SR5200
SR5200
    DY(迪一电子)
    DO201AD
    200V 5A VF=0.92V @ 5A
SR5200 数据手册
SR520 THRU SR5250 5.0 AMP. Schottky Barrier Rectifiers Features •Plastic package has Underwriters Laboratory DO-201AD Flammability Classification 94V-0 utilizing Flame Retardant Epoxy Molding Compound. • Guard ring for overvoltage protection 0.96(24.5) • High current capability, low forward voltage drop MIN. • Low power loss, high efficiency DIA. • High surge capability Mechanical Data · Case: Molded plastic DO-201AD · Terminals: Plated leads solderable per 0.96(24.5) DIA. MIL-STD-202,Method 208 guaranteed MIN. · Polarity: Color band dentes cathode end · Mounting Position: Any Dimensions in inches and (millimeters) · Making: Type Number · Lead Free: For RoHS/Lead Free Version Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified Single phase,half wave,60Hz,resistive or inductive load For capacitive load derate current by 20% Type Number SYMBOL SR SR SR 520 530 540 SR 545 SR SR 550 560 SR SR SR SR SR 580 5100 5150 5200 5250 Unit Maximum Recurrent Peak Reverse Voltage VRRM 20 30 40 45 50 60 80 100 150 200 250 V Maximum RMS Voltage VRMS 14 21 28 31.5 35 42 56 70 105 140 175 V Maximum DC Blocking Voltage VDC 20 30 40 45 50 60 80 100 150 200 250 V Average Rectified Output Current (Note 1) @TL =100℃ Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) I2t Rating for Fusing (t < 8.3ms) Forward Voltage @IF=5.0A Peak Reverse Current @TA=25℃ At Rated DC Blocking Voltage @TA=100℃ IF(AV) 5.0 A IFSM 120 A I 2t 59.76 0.7 A2s V VFM IR Typical Junction Capacitance (Note 2) CJ Typical Thermal Resistance Junction to Ambient(Note 1) RθJA Operating Temperature Range Storage Temperature Range 0.55 0.85 0.92 0.2 0.05 10.0 5.0 500 350 25 mA pF ℃/W TJ -55 to + 150 ℃ TSTG -55 to + 150 ℃ Note: 1. Leads maintained at ambient temperature at a distance of 9.5mm from the case 2. Measured at 1.0 MHz and Applied reverse Voltage of 4.0V D.C version:02 0.95 1of3 www.dyelec.com SR520 THRU SRB5250 FIG.2-TYPICAL FORWARD CHARACTERISTICS FIG. 1 - FORWARD CURRENT DERATING CURVE INSTANTANEOUS FORWARD CURRENT,(A) AVERAGE FORWARD CURRENT (A) 10.0 5.0 4.0 3.0 2.0 1.0 0 25 50 75 100 125 150 175 SR520-SB545 SR550-SR560 5.0 SR580-SR5100 SR5250 1.0 SR5150-SR5200 TA = 25 ℃ 0.1 0.1 LEAD TEMPERATURE( OC) 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 INSTANTANEOUS FORWARD VOLTAGE, (V) MAXIMUM NON-REPETITIVE SURGE CURRENT FIG.4 TYPICAL JUNCTION CAPACITANCE 200 4000 150 CAPACITANCE, (pF) PEAK FORWARD SURGE CURRENT,(A) FIG. 3 100 50 PULSE WIDTH 8.3ms SINGLE HALF-SINE-WAVE (JEDEC METHOD) SR520-SR545 1000 SR550-SR5250 0 1 2 5 10 20 50 100 T J = 25°C f = 1 MHz NUMBER OF CYCLES AT 60Hz 100 0.1 1 10 REVERSE VOLTAGE (V) version:02 2of3 www.dyelec.com 100 SR520 THRU SRB5250 Important Notice and Disclaimer •Reproducing and modifying information of the document is prohibited without permission from DIYI. • DIYI reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design, purchase or use. •DIYI disclaims any and all liability arising out of the application or use of any product including damages incidentally and consequentially occurred. •DIYI does not assume any and all implied warranties, including warranties of fitness for particular purpose, non-infringement and merchantability. Applications shown on the here in document are examples of standard use and • operation. Customers are responsible in comprehending the suitable use in particular applications. DIYI makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. •The products shown here in are not designed and authorized for equipments requiring high level of reliability or relating to human life and for any applications concerning life-saving or life-sustaining, such as medical instruments, transportation equipment, aerospace machinery et cetera. Customers using or selling these products for use in such applications do so at their own ris k andagree to fully indemnify DIYI for any damages resulting from such improper use or sale. •Since DIYI uses lot number as the tracking base, please provide the lot number for tracking when complaining. version:02 3of3 www.dyelec.com
SR5200 价格&库存
很抱歉,暂时无法提供与“SR5200”相匹配的价格&库存,您可以联系我们找货
SR5200
    • 1+0.81140
