Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/05/2022
page 1 of 4
MODEL: CST-951AP | DESCRIPTION: MAGNETIC BUZZER TRANSDUCER
FEATURES
• through hole
• 85 dB
• externally driven
SPECIFICATIONS
parameter
rated voltage
conditions/description
Vo-p
operating voltage
current consumption
min
4.0
at rated voltage, 2,730 Hz square wave, ½ duty
at 10 cm (A-weight), rated voltage, 2,730 Hz square wave,
½ duty
coil resistance
dimensions
max
5.0
0V
rated frequency
sound pressure level
typ
Vo-p
6.0
Vo-p
80
mA
2,730
Hz
85
92
dBA
25.5
30
34.5
Ø9.0 x 4.5
0.6
PPO
terminal
pin type (Au plating)
Ω
mm
weight
material
units
g
operating temperature
-20
70
°C
storage temperature
-30
80
°C
max
units
380
°C
RoHS
Notes:
yes
1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
min
hand soldering2
for maximum 2 seconds
330
Notes:
2. Not recommended for wave soldering
cuidevices.com
typ
Product Page
3D Model
PCB Footprint
CUI DEVICES | MODEL: CST-951AP | DESCRIPTION: MAGNETIC BUZZER TRANSDUCER
date 08/05/2022 | page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
Silver ink
6RXQG
(PLVVLRQ
+ROH
WEEK
YEAR
FREQUENCY RESPONSE CURVE
MEASUREMENT METHOD
+VDC
+2.5V
180Ω
TR:
2SC1741AS
cuidevices.com
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 3 of 4
PACKAGING
Internal Tray Size: 184 x 184 x 23 mm
Carton Size: 440 x 400 x 310 mm
QTY: 8,400 pcs (700 x 12)
100PCS
TRAY
Out Box
(7PCS Tray)
310mm
Carton Box
(12PCS Out Box)
400
mm
mm
cuidevices.com
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
01/30/2006
1.01
updated datasheet
07/31/2019
1.02
brand update
03/18/2020
logo, datasheet style update
08/05/2022
1.03
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CST-951AP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+5.40539100+0.65511
- 300+5.38013300+0.65204
- 500+5.38001500+0.65203
- 2000+5.379902000+0.65202
- 3000+5.379783000+0.65200
- 国内价格 香港价格
- 100+4.95494100+0.60051
- 400+4.93179400+0.59771
- 1500+4.931681500+0.59770
- 2500+4.931572500+0.59768
- 5000+4.931465000+0.59767
- 国内价格 香港价格
- 25+4.2342225+0.51317
- 75+4.2144475+0.51077
- 250+4.21434250+0.51076
- 750+4.21425750+0.51075
- 2500+4.214162500+0.51074
- 国内价格
- 10+5.98171
- 100+5.67763
- 250+5.39021
- 500+5.13195
