RAPC722BK
RAPC722BK
    SWITCHCRAFT
    CONN PWR JACK 2X5.5MM SOLDER
RAPC722BK 数据手册
0.076 PIN 1.9 0.05 1.3 0.35 9.0 0.57 14.5 A 0.140 3.56 0.040 1.02 CENTER PIN 10° 0.25 6.3 0.030 0.76 0.43 11.0 0.030 0.76 SLEEVE SHUNT 0.120 3.05 SLEEVE SLEEVE SHUNT 0.26 6.5 0.14 TYP 3.4 CENTER PIN 0.02 0.5 SLEEVE A 0.02 0.5 0.10 2.5 0.42 10.7 0.120 3.05 SLEEVE SHUNT LOCKING GROOVE A 0.54 13.8 0.140 3.56 CENTER PIN LOCKING SHOULDER CENTER PIN SLEEVE SHUNT SLEEVE 0.120 3.05 SLEEVE SCHEMATIC 1° 0.295 7.49 0.189 4.80 0.541 13.74 0.423 10.74 ALTERNATE PC BOARD LAYOUT (COMPONENT SIDE) NOTES: 1. THIS PRODUCT IS RoHS COMPLIANT. 0.20 5.1 DETAIL A SCALE 14 : 1 2. MATERIALS: CENTER PIN: COPPER ALLOY, NICKEL PLATED SLEEVE CONTACT: SPRING COPPER ALLOY, SILVER PLATED PIN TERMINAL AND SHUNT: COPPER ALLOY, SILVER PLATED HOUSING AND COVER: HIGH TEMPERATURE THERMOPLASTIC, BLACK 3. SPECIFICATIONS: LIFE: 5000 CYCLES; INSERTION FORCE: 5LB [2.3 KG] MAX; WITHDRAWL FORCE: 0.5 LB [0.2 KG] MIN; CONTACT RESISTANCE: 30 MILLIOHM MAX, 60 MILLIOHM MAX. AFTER TEST; INSULATION RESISTANCE: 30 MEGAOHM MIN. @ 100VDC; DIELECTRIC WITHSTANDING VOLTAGE: 250VAC FOR 1 MINUTE; CURRENT (CARRYING): 5A OPERATING TEMPERATURE: -30 C TO +65 C 0.189 4.80 RECOMMENDED PC BOARD LAYOUT (COMPONENT SIDE) 0.12 3.0 0.19 4.7 0.10 2.5 0.29 7.5 0.295 7.49 0.423 10.74 JACK MATING FACE (EDGE OF PC BOARD) 0.02 0.5 0.008 0.2 0.120 3.05 0.541 13.74 0.27 6.9 CUSTOMER DRAWING SECTION A-A THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. STAR SYMBOL DENOTES CRITICAL DIMENSION UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES SIZE WIDTH FINISH - TWO PLACE DECIMALS 0.02 - THREE PLACE DECIMALS 0.005 REV ECO 25775 ECO NUMBER 1/22/07 DATE REVISIONS BS SPEC No. FIRST USED ON BY 1/17/07 * TJK APVD DO NOT SCALE DRAWING SolidWorks CAD File NAME B LBS/M TEMPER MATERIAL DATE DRAWN A MULT BY BS SPEC No. SCALE 4:1 CHKD TJK 08/20/08 APVD TJK 08/20/08 LOCKING POWER JACK, PC, 0.08 [2.0mm], RoHS SHEET PART No. 1 OF 1 RAPC722BK REV A
RAPC722BK 价格&库存
很抱歉,暂时无法提供与“RAPC722BK”相匹配的价格&库存,您可以联系我们找货
