Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/05/2022
page 1 of 4
MODEL: CST-911AP | DESCRIPTION: MAGNETIC BUZZER TRANSDUCER
FEATURES
• through hole
• 85 dB
• externally driven
SPECIFICATIONS
parameter
rated voltage
conditions/description
Vo-p
operating voltage
current consumption
min
1.0
at rated voltage, 2,730 Hz square wave, ½ duty
at 10 cm (A-weight), rated voltage, 2,730 Hz square wave,
½ duty
coil resistance
dimensions
max
1.5
0V
rated frequency
sound pressure level
typ
Vo-p
2.0
Vo-p
80
mA
2,730
Hz
85
92
dBA
5.0
6.0
7.0
Ø9.0 x 4.5
0.6
PPO
terminal
pin type (Au plating)
Ω
mm
weight
material
units
g
operating temperature
-20
60
°C
storage temperature
-30
70
°C
max
units
380
°C
RoHS
Notes:
yes
1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
min
hand soldering2
for maximum 2 seconds
330
Notes:
2. Not recommended for wave soldering
cuidevices.com
typ
Product Page
3D Model
PCB Footprint
CUI DEVICES | MODEL: CST-911AP | DESCRIPTION: MAGNETIC BUZZER TRANSDUCER
date 08/05/2022 | page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
Silver ink
6RXQG
(PLVVLRQ
+ROH
WEEK
很抱歉,暂时无法提供与“CST-911AP”相匹配的价格&库存,您可以联系我们找货
