SP1471SRL
3A Wide Input 500kHz Synchronous Step-Down Converter
FEATURES
GENERAL DESCRIPTION
The SP1471 is a fully integrated, high efficiency
3A synchronous rectified step-down converter.
The SP1471 operates at high efficiency over a
wide output current load range.
This device offers two operation modes, PWM
control and PFM Mode switching control, which
allows a high efficiency over the wider range of
the load.
The SP1471requires a minimum number of
readily available standard external components
and is available in an 6-pin SOT23 ROHS
compliant package.
4.5V to 16V Wide Input Voltage Range
Max 3A Output Current,Up to 96% Efficiency
Excellent Line and Load Transient Response
Over Current Protection with Hiccup-Mode
Inrush Current Limit and Soft Start circuit
0.8V Reference Voltage
-40°C to +85°C Temperature Range
Available in SOT23-6 Package
TYPICAL APPLICATION CIRCUIT
C2
1uF
L
VIN
BS
VIN
SW
SP1471
CIN
22μF
EN
R1
C1
100k
22pF
1%
opt.
FB
R2
GND
19k
1%
1
V01
VOUT
6.8μH
www.sourcechips.com
COUT
22μF*3
SP1471SRL
FUNCTIONAL BLOCK DIAGRAM
VIN
VCC
REGULATOR
RSEN
VCC
CURRENT SENSE
AMPLIFIER
BOOST
REGULATOR
BS
OSCILLATOR
HS
DRIVER
EN
COMPARATOR
REFERENCE
CURRENT LIMIT
COMPARATOR
1pF
1M
56pF
VCC
LOGIC CONTROL
400k
FB
PIN CONFIGURATION
Order Part Number
Package
SP1471SRL
SOT23-6
TOP VIEW
6
BS
SW
2
5
EN
VIN 3
4
FB
6-LEAD PLASTIC SOT-23
TJMAX = 150°C, θJA = 170°C/ W, θJC =
130°C/W
V01
LS
DRIVER
GND
ERROR AMPLIFIER
GND 1
SW
ON TIME CONTROL
2
www.sourcechips.com
SP1471SRL
PIN DESCRIPTIONS
Pin Name
Pin Number
Description
GND
1
Analog ground pin.
SW
2
Switching Pin.
VIN
3
Power supply Pin
FB
4
Adjustable version feedback input. Connect FB to the center point of the
external resistor divider
EN
5
Drive this pin to a logic-high to enable the IC. Drive to a logic-low to disable
the IC and enter micro-power shutdown mode. For automatic start-up,
connect EN to VIN using a 200kΩ resistor.
BS
6
Bootstrap. A capacitor connected between SW and BS pins is required to
form a floating supply across the high-side switch driver.
ABSOLUTE MAXIMUM RATINGS
Input Supply Voltage…….…….…-0.3V to 17V
V01
EN Voltages…………………………-0.3V to 6V
Thermal Resistance θJA……….…..….....….170°C /W
Junction Temperature(Note2)…….…............150°C
FB Voltages…………………………-0.3V to 6V
Operating Temperature Range….….-40°C to 85°C
SW Voltage………………...-0.3V to (VIN+0.5V)
Lead Temperature(Soldering,10s)……...…...300°C
BS Voltage…………..(VSW-0.3V) to (VSW+5V)
Storage Temperature Range……....-65°C to 150°C
Power Dissipation…………………...……...0.6W
ESD HBM(Human Body Mode)…………..…...2kV
Thermal Resistance θJC…………...….130°C /W
ESD MM(Machine Mode)……………......…….200V
3
www.sourcechips.com
SP1471SRL
ELECTRICAL CHARACTERISTICS (VIN=12V, VOUT=5V, TA = 25°C)
PARAMETER
CONDITIONS
MIN
Input Voltage Range
4.5
Supply Current in
Operation
VEN=3.0V, VFB=2V
Supply Current in
Shutdown
VEN =0 or EN = GND
Regulated Feedback
Voltage
TA = 25°C, 4.5V≤ VIN ≤16V
0.6
MAX
UNIT
16
V
0.8
mA
1
780
800
µA
820
mV
High-Side Switch
On-Resistance
90
mΩ
Low-Side Switch
On-Resistance
70
mΩ
High-Side Switch
Leakage Current
VEN=0V, VSW=0V
1
µA
Low-Side Switch
Leakage Current
VEN=0V, VSW=12V
1
µA
Upper Switch Current
Limit
Minimum Duty Cycle
Maximum Duty Cycle
400
VFB=0.8V
Minimum On-Time
Soft-start Time
A
4.5
Oscillation Frequency
Tss
Thermal Shutdown
4
V01
TYP
www.sourcechips.com
500
92
580
KHz
60
nS
1
mS
180
SP1471SRL
TYPICAL PERFORMANCE CHARACTERISTICS
100
100
95
95
90
90
85
85
80
80
75
75
70
65
70
60
65
60
0.01
55
0.1
1
50
0.01
10
0.1
1
10
100
100
95
90
90
85
80
80
75
70
70
60
65
60
50
55
40
0.01
0.1
1
50
0.01
10
5
V01
www.sourcechips.com
0.1
1
10
SP1471SRL
OPERATION
Internal Regulator
The SP1471 is a current mode step down
DC/DC converter that provides excellent
transient response with no extra external
compensation components. This device
contains an internal, low resistance, high
voltage power MOSFET, and operates at a
high 500K operating frequency to ensure a
compact, high efficiency design with
excellent AC and DC performance.
Over-Current-Protection and Hiccup The
The SP1471 has cycle-by-cycle over current
limit when the inductor current peak value
exceeds the set current limit threshold.
Meanwhile, output voltage starts to drop
until FB is below the Under-Voltage (UV)
threshold, typically 30% below the
reference. Once a UV is triggered, the
The SP1471 enters hiccup mode to periodically
restart the part. This protection mode is
especially useful when the output is deadshort to ground. The average short circuit
current is greatly reduced to alleviate the
thermal issue and to protect the regulator.
The SP1471 exits the hiccup mode once
the over current condition is removed.
Error Amplifier
The error amplifier compares the FB pin
voltage with the internal FB reference
(VFB) and outputs a current proportional to
the difference between the two. This
output current is then used to charge or
discharge the internal compensation
network to form the COMP voltage, which
is used to control the power MOSFET
current. The optimized internal
compensation network minimizes the
external component counts and simplifies
the control loop design.
Startup and Shutdown
If both VIN and EN are higher than their
appropriate thresholds, the chip starts. The
reference block starts first, generating stable
reference voltage and currents, and then the
internal regulator is enabled. The regulator
provides stable supply for the remaining
circuitries. Three events can shut down the
chip: EN low, VIN low and thermal
shutdown. In the shutdown procedure, the
signaling path is first blocked to avoid any
fault triggering. The COMP voltage and the
internal supply rail are then pulled down.
The floating driver is not subject to this
shutdown command.
Internal Soft-Start
The soft-start is implemented to prevent
the converter output voltage from
overshooting during startup. When the chip
starts, the internal circuitry generates a
soft-start voltage (SS) ramping up from 0V
to 0.8V. When it is lower than the internal
reference (REF), SS overrides REF so the
error amplifier uses SS as the reference.
When SS is higher than REF, REF regains
control. The SS time is internally fixed to
1ms.
6
V01
www.sourcechips.com
SP1471SRL
PACKAGE OUTLINE
SOT23-6 PACKAGE OUTLINE AND DIMENSIONS
D
θ
0.2
SYMBOL
E
E1
c
e
A
A1
A2
e1
DIMENSION IN
INCHES
MIN
MAX
A
1.450
0.057
A1
0.000
0.150
0.000
0.006
A2
0.900
1.300
0.035
0.051
b
0.300
0.500
0.012
0.020
c
0.080
0.220
0.003
0.009
D
2.900 BSC
0.114 BSC
E
1.600 BSC
0.063 BSC
E1
2.800 BSC
0.110 BSC
e
0.950 BSC
0.037 BSC
e1
1.900 BSC
0.075 BSC
L
0.300
θ
0°°
7
V01
DIMENSION IN
MILLIMETERS
MIN
L
b
www.sourcechips.com
0.600
0.012
0.024
8°
很抱歉,暂时无法提供与“SP1471SRL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.11500
- 50+0.89727
- 150+0.80396
- 500+0.68753
