SR5200
SR5200
    SUNMATE(森美特)
    SR5200
SR5200 数据手册
SR5150 - SR5200 SCHOTTKUY BARRIER RECTIFIER DIODES VOLTAGE RANGE: 150 - 200V CURRENT: 5.0 A Features ! Schottky Barrier Chip ! ! ! ! Ideally Suited for Automatic Assembly Low Power Loss, High Efficiency For Use in Low Voltage Application Guard Ring Die Construction ! Plastic Case Material has UL Flammability B A A Classification Rating 94V-O  Mechanical Data ! ! ! ! ! ! C D DO-201AD Case: DO-201AD, Molded Plastic Terminals: Plated Leads Solderable per MIL-STD-202, Method 208 Polarity: Cathode Band Weight: 1.2 grams (approx.) Mounting Position: Any Marking: Type Number Dim Min A 25.40 Max ¾ B 7.20 9.50 C 1.20 1.30 D 4.80 5.30 All Dimensions in mm Maximum Ratings and Electrical Characteristics TA = 25C unless otherwise specified Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Characteristic Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TL(see fig.1) Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 5.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=100 C Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) Operating junction temperature range Storage temperature range Symbol SR5150 150 105 150 VRRM VRMS VDC SR5200 Unit 200 150 200 Volts Volts Volts I(AV) 5.0 Amps IFSM 150.0 Amps 0.85 VF 0.95 0.2 2.0 200 IR CJ RθJA TJ, TSTG 50.0 -50 to +150 -50 to +150 Volts mA pF C/W C C Note: 1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. copper pad areas 2.P.C.B. mounted with 0.2x0.2(5.0x5.0mm) ” 1 of 2 www.sunmate.tw FIG. 1- FORWARD CURRENT DERATING CURVE PEAK FORWARD SURGE CURRENT, AMPERES AVERAGE FORWARD RECTIFIED CURRENT, AMPERES RATINGS AND CHARACTERISTIC CURVES SR5150 THRU SR5200 5.0 4.0 Single Phase Half Wave 60Hz Resistive or inductive Load 3.0 2.0 1.0 0 0 25 50 75 100 125 150 FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 150 120 90 60 30 175 0 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 1 10 AMBIENT TEMPERATURE, C NUMBER OF CYCLES AT 60 Hz FIG. 4-TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, MILLIAMPERES FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 50 INSTANTANEOUS FORWARD CURRENT,AMPERES TJ=25 C 10.0 1 0.1 SR5150 SR5200 100 10 TJ=100 C 1 TJ=75 C 0.1 0.01 TJ=25 C 0.001 0.01 100 0 20 40 60 80 100 PERCENT OF PEAK REVERSE VOLTAGE,% 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 TRANSIENT THERMAL IMPEDANCE, C/W INSTANTANEOUS FORWARD VOLEAGE, VOLTS JUNCTION CAPACITANCE, pF FIG. 5-TYPICAL JUNCTION CAPACITANCE 2000 1000 TJ=25 C 100 FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE 100 10 1 0.1 0.01 0.1 1 10 100 10 0.1 1.0 10 100 REVERSE VOLTAGE,VOLTS t,PULSE DURATION,sec. 2 of 2 www.sunmate.tw
SR5200 价格&库存
很抱歉,暂时无法提供与“SR5200”相匹配的价格&库存,您可以联系我们找货
