RU4S-M-A24
RU4S-M-A24
    IDEC
    RU4S-M-A24
RU4S-M-A24 数据手册
Relays & Sockets Switches & Pilot Lights RU RU Series Universal Relays Key features: • Full featured universal miniature relays • Designed with environment taken into consideration • Two terminal styles: plug-in and PCB mount • Non-polarized LED indicator Signaling Lights • No internal wires, lead-free construction • Cadmium-free contacts • Mechanical flag indicator • Manual latching lever with color coding for AC or DC coil • Snap-on yellow marking plate; optional marking plates are available in four other colors • Maximum contact ratings: 10A (RU2), 6A (RU4), 3A (RU42) Relays & Sockets • UL Recognized, CSA Certified, EN Compliant EN61810-1 With Latching or Momentary Lever Latching and Momentary Lever Using the lever, operation can be checked without energizing the coil. The lever is color coded for AC and DC coils. Timers Mechanical Indicator* The contact position can be confirmed through the five small windows. Marking Plate Standard yellow marking plate is easily replaced with optional marking plates in four colors for easy identification of relays. Latching Momentary AC coil: Orange Red DC coil: Green Blue In Normal Operation Note: Turn off the power to the relay coil when using the latching lever. After checking the operation, return the latching lever in the normal position. Standard (without lever) AC/DC Color Marking For identification of AC or DC coils. AC coil: Yellow DC coil: Blue Coil Voltage Tape Color 24V AC White Marking Plate 100 to 110V AC Clear LED Indicator* Non-polarized green LED indicator is standard provision for plug-in terminal types. 110 to 120V AC Blue 200 to 220V AC Black 220 to 240V AC Red 24V DC Green Mechanical Indicator* Circuit Breakers Terminal Blocks Contactors LED Indicator* Non-polarized green LED indicator is standard provision for plug-in terminal, latching lever types AC Coil DC Coil 6V DC 12V DC 48V DC *Not available on PCB type. 890 Voltage marking on yellow tape 110V DC www.IDEC.com 1705151135 Relays & Sockets RU Switches & Pilot Lights Part Number Selection Part Number Contact Model DPDT (10A) With Momentary Lever Standard RU2S-C-0 RU2S-0 RU2S-M-0 A24, A110, A220 D6, D12, D24, D48, D110 With RC (AC coil only) RU2S-CR-0 RU2S-R-0 RU2S-MR-0 A110, A220 With diode (DC coil only) RU2S-CD-0 RU2S-D-0 RU2S-MD-0 D6, D12, D24, D48, D110 PCB RU2V-NF-0 ­— — A24, A110, A220 D6, D12, D24, D48, D110 Standard RU4S-C-0 RU4S-0 RU4S-M-0 A24, A110, A220 D6, D12, D24, D48, D110 With RC (AC coil only) RU4S-CR-0 RU4S-R-0 RU4S-MR-0 A110, A220 With diode (DC coil only) RU4S-CD-0 RU4S-D-0 RU4S-MD-0 D6, D12, D24, D48, D110 PCB RU4V-NF-0 — — A24, A110, A220 D6, D12, D24, D48, D110 Standard RU42S-C-0 RU42S-0 RU42S-M-0 A24, A110, A220 D6, D12, D24, D48, D110 With RC (AC coil only) RU42S-CR-0 RU42S-R-0 RU42S-MR-0 A110, A220 With diode (DC coil only) RU42S-CD-0 RU42S-D-0 RU42S-MD-0 D6, D12, D24, D48, D110 PCB RU42V-NF-0 — — A24, A110, A220 D6, D12, D24, D48, D110 1. Plug-in terminal models have an LED indicator and a mechanical indicator as standard. 2. PCB models do not have an LED indicator or a mechanical indicator. Relays & Sockets 4PDT Bifurcated (3A) With Latching Lever Signaling Lights 4PDT (6A) Coil Voltage Code (Standard Stock in bold) Standard Ordering Information When ordering, specify the Part No. and coil voltage code: Part No. A110 Timers (example) RU2S-C Coil Voltage Code Coil Voltage Table Coil Voltage Code Coil Rating A24 A110 A220 D6 D12 D24 D48 D110 24V AC 110-120V AC 220-240V AC 6V DC 12V DC 24V DC 48V DC 110V DC Sockets Spring Clamp DIN Rail Mount Standard DIN Rail Mount Finger-safe DIN Rail Mount RU2S (DPDT) SU2S-11L SM2S-05 SM2S-05C RU4S (4PDT) RU42S (4PDT) SU4S-11L SY4S-05 SY4S-05C Panel Mount SY4S-51 Contactors Relays PCB Mount SM2S-61 SM2S-62 SY4S-61 SY4S-62 Terminal Blocks Circuit Breakers 1705151135 800-262-IDEC (4332) • USA & Canada 891 Relays & Sockets Hold Down Springs & Clips Appearance Signaling Lights Switches & Pilot Lights RU Item Relay For DIN Mount Socket For Through Panel & PCB Mount Socket Pullover Wire Spring RU2S/RU4S/ RU42S SY4S-02F1 SY4S-51F1 Leaf Spring (side latch) RU2S/RU4S/ RU42S SFA-202* SFA-302* Leaf Spring (top latch) RU2S/RU4S/ RU42S SFA-101* SFA-301* Note: Order 2 pieces for each relay Relays & Sockets Accessories Name Part Number Color Code * Marking Plate RU9Z-P* A (orange), G (green), S (blue), W (white), Y (yellow) Specify a color code when ordering. The marking plate can be removed from the relay by inserting a flat screwdriver under the marking plate. Specifications Model (Contact) Contact Material Timers Contact Resistance RU2 (DPDT) RU4 (4PDT) RU42 (4PDT-bifurcated) Silver alloy Silver (gold clad) Silver-nickel (gold clad) 50 mΩ maximum 1 Minimum Applicable Load 2 24V DC, 5 mA (reference value) 1V DC, 1 mA Operating Time 3 20 ms maximum Release Time 3 20 ms maximum 1V DC, 0.1 mA Power Consumption AC: 1.1 to 1.4VA (50 Hz), 0.9 to 1.2VA (60 Hz) DC: 0.9 to 1.0W Insulation Resistance 100MΩ minimum (500V DC megger) Terminal Blocks Contactors Between contact and coil: 2500V AC, 1 minute Dielectric Strength 2500V AC, 1 minute 2000V AC, 1 minute Between contacts of the same pole: 1000V AC, 1 minute Operating Frequency Electrical: 1800 operations/h maximum Mechanical: 18,000 operations/h maximum Vibration Resistance Damage limits: 10 to 55 Hz, amplitude 0.5 mm Operating extremes: 10 to 55 Hz, amplitude 0.5 mm Shock Resistance Mechanical Life Damage limits: 1000 m/s2 (100G) Operating extremes: 150 m/s2 (15G) AC: 50,000,000 operations DC: 100,000,000 operations 50,000,000 operations Electrical Life 4 See table on page 894 Operating Temperature 5 PCB model: –55 to +70°C (no freezing) Blade model: –55 to +60°C (no freezing) Operating Humidity Circuit Breakers Between contacts of different poles: Weight 5 to 85% RH (no condensation) Approx. 35g 1. Measured using 5V DC, 1A voltage drop method 2. Measured at operating frequency of 120 operations/min (failure rate level P, reference value) 3. Measured at the rated voltage (at 20°C), excluding contact bouncing; Release time of AC relays with RC: 25 ms maximum Release time of DC relays with diode: 40 ms maximum 892 4. Contact Load and Electrical Life (at ambient temperature 20°C) 5. Measured at the rated voltage. www.IDEC.com 1705151135 Relays & Sockets RU Item Appearance Use with Part No. Remarks All DIN rail sockets BNDN1000 The BNDN1000 is designed to accommodate DIN mount sockets. Made of durable extruded aluminum, the BNDN1000 measures 0.413 (10.5mm) in height and 1.37 (35mm) in width (DIN standard). Standard length is 39” (1,000mm). DIN Rail End Stop DIN rail BNL5 9.1 mm wide. Replacement Hold-Down Spring Anchor Horseshoe clip for DIN rail sockets Y778-011 For use on DIN rail mount socket when using pullover wire hold down spring. 2 pieces included with each socket. Signaling Lights Aluminum DIN Rail (1 meter length) Switches & Pilot Lights Accessories Coil Ratings Rated Voltage (V) DC 50 Hz 60 Hz Coil Resistance (Ω) ±10% (at 20°C) 24 A24 49.3 42.5 110-120 A110 8.4-10.0 7.1-8.2 4,550 220-240 A220 4.2-5.0 3.6-4.2 18,230 Operating Characteristics (values at 20°C) Maximum Continuous Applied Voltage Pickup Voltage Dropout Voltage 110% 80% maximum 30% minimum 110% 80% maximum 10% minimum Relays & Sockets AC (50/60 Hz) Rated Current (mA) ±15% (at 20°C) Coil Voltage Code 164 D6 155 40 D12 80 160 24 D24 44.7 605 48 D48 18 2,560 110 D110 8.9 12,100 Timers 6 12 1. The rated current includes the current of the LED indicator. Surge Suppressor Ratings UL and c-UL Ratings Model Ratings With RC DC Coil With Diode Diode reverse voltage: 1000V Diode forward current: 1A Voltage DPDT 4PDT 4PDT bifurcated 10A 6A 3A RU2 250V AC 10A — 3A 30V DC 10A 6A 3A Allowable Contact Power Rated Load Resistive Load Inductive Load Voltage (V) 2500VA AC 1250VA AC 250 AC 10A 300W DC 150W DC 30 DC 10A 5A 1500VA AC 600VA AC 250 AC 6A 0.8A 180W DC 90W DC 30 DC 6A 1.5A 750VA AC 200VA AC 250 AC 3A 0.8A 90W DC 45W DC 30 DC 3A 1.5A Res. Load Ind. Load 5A Horse Power Rating RU4 RU42 RU2 RU4 RU42 — 6A — — 1/10HP — — — — — — — TÜV Ratings Resistive RU42 Voltage Resistive Inductive RU2 RU4 RU42 RU2 RU4 RU42 250V AC 3A 250V AC 10A 6A 3A 5A 0.8A 0.8A 30V DC 3A 30V DC 10A 6A 3A 5A 1.5A 1.5A Circuit Breakers 1. On 4PDT relays, the maximum allowable total current of neighboring two poles is 6A. At the rated load, make sure that the total current of neighboring two poles does not exceed 6A (3A + 3A = 6A). 2. Inductive load for the rated load — cos ø = 0.3, L/R = 7 ms 1705151135 800-262-IDEC (4332) • USA & Canada Terminal Blocks Contact RU42 Voltage Maximum Contact Capacity General Use RU4 CSA Ratings Contact Ratings Continuous Current Resistive RU2 Contactors AC Coil RC series circuit R: 20 kΩ, C: 0.033 µF 893 Relays & Sockets Socket Specifications DIN Rail Mount Sockets Through Panel Mount Socket PCB Mount Socket Sockets Terminal Electrical Rating Wire Size SU2S-11L Spring clamp terminals 250V/10A 24-16 AWG SU4S-11L Spring clamp terminals 250V/6A (using RU4), 10A (using RU2) 24-16 AWG SM2S-05 M3 screw with captive wire clamp 300V, 10A Maximum up to 2–#14AWG 5.5 - 9in•lbs SM2S-05C M3 screw with captive wire clamp, fingersafe 300V, 10A Maximum up to 2–#14AWG 5.5 - 9in•lbs SY4S-05 M3 screw with captive wire clamp 300V, 7A (using RU4), 10A (using RU2) Maximum up to 2–#14AWG 5.5 - 9in•lbs SY4S-05C M3 screw with captive wire clamp, fingersafe 300V, 7A (using RU4), 10A (using RU2) Maximum up to 2–#14AWG 5.5 - 9in•lbs SY4S-51 Solder 300V, 7A — — SY4S-61 PCB mount 300V, 7A — — SY4S-62 PCB mount 250V, 7A — — RU2 (Resistive Load) RU4 (Resistive Load) (¥ 10,000 operations) 100 10 Timers 1 0.1 0.5 1 5 0.1 0.5 1 3 0.02 6 RU4 (Inductive Load) 10 AC: cos ø = 0.3 DC: L/R = 7 ms 5 10 1 10 0.02 0.1 3 6 100 10 AC: cos ø = 0.3 DC: L/R = 7 ms 1 1 250V AC 30V DC 110V DC 100 Load Current (A) 0.5 Load Current (A) RU42 (Inductive Load) (¥ 10,000 operations) 100 0.5 0.1 250V AC 30V DC 110V DC (¥ 10,000 operations) (¥ 10,000 operations) 10 Load Current (A) RU2 (Inductive Load) 0.1 100 1 1 10 Load Current (A) 1 250V AC 30V DC 110V DC 10 1000 Contactors — RU42 (Resistive Load) 100 250V AC/30V DC 110V DC AC: cos ø = 0.3 DC: L/R = 7 ms 0.5 1 0.02 Load Current (A) 0.1 0.5 Load Current (A) Maximum Switching Current RU2 RU4 RU42 (Bifurcated) AC resistive AC inductive (cos ø = 0.3) 10 5 Load Current (A) Terminal Blocks — 250V AC 30V DC 110V DC 1000 1000 (¥ 10,000 operations) Relays & Sockets 250V AC 30V DC 110V DC Circuit Breakers Torque Electrical Life Curves (¥ 10,000 operations) Signaling Lights Switches & Pilot Lights RU 1 0.1 DC resistive DC inductive L/R = 7 ms 10 30 100 250 500 Load Voltage (V) 894 www.IDEC.com 1705151135 Relays & Sockets RU RU2 (AC Coil, 60 Hz) 110 110 100 100 100 90 90 90 80 Load current 10A ¥ 2 poles 70 60 50 40 Load current 5A ¥ 2 poles Load current 10A ¥ 2 poles 70 60 50 40 20 Load current 5A ¥ 2 poles 10 20 30 40 50 60 0 70 10 RU4/RU42 (AC Coil, 50 Hz) 20 30 40 60 50 40 50 Ambient Temperature (C) 60 70 0 RU4/RU42 (AC Coil, 60 Hz) 100 90 90 90 50 40 30 Load current 3A ¥ 4 poles Load current 6A ¥ 2 poles 60 50 40 20 Load current 3A ¥ 4 poles 20 30 40 50 Ambient Temperature (C) 60 70 0 20 70 30 50 60 70 40 50 60 70 Load current 6A ¥ 2 poles 60 50 40 20 No load current 10 40 Load current 3A ¥ 4 poles No load current 10 60 70 0 10 Ambient Temperature (C) 20 30 40 50 Timers 10 30 80 30 10 10 0 80 30 No load current 20 Temperature Rise (C) 100 Temperature Rise (C) 110 100 60 20 Relays & Sockets 120 110 70 10 RU4/RU42 (DC Coil) 110 Load current 6A ¥ 2 poles No load current Ambient Temperature (C) 120 70 Load current 5A ¥ 2 poles 10 120 80 Load current 10A ¥ 2 poles 70 20 No load current Ambient Temperature (C) 80 30 10 10 0 80 30 No load current 20 Temperature Rise (C) 120 110 Temperature Rise (C) 120 30 Temperature Rise (C) RU2 (DC Coil) 120 Signaling Lights Temperature Rise (C) RU2 (AC Coil, 50 Hz) Switches & Pilot Lights Ambient Temperature vs. Temperature Rise Curves Ambient Temperature (C) The above temperature rise curves show the characteristics when 100% the rated coil voltage is applied. The heat resistance of the coil is 120°C. The slant dashed line indicates the allowable temperature rise for the coil at different ambient temperatures. Load current 6A x 2 poles is for the RU4 models only. Contactors Terminal Blocks Circuit Breakers 1705151135 800-262-IDEC (4332) • USA & Canada 895 Relays & Sockets Internal Connection (View from Bottom) RU2S-* Standard (1)12 (5)14 (9)11 (13)A1 RU2S-*R with RC (4)42 RU2S-*D With Diode (1)12 (8)44 (5)14 (12)41 Signaling Lights (5)14 (1)12 (4)42 (12)41 (9)11 (13)A1 (14)A2 (13)A1 Relays & Sockets RU4S-*/RU42S-* Standard RU4S-*R/RU42S-*R With RC (3)32 (4)42 (1)12 (7)34 (8)44 (5)14 (9)11 (10)21 (11)31 (12)41 (13)A1 (2)22 (6)24 (3)32 (5)14 (6)24 (7)34 Timers (14)A2 (5)14 (6)24 (8)44 (14)A2 (1)12 (7)34 (8)44 (5)14 (2)22 (6)24 (3)32 (7)34 (4)42 (8)44 (9)11 (10)21 (11)31 (12)41 (14)A2 (13)A1 (14)A2 (13)A1 RU4V-NF-*/RU42V-NF-* (3)32 (4)42 (9)11 (10)21 (11)31 (12)41 (9)11 (10)21 (11)31 (12)41 (13)A1 (14)A2 24V DC coil or less (3)32 (4)42 (1)12 (2)22 (7)34 (8)44 (5)14 (6)24 (3)32 (4)42 (7)34 (8)44 (9)11 (10)21 (11)31 (12)41 (14)A2 Over 24V AC/DC coil (14)A2 (13)A1 Mechanical Indicator Window Marking Plate (yellow) Latching Lever AC: Orange RU2S DC: Green Over 24V DC coilMarking Plate (yellow) LED Indicator (green) Color Marking Dimensions (mm) AC: Yellow DC: Blue RU2V Marking Plate Removal Slot 0.5 35.0 Marking Plate Removal Slot Contactors (12)41 (1)12 (2)22 (9)11 (10)21 (11)31 (12)41 (13)A1 (14)A2 (8)44 RU4S-*D/RU42S-*D With Diode (4)42 24V AC/DC coil or less (1)12 (2)22 (13)A1 Over 24V DC coil Over 24V AC/DC coil (5)14 (6)24 (12)41 (4)42 (5)14 (8)44 (9)11 (1)12 (2)22 (14)A2 (8)44 (9)11 24V DC coil or less 24V AC/DC coil or less (1)12 (4)42 (5)14 (12)41 (13)A1 (14)A2 (1)12 (8)44 (9)11 (12)41 (13)A1 (4)42 (5)14 (8)44 (9)11 (14)A2 (1)12 (4)42 RU2V-NF-* 35.0 Switches & Pilot Lights RU 13.2 2.6 ø1.2 ¥ 2.2 Hole 21.0 Terminal Blocks 0.8 2.6 21.0 14 6.4 12 9 5 13 4 8 1 0.5 4.0 0.5 27.5 27.5 Mounting Hole Layout 7.0 oles 1H 8-ø 13.2 Marking plate removal slot is provided only on one side. Insert a flat screwdriver into the slot to remove the marking plate. 4.1 6.4 12.7 Circuit Breakers All dimensions in mm. 896 www.IDEC.com 1705151135 Mechanical Indicator Window Marking Plate (yellow) Relays & Sockets Color Marking AC: Yellow DC: Blue LED Indicator (green) Latching Lever AC: Orange RU4S/RU42S DC: Green RU Marking Plate (yellow) Switches & Pilot Lights Dimensions con’t (mm) RU4V/RU42V 0.5 35.0 Marking Plate Removal Slot 35.0 Marking Plate Removal Slot 4.0 6.4 14 8 12 0.8 2.6 ø1.2 × 2.2 Hole 13 10 9 21.0 11 4 6 5 7 2 1 3 21.0 3-4.4 0.5 2.6 Signaling Lights 0.5 27.5 27.5 Marking plate removal slot is provided only on one side. Insert a flat screwdriver into the slot to remove the marking plate. Mounting Hole Layout 7.0 ø1 es Hol Relays & Sockets 6.4 12.7 4.1 4.4 13.2 14- All dimensions in mm. Spring Clamp DIN Rail Mount Sockets SU2S-11L SU4S-11L 31 Terminal Arrangement 2-ø3.2 Mounting Holes 9 8 5 4 1 14 13 28.8 (Top View)   6 5 4 3 2 1 37.5 80 Ring terminals cannot be used. 2-ø3.2 Mounting Holes 7 14 32 38.3 4.4 28.8 24.0 9 8 Ring terminals cannot be used. 13 (Top View) Contactors 32 38.3 4.4 Terminal Arrangement 12 11 10 37.5 80 24.0 12 Standard DIN Rail Mount Sockets SY4S-05 18 8 18 4 1 14 13 12 9 25 4.8 min. 26 ø3.2 min. Terminal Arrangement 8 4 7 6 3 2 5 1 26 4 max. 4.8 min. 14 13 12 11 10 9 18.5 (Top View) 5.9 max. 2-ø4.2 Mounting Holes (or M4 Tapped Holes) 45 62 4 max. DIN Rail (BNDN) 5 26 4.2 3 M3 Terminal Screw Terminal Blocks   31.5 6 Terminal Arrangement 2-ø4.2 Mounting Holes (or M4 Tapped Holes) 18.5 26 30 4.2 M3 Terminal Screw DIN Rail (BNDN) 3 6 0.7 31.5 45 30 62 0.7 SM2S-05 Timers 31 25 (Top View) 5.9 max. ø3.2 min. Circuit Breakers 1705151135 800-262-IDEC (4332) • USA & Canada 897 Relays & Sockets Dimensions con’t (mm) Finger-safe DIN Rail Mount Sockets SM2S-05C SY4S-05C 30 DIN Rail (BNDN) 35.5 25 M3 Terminal Screw 18 5 1 46 Ring terminals cannot be used. 13 12 9 (Top View) 8 7 6 5 4 3 2 1 29 26 Ring terminals cannot be used. 18.2 26 1.6 18.2 14 Terminal Arrangement 2-ø4.2 Mounting Holes (or M4 Tapped Holes) 18 64 8 4 DIN Rail (BNDN) 25 ø5.5 26 2 26 1.6 Signaling Lights 64 4.2 ø5.5 Terminal Arrangement 2-ø4.2 Mounting Holes (or M4 Tapped Holes) 35.5 M3 Terminal Screw 6 46 6 2 30 4.2 Switches & Pilot Lights RU 14 13 12 11 10 9 (Top View) 29   PCB Mount Sockets SM2S-62 15 21.2 4.1 4 8 12 14 (Bottom View) 15 1.5 (Tolerance 0.1) * 17.2 min. when using a hold-down spring. ** 13.2 min. when using a hold-down spring for the relay with check button. SY4S-61 SY4S-62 13.2 13.8 min. (Bottom View) 11 1.5 4.1 16.8 10.4 (Bottom View) 3 15-ø2 holes 11 15 15-ø2 holes (Tolerance 0.1) * 19.2 min. when using hold-down springs 21.2 1 2 3 4 5 6 7 8 9 10 11 12 13 14 1.4 0.3 21.2 1.4 15 29 16.8 9 10.4 Terminal Arrangement 1.5   12.2 min.* 3 4.4 14.2 min.* 27 0.3 31 25.4 1 2 3 4 5 6 7 8 9 10 11 12 13 14 4.4 4.1 Terminal Arrangement 8.2 min.** 8.8 8.8 9 Timers 13.2 Contactors 9 9-ø2 holes 11 (Tolerance 0.1) * 19.2 min. when using hold-down springs 1.5 3 1 5 9 13 8.2 min.** 16.8 10.4 29 9 21.2 9-ø2 holes 1.4 11 0.3 4.1 10.4 (Bottom View) 14.2 min.* 3 13.2 Terminal Arrangement 12.2 min.* 0.3 27 4 8 12 14 13.8 min. 16.8 25.4 1 5 9 13 13.2 1.4 Terminal Arrangement 31 Relays & Sockets SM2S-61 (Tolerance 0.1) * 17.2 min. when using a hold-down spring. * *13.2 min. when using a hold-down spring for the relay with check button Through Panel Mount Socket SY4S-51 3 11 18.7 2.4 [27 (N–1) + 21.4] + 0.5 0 13 14 0 25.6 1 2 3 4 5 6 7 8 9 10 11 12 +0.2 Terminal Arrangement (Bottom View) N: No. of sockets mounted 5.4 min.* 25.4 27 0.3 31 Terminal Blocks Panel Thickness: 1 to 2 * 10.4 min. when using hold-down springs 21.2 Circuit Breakers   898 www.IDEC.com 1705151135
RU4S-M-A24 价格&库存
很抱歉,暂时无法提供与“RU4S-M-A24”相匹配的价格&库存,您可以联系我们找货
