APPLICABLE STANDARD
OPERATING
TEMPERATURE RANGE
OPERATING
HUMIDITY RANGE
May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents.
RATING
STORAGE
TEMPERATURE RANGE
STORAGE
HUMIDITY RANGE
APPLICABLE
2
CONTACT
-35 C TO +85C (NOTE1)
20%
TO 80% (NOTE2)
50
VOLTAGE
V
-10 C TO +60C (NOTE3)
40%
70%
(NOTE3)
DF57-*S-1.2C
DF57H-*S-1.2C
AC/DC
TO
APPLICABLE
CABLE
INSULATION
DIAMETER
AWG32 TO AWG 34
φ0.32~0.63 mm
SPECIFICATIONS
ITEM
TEST METHOD
REQUIREMENTS
QT
AT
X
X
X
X
X
X
X
X
X
X
X
X
CONSTRUCTION
GENERAL EXAMINATION VISUALLY AND BY MEASURING INSTRUMENT.
MARKING
ACCORDING TO DRAWING.
CONFIRMED VISUALLY.
ELECTRIC CHARACTERISTICS
CONTACT RESISTANCE 20 mV MAX,
1 mA(DC OR
1000 Hz).
10 mMAX.
MECHANICAL CHARACTERISTICS
CONTACT INSERTION
AND EXTRACTION
FORCES
MECHANICAL
OPERATION
VIBRATION
SHOCK
INSERTION FORCE
EXTRACTION FORCE
T=0.2±0.002 mm BY STEEL GAUGE.
5 N MAX.
0.1 N MIN.
① CONTACT RESISTANCE: 20 mΩ MAX.
② NO DAMAGE, CRACK OR LOOSENESS
OF PARTS.
FREQUENCY 10 TO 55 Hz, SINGLE AMPLITUDE
① NO ELECTRICAL DISCONTINUITY OF
0.75 mm, AT 10 CYCLES FOR 3 DIRECTION.
1μs.
2
490 m/s DURATION OF PULSE 11 ms AT 3 TIMES ② NO DAMAGE, CRACK OR LOOSENESS
OF PARTS.
FOR 3 DIRECTIONS.
30 TIMES INSERTION AND EXTRACTION.
① #AWG32
② #AWG34
CRIMP TENSILE
STRENGTH
5 N MIN.
3 N MIN.
ENVIRONMENTAL CHARACTERISTICS
DAMP HEAT(STEADY
STATE)
RAPID CHANGE OF
TEMPERATURE
EXPOSED AT 40 ± 2℃ , 90 TO 95 %, 96 h.
(AFTER LEAVING THE ROOM TEMPERATURE
FOR 1~2h.)
TEMPERATURE -55℃→ +85℃
TIME
30min→ 30min
UNDER 5 CYCLES.
FOR 1~2h.)
OF PARTS.
REMARKS
NOTE 1:INCLUDING THE TEMPERATURE RISE BY CURRENT
NOTE 3:NON-CONDENSING.
NOTE 2:APPLY TO THE CONDITION OF LONG TERM STORAGE FOR UNUSED PRODUCTS BEFORE PCB ON BOARD, AFTER PCB BOARD,
OPERATING TEMPERATURE AND HUMIDITY RANGE IS APPLIED FOR INTERIM STORAGE DURING TRANSPORTATION.
2
COUNT
DESCRIPTION OF REVISIONS
DESIGNED
CHECKED
DATE
1
DIS-H-00000127
MI.SAKIMURA
KI.AKIYAMA
15.02.16
APPROVED
Unless otherwise specified, refer to IEC 60512
Note
QT:Qualification Test
FORM HD0011-2-1
AT:Assurance Test X:Applicable Test
PART NO.
CODE NO.
10.12.02
CHECKED
HK.UMEHARA
10.12.02
DESIGNED
TS.KUMAZAWA
10.12.02
DRAWN
TS.KUMAZAWA
10.12.02
DRAWING NO.
SPECIFICATION SHEET
KI.AKIYAMA
ELC4-335549-00
DF57-3234SCF
CL666-0016-1-00
2
1/1
很抱歉,暂时无法提供与“DF57-3234SCF”相匹配的价格&库存,您可以联系我们找货
