SFHG56JA002
SFHG56JA002
    WISOL(威盛)
    SFHG56JA002
SFHG56JA002 数据手册
SPECIFICATION Surface Acoustic Wave Filter USER USER PART No. SEMCO PART No. SFHG56JA002 DOC. No. SMS-51-L-SFT FX-36 DATE July 26, 2013 REVISION 000 WISOL Kim,Young-Hun Jeon. Hyeon Cheol Hong, Seong-Su ISSUED APPROVED APPROVED BY BY (R&D) BY (QC) User ISSUED CHECKED APPROVED BY BY BY WISOL CO., LTD. 373-7, GAJANG-DONG, OSAN-SI, GYUNGGI-DO, KOREA, 447-210 http://www.wisol.co.kr Surface Acoustic Wave Filter Band 7 Rx 2655MHz SFHG56JA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 ▶ A TABLE OF CONTENTS 1. REVISION HISTORY ............................................................................................................................. 3 2. DEFINITION ........................................................................................................................................... 4 3. PRECAUTIONS...................................................................................................................................... 4 4. OUTLINE DRAWING & DIMENSIONS .................................................................................................. 5 5. MARKING ............................................................................................................................................... 6 6. PERFORMANCE.................................................................................................................................... 7 6-1. MAXIMUM RATINGS ................................................................................................................... 7 6-2. ELECTRICAL CHARACTERISTICS ............................................................................................ 8 7. RELIABILITY ......................................................................................................................................... 11 7-1. ENGINEERING SAMPLE FLOW CHART .................................................................................. 11 7-2. TEST ITEM & CONDITION ........................................................................................................ 12 8. REFLOW CONDITION ......................................................................................................................... 13 9. RECOMMENDED PCB DIMENSIONS ................................................................................................ 13 11. PACKING ........................................................................................................................................... 15 11-1. DIMENSIONS .......................................................................................................................... 15 11-2. REELING QUANTITY .............................................................................................................. 16 11-3. TAPING STRUCTURE ............................................................................................................. 16 11-4. INNER BOX(Reel Packing) STRUCTURE .............................................................................. 17 11-5. OUTER BOX STRUCTURE ..................................................................................................... 18 12. TAPE SPECIFICATIONS ................................................................................................................... 19 13. RoHS DATA ....................................................................................................................................... 20 SMS-51-L-SFT FX-36 Page 2/21 July 26, 2013 Surface Acoustic Wave Filter Band 7 Rx SFHG56JA002 3 2655MHz 1.1×0.9×0.5mm 5pin lay-out Version : 000 1. REVISION HISTORY 000 July. 26, 2013 All Page SMS-51-L-SFT FX-36 Make specification Page 3/21 July 26, 2013 Surface Acoustic Wave Filter Band 7 Rx SFHG56JA002 3 2655MHz 1.1×0.9×0.5mm 5pin lay-out Version : 000 2. DEFINITION 2-1. PART No. S F H G 56 J A 0 0 2 ① ② ③ ④ No. ⑤ ⑥ EXPLANATION ① SAW Filter ② Design Type ③ Center Frequency : 2655MHz (2620MHz ~ 2690MHz) ④ Input:50ohm,Output:100ohm ⑤ Package size: 1.1×0.9mm² ⑥ Design Revision (02 : Molding Type) 2-2. APPLICATION : Band-Pass Filter for LTE Band7 Rx 3. PRECAUTIONS 3-1. This device should not be used in any type of fluid such as water, oil, organic solvent, etc. 3-2. This is a hermetic device. MSL(Moisture Sensitive Level) is the '2a' level. 3-3. Ultrasonic cleaning shall be avoided. 3-4. Isopropyl Alcohol and Ethyl Alcohol can be used for cleaning. Contact us before using other cleaning solvents than above 3-5. This is an electrostatic sensitive device. Please avoid static voltage during operation and storage. 3-6. Sudden change of temperature shall be avoided, deterioration of the characteristics can occur. 3-7. If any malfunction due to designing or manufacturing which is out of specification occurs within one year after the products have been delivered, the maker should exchange the defective products. SMS-51-L-SFT FX-36 Page 4/21 July 26, 2013 Surface Acoustic Wave Filter Band 7 Rx 2655MHz SFHG56JA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 4. OUTLINE DRAWING & DIMENSIONS [Unit: mm] wFX O X SMS-51-L-SFT FX-36 Page 5/21 No. Function 2, 5 Ground 1 Unbalanced Input 3,4 Balanced Output July 26, 2013 Surface Acoustic Wave Filter Band 7 Rx SFHG56JA002 3 2655MHz 1.1×0.9×0.5mm 5pin lay-out Version : 000 5. MARKING wFX O X 5-1. w F X X st nd - The 1 2 character 'wF' indicates the model name of SAW Filter SFHG56JA002. rd - The 3 character 'X' indicates the year and the month of manufacture. Year Month 1 2 3 4 5 6 7 8 9 10 11 12 2013 P Q R S T U V W X Y Z a 2014 1 2 3 4 5 6 7 8 9 A B C 2015 D E F G H I J K L M N O 2016 P Q R S T U V W X Y Z a ※ This rotates by the 3 years. - The th 4 character 'X' indicates Lot No. 5-2. ○ - This symbol indicates input pin 1. - This indicates the producing center ○ : China, 5-3. Marking : Laser Marking SMS-51-L-SFT FX-36 Page 6/21 July 26, 2013 Surface Acoustic Wave Filter Band 7 Rx 2655MHz SFHG56JA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 6. PERFORMANCE 6-1. MAXIMUM RATINGS CHARACTERISTICS RATINGS UNITS DC Permissive Voltage 5 V Maximum Input Power 15 dBm Operating Temperature Range -30 ~ +85 ℃ Storage Temperature Range -40 ~ +85 ℃ SMS-51-L-SFT FX-36 Page 7/21 July 26, 2013 Surface Acoustic Wave Filter Band 7 Rx 2655MHz SFHG56JA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 6-2. ELECTRICAL CHARACTERISTICS 6-2-1. TABLE Ta = -30 ~ +85℃ SPECIFICATION FREQUENCY RANGE [MHz] UNIT Insertion Loss 2620 ~ 2690 Inband Ripple Item Min. Typ. (25℃) Max. dB - 2.4 3.3 2620 ~ 2690 dB - 1.0 1.7 Input VSWR 2620 ~ 2690 - - 1.5 2.3 Output VSWR 2620 ~ 2690 - - 1.5 2.3 Amplitude Imbalance 2620 ~ 2690 dB -2.3 - +2.3 Phase Imbalance 2620 ~ 2690 degree -20 - +20 2450 ~ 2485 dB 40 50 - 2500 ~ 2570 dB 35 50 - 2750 ~ 2850 dB 22 28 Absolute Attenuation Input: Unbalanced 50 ohm Output: Balanced 100 ohm // 18nH Termination Impedance SMS-51-L-SFT FX-36 Page 8/21 July 26, 2013 Surface Acoustic Wave Filter Band 7 Rx 2655MHz SFHG56JA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 6-2-2. TEST FIXTURE 50Ω wFX O X 18nH 100Ω [X—Ray Top View] SMS-51-L-SFT FX-36 Page 9/21 July 26, 2013 Surface Acoustic Wave Filter Band 7 Rx 2655MHz SFHG56JA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 6-2-3. GRAPH SMS-51-L-SFT FX-36 Page 10/21 July 26, 2013 Surface Acoustic Wave Filter Band 7 Rx 2655MHz SFHG56JA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 7. RELIABILITY 7-1. ENGINEERING SAMPLE FLOW CHART Initial Characteristics Electrical Parametric Data@25℃ Preconditioning (JESD22-A113F) Temp. Drift (n=5) Thermal Shock (n=23) Board Adhesion (n=11) Low Temp. Storage (n=23) PCT (n=23) Bending Test (n=11) High Temp. Storage (n=23) Vib ration (n=23) ESD Test (n=11) Humidity Test (n=23) Drop (n=23) ESD Limit Test (n=11) Final Electrical Data (n=74) Final Electrical Data (n=92) Final Electrical Data (n=44) SMS-51-L-SFT FX-36 Page 11/21 July 26, 2013 Surface Acoustic Wave Filter Band 7 Rx 2655MHz SFHG56JA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 7-2. TEST ITEM & CONDITION CATEGORY TEST ITEM Preconditioning Environment Test +125℃ 24hr Baking → +60℃ 60%RH 120hr → Reflow Test(3times) JESD22A113F -30℃ → +25℃→ +85℃ High Temp. Storage +85℃ 240hr JESD22-A103C Low Temp. Storage -40℃ 240hr JESD22-A119 description High Temp. High Humidity Storage +85℃ 85%RH 240hr JESD22-A106B Thermal Shock -40℃/30min ⇔ +85℃/30min , 100cycle JESD22-A106A +121℃ 100%RH 96hr JESD22-A102C Vibration Test (Random) 20 ㎐~2000 ㎐,0.053G²/Hz or 8g's RMS,15min/plane IEC 68-2-36 Fdb Drop Test 152 ㎝ 12times Steel floor JIG(110g~150g) IEC 1178-1.4.8.9 0.5 ㎜/sec 1point push IEC 68-2-21 Ue3 0.5 ㎜/sec 3times -PCB : FR4 , PCB SIZE : 100*40 ㎜ IEC 68-2-21 Ue3 Solder Heat Resistance ±250V,C=100pF,R=1.5 ㏀,1times IEC 68-2-21 Ue3 static marginal test C=100pF,R=1.5 ㏀,1times(demand of customer) JESD22-A114F Board Adhesion Bending Test Physical Test REMARK Temp. Drift High Temp. Operating Mechanical Test TEST CONDITION SMS-51-L-SFT FX-36 Page 12/21 July 26, 2013 Surface Acoustic Wave Filter Band 7 Rx 2655MHz SFHG56JA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 8. REFLOW CONDITION 9. RECOMMENDED PCB DIMENSIONS [unit:mm] SMS-51-L-SFT FX-36 Page 13/21 July 26, 2013 Surface Acoustic Wave Filter Band 7 Rx 2655MHz SFHG56JA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 10. CAUTION Moisture Sensitivity Device Caution (MSL LEVEL=2a) 1. Calculated shelf life in sealed bag : 12 month at 〈40℃ and 〈90% relative Humidity(RH) 2. Peak package body temperature : 260℃ 3. After bag is opened, devices that will be subjected to reflow solder or other high temperature process must be (a) Mounted within : 672 hours of factory conditions ≤30℃/60% RH, or (b) Stored per J-STD-033 4. Device require bake, before mounting, if : (a) Humidity Indicator Card reads 〉60% when read at 23±5℃ (b) 3(a) or 3(b) are not met 5. If baking is required, refer to IPC/JEDEC J-STD-033 for bake procedure Note : Level and body temperature defined by IPC/JEDEC J-STD-020 Aluminum Pack (310mmΧ370mm) HIC(Humidity Indication Card) 10 to 60% RH SMS-51-L-SFT FX-36 Page 14/21 July 26, 2013 Surface Acoustic Wave Filter Band 7 Rx SFHG56JA002 3 2655MHz 1.1×0.9×0.5mm 5pin lay-out Version : 000 11. PACKING 11-1. DIMENSIONS - Carrier Tape [Unit: mm] A B D0 D1 E F P0 P1 P2 t1 t2 W 1.10 +0.05 -0.05 1.35 +0.05 -0.05 Ø 1.50 +0.10 -0.00 Ø 0.50 +0.05 -0.05 1.75 +0.10 -0.10 3.50 +0.05 -0.05 4.00 +0.10 -0.10 4.00 +0.10 -0.10 2.00 +0.05 -0.05 0.25 +0.02 -0.02 0.70 +0.05 -0.05 8.00 +0.30 -0.10 - Reel [Unit: mm] A B C D E F G H t1 t2 W Ø 258.0 +1.0 -0.5 Ø 81.0 +1.0 -1.0 Ø 13.0 +0.5 -0.5 50.0 +0.8 -0.8 2.2 +0.3 -0.3 7.0 +0.5 -0.5 30.0 +0.8 -0.8 35.0 +1.0 -1.0 1.8 +0.5 -0.5 1.5 +0.5 -0.5 9.0 +1.0 -0.5 - The product shall be packed properly not to damaged during transportation and storage. SMS-51-L-SFT FX-36 Page 15/21 July 26, 2013 Surface Acoustic Wave Filter Band 7 Rx 2655MHz SFHG56JA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 11-2. REELING QUANTITY 10 inch reel : 10,000 pcs/reel 11-3. TAPING STRUCTURE 11-3-1. The tape shall be wound around the reel in direction shown below. w F X O X w F X O X 11-3-2. BAR CODE LABEL SMS-51-L-SFT FX-36 ① MODEL NAME BARCODE ② SFH836AQ101 Model Name ③ RLYC12563 Reel number ④ 8000 / qAFYU Quantity / Marking Page 16/21 July 26, 2013 Surface Acoustic Wave Filter Band 7 Rx SFHG56JA002 3 2655MHz 1.1×0.9×0.5mm 5pin lay-out Version : 000 1-3-3. Leader part and vacant position specifications. 11-4. INNER BOX(Reel Packing) STRUCTURE Material: Polycarbonate Material: Polyethylene + Aluminium Size: 310×370mm Material: Size: 2 Paper (D)260×(W)37×(H)265mm SMS-51-L-SFT FX-36 3 Page 17/21 July 26, 2013 . . Surface Acoustic Wave Filter Band 7 Rx SFHG56JA002 3 2655MHz 1.1×0.9×0.5mm 5pin lay-out Version : 000 11-5. OUTER BOX STRUCTURE Material : Paper TYPE A SIZE(mm) a b c Inner Box # 270 240 275 6 boxes SIDE ① SIDE ② - SIDE is the same as front side. SMS-51-L-SFT FX-36 Page 18/21 July 26, 2013 Surface Acoustic Wave Filter Band 7 Rx 2655MHz SFHG56JA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 12. TAPE SPECIFICATIONS 12-1. Tensile Strength of Carrier Tape: 4.4N/mm width 12-2. Top Cover Tape Adhesion (See the below figure) - pull of angle: 0~15 degree - speed: 300mm/min. - force: 20~70g SMS-51-L-SFT FX-36 Page 19/21 July 26, 2013 Surface Acoustic Wave Filter Band 7 Rx 2655MHz SFHG56JA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 13. RoHS DATA SMS-51-L-SFT FX-36 Page 20/21 July 26, 2013 Surface Acoustic Wave Filter Band 7 Rx 2655MHz SMS-51-L-SFT FX-36 SFHG56JA002 3 1.1×0.9×0.5mm 5pin lay-out Page 21/21 Version : 000 July 26, 2013
SFHG56JA002 价格&库存
很抱歉,暂时无法提供与“SFHG56JA002”相匹配的价格&库存,您可以联系我们找货
