SFHG40AA002
SFHG40AA002
    WISOL(威盛)
    SMD
    SFHG40AA002
SFHG40AA002 数据手册
SPECIFICATION Surface Acoustic Wave Filter USER USER PART No. SEMCO PART No. SFHG40AA002 DOC. No. SMS-51-L-SFT FX-22 DATE July 23, 2013 REVISION Preliminary WISOL Kim, Kyung-Sik Jeon. Hyeon Cheol Hong, Seong-Su ISSUED APPROVED APPROVED BY BY (R&D) BY (QC) User ISSUED CHECKED APPROVED BY BY BY WISOL CO., LTD. 373-7, GAJANG-DONG, OSAN-SI, GYUNGGI-DO, KOREA, 447-210 http://www.wisol.co.kr Surface Acoustic Wave Filter WCDMA Rx 2140.0MHz UMTS Band Ⅰ SFHG40AA002 3 1.1×0.9×0.5mm 5pin lay-out Version : Preliminary ▶ A TABLE OF CONTENTS 1. REVISION HISTORY ............................................................................................................................. 3 2. DEFINITION ........................................................................................................................................... 4 3. PRECAUTIONS...................................................................................................................................... 4 4. OUTLINE DRAWING & DIMENSIONS .................................................................................................. 5 5. MARKING ............................................................................................................................................... 6 6. PERFORMANCE.................................................................................................................................... 7 6-1. MAXIMUM RATINGS ................................................................................................................... 7 6-2. ELECTRICAL CHARACTERISTICS ............................................................................................ 8 7. RELIABILITY ........................................................................................................................................ 10 7-1. ENGINEERING SAMPLE FLOW CHART ................................................................................. 10 7-2. TEST ITEM & CONDITION ......................................................................................................... 11 8. REFLOW CONDITION ......................................................................................................................... 12 9. RECOMMENDED PCB DIMENSIONS ................................................................................................ 12 11. PACKING ........................................................................................................................................... 14 11-1. DIMENSIONS .......................................................................................................................... 14 11-2. REELING QUANTITY .............................................................................................................. 15 11-3. TAPING STRUCTURE ............................................................................................................. 15 11-4. INNER BOX(Reel Packing) STRUCTURE .............................................................................. 16 11-5. OUTER BOX STRUCTURE ..................................................................................................... 17 12. TAPE SPECIFICATIONS ................................................................................................................... 18 13. RoHS DATA ....................................................................................................................................... 19 SMS-51-L-SFT FX-22 Page 2/20 July 23, 2013 Surface Acoustic Wave Filter WCDMA Rx 2140.0MHz UMTS Band Ⅰ SFHG40AA002 3 1.1×0.9×0.5mm 5pin lay-out Version : Preliminary 1. REVISION HISTORY Preliminary July 23, 2013 SMS-51-L-SFT FX-22 All Page Make specification Page 3/20 July 23, 2013 Surface Acoustic Wave Filter SFHG40AA002 WCDMA Rx 2140.0MHz UMTS Band Ⅰ 3 1.1×0.9×0.5mm 5pin lay-out Version : Preliminary 2. DEFINITION 2-1. PART No. SFHG40AA002 ① ② ③ ④ No. ⑤ ⑥ EXPLANATION ① SAW Filter ② Design Type ③ Center Frequency :2140.0MHz(2110 ~ 2170) ④ Input:50ohm,Output:50ohm ⑤ Package size: 1.1×0.9mm² ⑥ Design Revision (02 : Molding Type) 2-2. APPLICATION : Band-Pass Filter for CDMA Rx etc (UMTS Band Ⅰ) 3. PRECAUTIONS 3-1. This device should not be used in any type of fluid such as water, oil, organic solvent, etc. 3-2. This is a hermetic device. MSL(Moisture Sensitive Level) is the '2a' level. 3-3. Ultrasonic cleaning shall be avoided. 3-4. Isopropyl Alcohol and Ethyl Alcohol can be used for cleaning. Contact us before using other cleaning solvents than above 3-5. This is an electrostatic sensitive device. Please avoid static voltage during operation and storage. 3-6. Sudden change of temperature shall be avoided, deterioration of the characteristics can occur. 3-7. If any malfunction due to designing or manufacturing which is out of specification occurs within one year after the products have been delivered, the maker should exchange the defective products. SMS-51-L-SFT FX-22 Page 4/20 July 23, 2013 Surface Acoustic Wave Filter WCDMA Rx 2140.0MHz UMTS Band Ⅰ SFHG40AA002 3 1.1×0.9×0.5mm 5pin lay-out Version : Preliminary 4. OUTLINE DRAWING & DIMENSIONS [Unit: mm] mFX O X SMS-51-L-SFT FX-22 Page 5/20 No. Function 2, 3, 5 Ground 1 Unbalanced Input 4 Unbalanced Output July 23, 2013 Surface Acoustic Wave Filter SFHG40AA002 WCDMA Rx 2140.0MHz UMTS Band Ⅰ 3 1.1×0.9×0.5mm Version : Preliminary 5pin lay-out 5. MARKING mFX O X 5-1. m F X X st nd - The 1 2 character 'mF' indicates the model name of SAW Filter SFHG40AA002. rd - The 3 character 'X' indicates the year and the month of manufacture. Year Month 1 2 3 4 5 6 7 8 9 10 11 12 2013 P Q R S T U V W X Y Z a 2014 1 2 3 4 5 6 7 8 9 A B C 2015 D E F G H I J K L M N O 2016 P Q R S T U V W X Y Z a ※ This rotates by the 3 years. - The th 4 character 'X' indicates Lot No. 5-2. ○ - This symbol indicates input pin 1. - This indicates the producing center ○ : China, 5-3. Marking : Laser Marking SMS-51-L-SFT FX-22 Page 6/20 July 23, 2013 Surface Acoustic Wave Filter WCDMA Rx 2140.0MHz UMTS Band Ⅰ SFHG40AA002 3 1.1×0.9×0.5mm Version : Preliminary 5pin lay-out 6. PERFORMANCE 6-1. MAXIMUM RATINGS CHARACTERISTICS RATINGS UNITS DC Permissive Voltage 5 V Maximum Input Power 15 dBm Operating Temperature Range -30 ~ +85 ℃ Storage Temperature Range -40 ~ +85 ℃ SMS-51-L-SFT FX-22 Page 7/20 July 23, 2013 Surface Acoustic Wave Filter WCDMA Rx 2140.0MHz UMTS Band Ⅰ SFHG40AA002 3 1.1×0.9×0.5mm Version : Preliminary 5pin lay-out 6-2. ELECTRICAL CHARACTERISTICS 6-2-1. TABLE Ta = -30 ~ +85℃ SPECIFICATION FREQUENCY RANGE [MHz] UNIT Insertion Loss 2110 ~ 2170 Inband Ripple Item Min. Typ. (25℃) Max. dB - 1.9 2.6 2110 ~ 2170 dB - 0.4 1.2 Input VSWR 2110 ~ 2170 - - 1.6 2.3 Output VSWR 2110 ~ 2170 - - 1.6 2.3 DC ~ 1920 dB 28 33 - 1920 ~ 1980 dB 30 35 - 2230 ~ 2300 dB 20 25 - 2300 ~ 3000 dB 22 27 - 3000 ~ 6000 dB 27 32 - Absolute Attenuation Input: Unbalanced 50 ohm Output: Unbalanced 50 ohm Termination Impedance 6-2-2. TEST FIXTURE [X—Ray Top View] SMS-51-L-SFT FX-22 Page 8/20 July 23, 2013 Surface Acoustic Wave Filter SFHG40AA002 WCDMA Rx 2140.0MHz UMTS Band Ⅰ 3 1.1×0.9×0.5mm Version : Preliminary 5pin lay-out 6-2-3. GRAPH NearBand 0 -10 [dB] -20 -30 -40 -50 1.89 1.99 2.09 2.19 Frequency (GHz) 2.29 2.39 WideBand 0 -10 [dB] -20 -30 -40 -50 -60 0 SMS-51-L-SFT FX-22 1 2 3 Frequency (GHz) Page 9/20 4 5 6 July 23, 2013 Surface Acoustic Wave Filter WCDMA Rx 2140.0MHz UMTS Band Ⅰ SFHG40AA002 3 1.1×0.9×0.5mm 5pin lay-out Version : Preliminary 7. RELIABILITY 7-1. ENGINEERING SAMPLE FLOW CHART Initial Characteristics Electrical Parametric Data@25℃ Preconditioning (JESD22-A113F) Temp. Drift (n=5) Thermal Shock (n=23) Board Adhesion (n=11) Low Temp. Storage (n=23) PCT (n=23) Bending Test (n=11) High Temp. Storage (n=23) Vib ration (n=23) ESD Test (n=11) Humidity Test (n=23) Drop (n=23) ESD Limit Test (n=11) Final Electrical Data (n=74) Final Electrical Data (n=92) Final Electrical Data (n=44) SMS-51-L-SFT FX-22 Page 10/20 July 23, 2013 Surface Acoustic Wave Filter WCDMA Rx 2140.0MHz UMTS Band Ⅰ SFHG40AA002 3 1.1×0.9×0.5mm 5pin lay-out Version : Preliminary 7-2. TEST ITEM & CONDITION CATEGORY TEST ITEM Preconditioning Environment Test JESD22A113F -30℃ → +25℃→ +85℃ High Temp. Storage +85℃ 240hr JESD22-A103C Low Temp. Storage -40℃ 240hr JESD22-A119 description High Temp. High Humidity Storage +85℃ 85%RH 240hr JESD22-A106B Thermal Shock -40℃/30min ⇔ +85℃/30min , 100cycle JESD22-A106A +121℃ 100%RH 96hr JESD22-A102C Vibration Test (Random) 20 ㎐~2000 ㎐,0.053G²/Hz or 8g's RMS,15min/plane IEC 68-2-36 Fdb Drop Test 152 ㎝ 12times Steel floor JIG(110g~150g) IEC 1178-1.4.8.9 0.5 ㎜/sec 1point push IEC 68-2-21 Ue3 0.5 ㎜/sec 3times -PCB : FR4 , PCB SIZE : 100*40 ㎜ IEC 68-2-21 Ue3 Solder Heat Resistance ±250V,C=100pF,R=1.5 ㏀,1times IEC 68-2-21 Ue3 static marginal test C=100pF,R=1.5 ㏀,1times(demand of customer) JESD22-A114F Board Adhesion Bending Test Physical Test +125℃ 24hr Baking → +60℃ 60%RH 120hr → Reflow Test(3times) REMARK Temp. Drift High Temp. Operating Mechanical Test TEST CONDITION SMS-51-L-SFT FX-22 Page 11/20 July 23, 2013 Surface Acoustic Wave Filter WCDMA Rx 2140.0MHz UMTS Band Ⅰ SFHG40AA002 3 1.1×0.9×0.5mm 5pin lay-out Version : Preliminary 8. REFLOW CONDITION 9. RECOMMENDED PCB DIMENSIONS SMS-51-L-SFT FX-22 Page 12/20 July 23, 2013 Surface Acoustic Wave Filter WCDMA Rx 2140.0MHz UMTS Band Ⅰ SFHG40AA002 3 1.1×0.9×0.5mm 5pin lay-out Version : Preliminary 10. CAUTION Moisture Sensitivity Device Caution (MSL LEVEL=2a) 1. Calculated shelf life in sealed bag : 12 month at 〈40℃ and 〈90% relative Humidity(RH) 2. Peak package body temperature : 260℃ 3. After bag is opened, devices that will be subjected to reflow solder or other high temperature process must be (a) Mounted within : 672 hours of factory conditions ≤30℃/60% RH, or (b) Stored per J-STD-033 4. Device require bake, before mounting, if : (a) Humidity Indicator Card reads 〉60% when read at 23±5℃ (b) 3(a) or 3(b) are not met 5. If baking is required, refer to IPC/JEDEC J-STD-033 for bake procedure Note : Level and body temperature defined by IPC/JEDEC J-STD-020 Aluminum Pack (310mmΧ370mm) HIC(Humidity Indication Card) 10 to 60% RH SMS-51-L-SFT FX-22 Page 13/20 July 23, 2013 Surface Acoustic Wave Filter SFHG40AA002 WCDMA Rx 2140.0MHz UMTS Band Ⅰ 3 1.1×0.9×0.5mm Version : Preliminary 5pin lay-out 11. PACKING 11-1. DIMENSIONS - Carrier Tape [Unit: mm] A B D0 D1 E F P0 P1 P2 t1 t2 W 1.1 1.35 Ø 1.50 Ø 0.50 1.75 3.5 4 4 2 0.25 0.7 8 0.05 0.10 0.10 0.05 0.02 +0.10 0.05 0.05 -0.00 +0.30 0.05 0.10 0.07 -0.10 - Reel [Unit: mm] A B C D E F G H t1 t2 W Ø 258.0 Ø 81.0 Ø 13.0 50.0 2.2 7.0 30.0 35.0 1.8 1.5 9.0 1.0 0.5 0.8 0.3 0.5 0.8 1.0 0.5 0.5 +1.0 +1.0 -0.5 -0.5 - The product shall be packed properly not to damaged during transportation and storage. SMS-51-L-SFT FX-22 Page 14/20 July 23, 2013 Surface Acoustic Wave Filter WCDMA Rx 2140.0MHz UMTS Band Ⅰ SFHG40AA002 3 1.1×0.9×0.5mm Version : Preliminary 5pin lay-out 11-2. REELING QUANTITY 10 inch reel : 10,000 pcs/reel 11-3. TAPING STRUCTURE 11-3-1. The tape shall be wound around the reel in direction shown below. m F X O X m F X O X 11-3-2. BAR CODE LABEL SMS-51-L-SFT FX-22 ① MODEL NAME BARCODE ② SFH836AQ101 Model Name ③ RLYC12563 Reel number ④ 8000 / qAFYU Quantity / Marking Page 15/20 July 23, 2013 Surface Acoustic Wave Filter SFHG40AA002 WCDMA Rx 2140.0MHz UMTS Band Ⅰ 3 1.1×0.9×0.5mm 5pin lay-out Version : Preliminary 1-3-3. Leader part and vacant position specifications. 11-4. INNER BOX(Reel Packing) STRUCTURE Material: Polycarbonate Material: Polyethylene + Aluminium Size: 310×370mm Material: Size: 2 Paper (D)260×(W)37×(H)265mm SMS-51-L-SFT FX-22 3 Page 16/20 July 23, 2013 . . Surface Acoustic Wave Filter WCDMA Rx 2140.0MHz UMTS Band Ⅰ SFHG40AA002 3 1.1×0.9×0.5mm 5pin lay-out Version : Preliminary 11-5. OUTER BOX STRUCTURE Material : Paper TYPE A SIZE(mm) a b c Inner Box # 270 240 275 6 boxes SIDE ① SIDE ② - SIDE is the same as front side. SMS-51-L-SFT FX-22 Page 17/20 July 23, 2013 Surface Acoustic Wave Filter WCDMA Rx 2140.0MHz UMTS Band Ⅰ SFHG40AA002 3 1.1×0.9×0.5mm 5pin lay-out Version : Preliminary 12. TAPE SPECIFICATIONS 12-1. Tensile Strength of Carrier Tape: 4.4N/mm width 12-2. Top Cover Tape Adhesion (See the below figure) - pull of angle: 0~15 degree - speed: 300mm/min. - force: 20~70g SMS-51-L-SFT FX-22 Page 18/20 July 23, 2013 Surface Acoustic Wave Filter WCDMA Rx 2140.0MHz UMTS Band Ⅰ SFHG40AA002 3 1.1×0.9×0.5mm 5pin lay-out Version : Preliminary 13. RoHS DATA SMS-51-L-SFT FX-22 Page 19/20 July 23, 2013 Surface Acoustic Wave Filter WCDMA Rx 2140.0MHz UMTS Band Ⅰ SMS-51-L-SFT FX-22 SFHG40AA002 3 1.1×0.9×0.5mm 5pin lay-out Page 20/20 Version : Preliminary July 23, 2013
SFHG40AA002 价格&库存
很抱歉,暂时无法提供与“SFHG40AA002”相匹配的价格&库存,您可以联系我们找货
