SF1F-002T-P0.6
SF1F-002T-P0.6
    JST
    Through Hole
    SF1F-002T-P0.6
SF1F-002T-P0.6 数据手册
JFA CONNECTOR J1000 SERIES 2.2mm pitcth/Disconnectable Crimp style connectors(Wire-to-board/Wire-to-wire) Specifications ––––––––––––––––––– •Current rating: Circuits 3 6 8 12 20 22 26 30 Connectors for signal circuit or power supply circuit, applicable to the factory automation, heavy electric machinery, and other industrial equipment in general. In spite of various kinds of housings available, their contacts are designed to be common. The applicable tooling can be standardized. • Double-spring construction • Up to AWG #18 with 2.2 mm pitch • Housing lance • Secure locking method • Recognition mark 1 #18 6.4 5.5 5.5 4.7 4.0 3.9 3.6 3.6 Unit: (A) #20 5.4 4.6 4.6 3.9 3.4 3.3 3.0 3.0 Wire size (AWG) #24 #22 4.0 4.8 3.4 4.0 3.1 4.0 2.7 3.4 2.4 3.0 2.3 2.9 2.2 2.6 2.1 2.6 #26 3.4 2.9 2.6 2.3 2.0 1.9 1.8 1.7 #28 2.8 2.4 2.2 2.0 1.8 1.7 1.6 1.5 •Voltage rating: 125 V AC, DC/ J1100 250 V AC, DC/ J1800 •Temperature range: -55°C to +105°C (including temperature rise in applying electrical current) •Applicable wire: AWG #28 to #18 •Applicable PC board thickness: 1.6 mm *In using the products, refer to "Handling Precaution for Terminal and Connector" described on our website (Technical documents of Product information page). *Contact JST for details. *RoHS2 compliance. Standards –––––––––––––––––––––– 0 Recognized E60389 JFA CONNECTOR/J1000 SERIES List of J1000 series products 2.2 mm pitch / Voltage rating 125 V AC, DC Type Wire-to-board Wire-to-wire Top entry type Side entry type Free hanging type 3 3 3 6, 8, 12, 20, 22, 26, 30 6, 8, 12, 20, 30 6, 8, 12, 20, 26 J1100 Single-row type Center locking type Circuits J1100 Double-row type Circuits 2.2 mm pitch / Voltage rating 250 V AC, DC Type Side locking type (Thin type) Wire-to-board Top entry type Side entry type 8 8 J1800 Single-row type Circuits 2 JFA CONNECTOR/J1000 SERIES Receptacle contact Strip contact Model No. Gold-plated Size SF1F-002GC-P0.6 Gold (0.2μm) M Tin SF1F-002T-P0.6 SF1F-01GC-P0.6 Gold (0.2μm) ME SF1F-21GC-P0.6 Gold (0.2μm) L Tin SF1F-21T-P0.6 12.8 (7) Applicable wire Series (4.3) (2) mm2 AWG # Insulation O.D. (mm) Q'ty/ reel 0.08∼0.2 28∼24 0.88∼1.43 6,000 0.2∼0.5 24∼20 1.30∼1.90 5,500 0.3∼0.8 22∼18 1.50∼2.10 5,000 Material and Finish J 1Ⅱ L Copper alloy, nickel-undercoated, selective gold-plated Tin-plated Series name Wire range mark RoHS2 compliance Note: Contact JST for 0.76 μm gold-plated product. Tin-plated 12.8 (4.3) (7) (2) J 1ⅡL Series name Wire range mark Tab contact Strip contact Model No. Size SF1M-002GC-M0.6A Gold (0.2μm) M Tin SF1M-002T-M0.6A SF1M-01GC-M0.6A Gold (0.2μm) ME SF1M-21GC-M0.6A Gold (0.2μm) L Tin SF1M-21T-M0.6A 20.9 (4.3) Applicable wire Series (10.8) (2) mm2 AWG # Insulation O.D. (mm) Q'ty/ reel 0.08∼0.2 28∼24 0.88∼1.43 6,000 0.2∼0.5 24∼20 1.30∼1.90 5,500 22∼18 1.50∼2.10 5,000 0.3∼0.8 Material and Finish Copper alloy, nickel-undercoated, selective gold-plated Tin-plated J 1ⅡL Series name RoHS2 compliance Note: Contact JST for 0.76 μm gold-plated product. Wire range mark Crimping machine, Applicator Strip contact Model No. SF1F-002(*) -P0.6 SF1M-002(*) -M0.6A SF1F-01GC -P0.6 SF1M-01GC -M0.6A Crimping machine Applicator Crimp applicator Hand crimp with dies tools Crimp applicator Dies AP-K2N MKS-L MK/SF1F/ M-002-06 APLMK SF1F/ M002-06 YRK-1220 AP-K2N MKS-L MK/SF1F/ M-01-06 APLMK SF1F/ M01-06 YRK-1230 Strip contact Model No. Crimping machine Crimp applicator Dies Applicator Crimp applicator Hand crimp with dies tools SF1F-21(*) -P0.6 MK/SF1F/ APLMK SF1F/ YRK-1210 AP-K2N MKS-L M21-06 M-21-06 SF1M-21(*) -M0.6A Note: Finish (*): GC ...Nickel-undercoated, 0.2 μm selective gold-platted T ......Tin-plated • Extraction tool for J1100 series: EJ-JFAJ1100/EJ-JFAJ1100N • Extraction tool for J1800 series: EJ-JFAJ18 • Refer to the page of "Crimping tools" for details of YRK series hand crimping tools that uses a strip contact. Note: Contact JST for fully automatic crimping applicator. Recognition mark Plating of the contact Each contact has a marking on its side so that the type or thickness of the plating is recognized. 1 ... gold-plated 0.2 μm thickness 3 ... gold-plated 0.76 μm thickness 5 ... tin-plated Receptacle contact Tab contact Wire range mark Series name Indication of the plating Common marking on the contact and its application tools In order to avoid incorrect combination of the hand crimp tools or extraction tools and the contacts, the series name (for example J1 ) and wire range mark (M, ME, L) are shown on both the tools and the contacts. J1 3 M..... AWG #28 ∼ #24 ME.... AWG #24 ∼ #20 L..... AWG #22 ∼ #18 Receptacle contact Tab contact Wire range mark Indication of the plating Series name J1000 SERIES/J1100 Assembly layout Wire-to-board Type Top entry type Wire-to-wire Side entry type Free hanging type (10.6) X X A A (10.6) (11.8) (23.4) A X J1100 Single-row type (22.9) A A (33.2) A (14.5) X B B A A X B B A A (14.5) (15.7) A B (23.4) J1100 Double-row type X (25.1) (33.2) B A 4 J1000 SERIES/J1100 Receptacle housing Circuits Keying 3 Dimensions (mm) Model No. J11SF-03V-KX J11SF-03V-KY X Y Q’ty/box A B 4.4 8.0 1,200 4.4 8.0 1,200 Material and Finish Glass-filled PBT, UL94V-0, black Keying No. 16.7 B (11.3) RoHS2 compliance 6.6 X A 2.2 Line No. A Tab housing Circuits Keying 3 2 1 X Keying No. Circuit No. 3 Dimensions (mm) Model No. X J11SFM-03V-KX Y — A B 4.4 — 9.2 — Q’ty/box 500 — Material and Finish Series name Glass-filled PBT, UL94V-0, black RoHS2 compliance B A 29.3 2.2 A 8.4 Line No. Header Top entry type X Keying No. 1 ±0.1 (2.5) (8.4) 3 2 1 Circuit No. Circuits Plating 2 ±0.05 Connector outline 2.7 ±0.05 Gold (0.2μm) 3 Tin Series name φ1 ±0.05 Keying Model No. X B03B-J11SK-GWXR B03B-J11SK-GWYR B03B-J11SK-TXR B03B-J11SK-TYR Y X Y Dimensions (mm) Q’ty/ box A B 4.4 9.2 625 4.4 9.2 625 2.2 ±0.05 Line No. A±0.05 3.2 2.7 (B) PC board layout (Reference) (viewed from component side) A 8.4 Post: Copper alloy, gold-plated, tin-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, tin-plated 2.2 A 19.5 Material and Finish (2.4) 3.6 RoHS2 compliance Note: 1. Gold-plated product displays (LF) on a label. 2. Contact JST for 0.76 μm gold-plated product. B Header Side entry type Connector outline (0.6) B A 19 2.2 3.1 A 8 3.3 9.6 8.4 Line No. 5 1 ±0.1 X Keying No. Series name (0.6) 2 ±0.05 Gold (0.2μm) 3 Tin 8 ±0.05 (19) 3 2 1 Circuit No. Circuits Plating (B) φ1 ±0.05 A Model No. X S03B-J11SK-GWXR S03B-J11SK-GWYR S03B-J11SK-TXR S03B-J11SK-TYR Y X Y Material and Finish 2.2 ±0.05 ±0.05 Keying (2.4) PC board layout (Reference) (viewed from component side) Post: Copper alloy, gold-plated, tin-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, tin-plated RoHS2 compliance Note: 1. Gold-plated product displays (LF) on a label. 2. Contact JST for 0.76 μm gold-plated product. Dimensions (mm) Q’ty/ box A B 4.4 9.2 600 4.4 9.2 600 J1000 SERIES/J1100 Receptacle housing Circuits Keying 6 X Y 8 X Y 12 X Y 20 X Y B 16.7 Keying No. A 22 X Y 2.2 10.5 B A Y (15.2) 3.9 26 X X 30 X Y Model No. J11DF-06V-KX J11DF-06V-KY J11DF-08V-KX J11DF-08V-KY J11DF-12V-KX J11DF-12V-KY J11DF-20V-KX J11DF-20V-KY J11DF-22V-KX J11DF-22V-KY J11DF-26V-KX J11DF-26V-KY J11DF-30V-KX J11DF-30V-KY Dimensions (mm) Q’ty/box A B 4.4 8.0 800 4.4 8.0 800 6.6 10.2 500 6.6 10.2 500 11.0 14.6 400 11.0 14.6 400 19.8 23.4 250 19.8 23.4 250 22.0 25.6 250 22.0 25.6 250 26.4 30.0 200 26.4 30.0 200 30.8 34.4 180 30.8 34.4 180 Material and Finish Line No. Glass-filled PBT, UL94V-0, black RoHS2 compliance Tab housing Circuits Keying 6 Y 10 9 8 7 6 5 4 3 X 2 1 Circuit No. X 8 Keying No. X Y 12 X Y Series name 20 X Y 26 X Y B 29.3 B 4.4 9.2 400 4.4 9.2 400 6.6 — 11.4 — 300 — 11.0 — 15.8 — 200 — 19.8 — 24.6 — 150 — 26.4 31.2 120 26.4 31.2 120 J11DFM-06V-KX J11DFM-06V-KY J11DFM-08V-KX — J11DFM-12V-KX — J11DFM-20V-KX — J11DFM-26V-KX J11DFM-26V-KY Q’ty/box A Line No. Glass-filled PBT, UL94V-0, black B RoHS2 compliance A 3.9 12.3 Dimensions (mm) Material and Finish A 2.2 Model No. 6 J1000 SERIES/J1100 Header Top entry type Circuits Plating Gold (0.2μm) 6 10 9 8 7 6 5 4 3 2 1 Circuit No. Tin X Keying No. Series name 8 Gold (0.2μm) Tin B 3.2 Line No. 12 B 3.9 A 2.2 20 A 19.5 (12.3) 1 ±0.1 3.9 ±0.05 2.2 (2.5) 1 ±0.1 (2.5) φ1 ±0.05 ±0.05 X B06B-J11DK-GWXR B06B-J11DK-GWYR B06B-J11DK-TXR B06B-J11DK-TYR B08B-J11DK-GWXR B08B-J11DK-GWYR B08B-J11DK-TXR B08B-J11DK-TYR B12B-J11DK-GWXR B12B-J11DK-GWYR B12B-J11DK-TXR B12B-J11DK-TYR B20B-J11DK-GWXR B20B-J11DK-GWYR B20B-J11DK-TXR B20B-J11DK-TYR B22B-J11DK-GWXR B22B-J11DK-GWYR B26B-J11DK-GWXR B26B-J11DK-GWYR B30B-J11DK-GWXR B30B-J11DK-GWYR Y X Y X Y X Y X Y X Y X Y X Y Gold (0.2μm) X 26 Gold (0.2μm) X 30 Gold (0.2μm) X Y Y Y φ1 ±0.05 Dimensions (mm) Q’ty/ A B C box 4.4 9.2 — 500 4.4 9.2 — 500 6.6 11.4 4.4 400 6.6 11.4 4.4 400 11.0 15.8 8.8 280 11.0 15.8 8.8 280 19.8 24.6 17.6 180 19.8 24.6 17.6 180 22.0 26.8 19.8 160 26.4 31.2 24.2 140 30.8 35.6 28.6 120 Material and Finish 2.2 ±0.05 Post: Copper alloy, gold-plated, tin-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, tin-plated A ±0.05 (2.4) A ±0.05 Model No. 22 2 ±0.05 (12.3) 2.7 ±0.05 2 ±0.05 Gold (0.2μm) Tin Connector outline C ±0.05 (2.4) 3.6 2.7 ±0.05 Connector outline 3.9 ±0.05 Gold (0.2μm) Tin 3.9 12.3 2.7 C Keying (B) (B) PC board layout (Reference) (Other than 6-circuit) (viewed from component side) PC board layout (Reference) (6-circuit) (viewed from component side) RoHS2 compliance Note: 1. Gold-plated product displays (LF) on a label. 2. Contact JST for 0.76 μm gold-plated product. Header Side entry type Circuits Plating Gold (0.2μm) 10 9 8 7 6 5 4 3 2 1 Circuit No. X 6 Keying No. Tin Series name Gold (0.2μm) 8 Tin B Gold (0.2μm) 2.2 12 Tin B Gold (0.2μm) 3.3 3.1 3.9 12.3 13.5 Line No. A 20 Tin (0.6) C 8 2.2 C ±0.05 30 2 ±0.05 Connector outline Model No. X X S06B-J11DK-GWXR S06B-J11DK-GWYR S06B-J11DK-TXR S06B-J11DK-TYR S08B-J11DK-GWXR S08B-J11DK-GWYR S08B-J11DK-TXR S08B-J11DK-TYR S12B-J11DK-GWXR S12B-J11DK-GWYR S12B-J11DK-TXR S12B-J11DK-TYR S20B-J11DK-GWXR S20B-J11DK-GWYR S20B-J11DK-TXR S20B-J11DK-TYR S30B-J11DK-GWXR Y — Y X Y X Y X Y 21.2 A Keying Connector outline 2 ±0.05 Gold (0.2μm) X Y X Y X Y X Y 2.2 ±0.05 A ±0.05 (B) PC board layout (Reference) (Other than 6- & 8-circuit) (viewed from component side) 7 (2.4) (21.2) 1 ±0.1 8 ±0.05 φ1 ±0.05 (0.6) (2.4) 2.2 ±0.05 8 ±0.05 1 ±0.1 (0.6) 2.2 ±0.05 φ1 ±0.05 (21.2) Material and Finish 2.2 ±0.05 A ±0.05 (B) PC board layout (Reference) (6- & 8-circuit) (viewed from component side) Post: Copper alloy, gold-plated, tin-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, tin-plated RoHS2 compliance Note: 1. Gold-plated product displays (LF) on a label. 2. Contact JST for 0.76 μm gold-plated product. Dimensions (mm) Q’ty/ A B C box 4.4 9.2 — 375 4.4 9.2 — 375 6.6 11.4 — 300 6.6 11.4 — 300 11.0 15.8 8.8 225 11.0 15.8 8.8 225 19.8 24.6 17.6 135 19.8 24.6 17.6 135 30.8 35.6 28.6 — — — 90 — J1000 SERIES/J1800 Assembly layout Wire-to-board Type Top entry type Side entry type (7) (23) (8) (23.5) J1800 Single-row type Receptacle housing Keying No. Circuits Circuit No. 8 Keying Model No. Q’ty/box X J18SF-08V-KX Y — 450 — 8 7 6 5 4 3 2 Material and Finish 4.8 5.1 Glass-filled PBT, UL94V-0, black 2.2 RoHS2 compliance 7.5 20.7 (31.5) Header Top entry type Connector outline Model No. Q’ty/box X B08B-J18SK-TXR Y — 245 — 2.2 ±0.05 7.5 ±0.05 2.7 ±0.05 5 6 7 8 Series name 8 Keying Material and Finish (2.7) 2 3 4 Keying No. 20.7 ±0.05 (4.65) Post: Copper alloy, tin-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, tin-plated RoHS2 compliance PC board layout (Reference) (viewed from component side) 30 18.5 1.6 3.2 7.5 2.7 7 2.2 (1.6) 1 ±0.05 2 ±0.05 φ1 (7) Circuit No. Circuits (30) 18.5 ±0.05 20.7 19.5 3.6 Header Side entry type Circuits (30) Circuit No. 2.2 ±0.05 φ1 ±0.05 23 ±0.05 φ2 ±0.05 7.5 ±0.05 5 6 7 8 (19) 2 3 4 Keying No. Series name (4.65) 8 ±0.05 (0.6) 20.7 ±0.05 8 Keying Model No. Q’ty/box X S08B-J18SK-TXR Y — 220 — Material and Finish Post: Copper alloy, tin-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, tin-plated RoHS2 compliance 7.5 19 PC board layout (Reference) (viewed from component side) 23 3.3 3.1 8 Connector outline 6.8 2.2 30 20.7 8 (0.6) 8 JFA CONNECTOR/J1000 SERIES Model number identification Receptacle contact Tab contact S F1 F - 21 T - P 0.6 S F1 M - 21 T - M 0.6 A Form: S…Strip form Form: S…Strip form Series name Series name Kind of terminal: M…Tab contact Kind of terminal: F…Receptacle contact Applicable wire: 002…AWG #28 ∼ AWG #24 01…AWG #24 ∼ AWG #20 21…AWG #22 ∼ AWG #18 Applicable wire: 002…AWG #28 ∼ AWG #24 01…AWG #24 ∼ AWG #20 21…AWG #22 ∼ AWG #18 Surface finish: GC…Nickel-undercoated, selective gold-plated (0.2μm) T…Tin-plated Surface finish: GC…Nickel-undercoated, selective gold-plated (0.2μm) Material: M…Copper alloy T…Tin-plated Material: P…Copper alloy Terminal size Terminal size Sub model number Receptacle housing Tab housing J11 DFM - 06 V - K X J11 DF - 06 V - K X Series name Series name Type of connector: SF…Single-row type DF…Double-row type Type of connector: SFM…Single-row type DFM…Double-row type Circuits: 3, 6, 8, 12, 20, 22, 26, 30 Circuits: 3, 6, 8, 12, 20, 26 Flammability: V…UL94V-0 Flammability: V…UL94V- 0 Color indication: K…Black Color indication: K…Black Keying: X…X-Keying, Y…Y-Keying Keying: X…X-Keying, Y…Y-Keying Header B 06 B - J11 D K - T X R PC board mounting direction: B…Top entry type S…Side entry type Circuits: 3, 6, 8, 12, 20, 22, 26, 30 Product name: Header Series name Rows: S…Single-row, D…Double-row Color indication: K…Black Surface finish: GW…Gold-plated (0.2μm), T…Tin-plated Keying: X…X-Keying, Y…Y-Keying Packaging form: R…Tray 9
SF1F-002T-P0.6 价格&库存
很抱歉,暂时无法提供与“SF1F-002T-P0.6”相匹配的价格&库存,您可以联系我们找货
SF1F-002T-P0.6
    • 1+1.12220
    • 1000+0.67330
    • 6000+0.33660
    库存:18000
