0.08 PIN
2.0
0.35
9.0
0.57
14.5
A
0.30
7.6
28°
10°
0.25
6.3
0.43
11.0
0.140
3.56
0.040
1.02
0.030
0.76
CENTER
PIN
SLEEVE
SHUNT
0.26
6.5
0.030
0.76
SLEEVE
SHUNT
0.120
3.05
SLEEVE
CENTER
PIN
0.05 TYP
1.3
SLEEVE
A
0.02
0.5
0.008
0.20
0.10
2.5
0.14
3.4
3 PLACES
0.02
0.5
0.12
3.0
0.10
2.5
0.29
7.5
0.42
10.7
0.120
3.05
JACK MATING FACE
(EDGE OF PC BOARD)
0.19
4.7
RECOMMENDED PC BOARD LAYOUT
(COMPONENT SIDE)
0.120
3.05
SLEEVE
SHUNT
LOCKING GROOVE
0.54
13.8
0.140
3.56
CENTER
PIN
LOCKING SHOULDER
CENTER PIN
SLEEVE SHUNT
SLEEVE
0.120
3.05
SLEEVE
SCHEMATIC
NOTES:
0.24
6.0
REF
1. THIS PRODUCT IS RoHS COMPLIANT.
2. MATERIALS:
CENTER PIN: COPPER ALLOY, NICKEL PLATED
SLEEVE CONTACT: SPRING COPPER ALLOY, SILVER PLATED
PIN TERMINAL AND SHUNT: COPPER ALLOY, SILVER PLATED
HOUSING AND COVER: HIGH TEMPERATURE THERMOPLASTIC, BLACK
3. SPECIFICATIONS:
LIFE: 5000 CYCLES;
INSERTION FORCE: 5LB [2.3 KG] MAX;
WITHDRAWL FORCE: 0.5 LB [0.2 KG] MIN;
CONTACT RESISTANCE: 30 MILLIOHM MAX, 60 MILLIOHM MAX. AFTER TEST;
INSULATION RESISTANCE: 30 MEGAOHM MIN. @ 100VDC;
DIELECTRIC WITHSTANDING VOLTAGE: 250VAC FOR 1 MINUTE;
CURRENT (CARRYING): 5A
OPERATING TEMPERATURE: -30 C TO +65 C
SECTION A-A
1. ALL DIMENSIONS IN INCHES [mm]
- TWO PLACE DECIMALS
0.02 [0.5]
- THREE PLACE DECIMALS
0.005 [0.13]
REV
ECO NUMBER
08-30-18
DATE
REVISIONS
PC
BY
SIZE
SolidWorks CAD File
MULT
NAME
TEMPER
BY
SRC
SPEC No.
SCALE
4:1
CHKD
TJK
8/17/18
APVD
TJK
8/17/18
LOCKING POWER JACK,
PC TERMINALS, 0.08 [2.0 mm], RoHS
B
LBS/M
MATERIAL
SPEC No.
FIRST USED ON
10-12-17
DO NOT SCALE DRAWING
WIDTH
FINISH
TJK
APVD
CUSTOMER DRAWING
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
DATE DRAWN
28064
0.423
10.74
0.541
13.74
ALTERNATE PC BOARD LAYOUT
(COMPONENT SIDE)
JACK MATING FACE
(EDGE OF PC BOARD)
UNLESS OTHERWISE SPECIFIED
0.295
7.49
0.189
4.80
0.24
6.0
REF
STAR SYMBOL DENOTES CRITICAL DIMENSION
A
0.423
10.74
0.295
7.49
0.189
4.80
0.541
13.74
SHEET
PART No.
1
OF
1
RAPC722BKZ
REV
A
很抱歉,暂时无法提供与“RAPC722BKZ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+6.291631+0.76157
