KIA
FAST RECOVERY DIODE
10A,600V
10TB60
SEMICONDUCTORS
1.Features
This series are state−of−the−art devices designed for use in switching power supplies,
inverters and as free wheeling diodes.
2. Features
High efficiency, low VF
High current capability
High reliability
High surge current capability
Low power loss.
For use in low voltage, high frequency inventor, free wheeling, and polarity protection application
3. Mechanical Characteristics
Case: TO-220 Molded plastic
Epoxy: UL 94V-0 rate flame retardant
Terminals: Pure tin plated, lead free. solderable per MIL-STD-202, Method 208 guaranteed
Polarity: As marked
High temperature soldering guaranteed: 260oC/10 seconds .16”,(4.06mm) from case.
Weight: 2.24 grams
4. Pin configuration
1 of 2
Pin
Function
1
Cathode
3
Anode
Rev 1.1 JAN 2014
KIA
FAST RECOVERY DIODE
10A,600V
10TB60
SEMICONDUCTORS
5. Maximum ratings
Parameter
Symbol
Maximum recurrent peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current .
TC = 100ºC
Peak forward surge current, 8.3 ms single
half sine-wave superimposed on rated
load (JEDEC method )
(TJ=25°C,unless otherwise notes)
Rating
Units
VRRM
VRMS
VDC
600
620
600
V
V
V
I(AV)
10.0
A
IFSM
125
A
Maximum instantaneous forward voltage
@ 10A
VF
1.8
V
Maximum DC reverse current
@ TA=25ºC at rated DC blocking voltage
@ TA=100ºC
IR
10.0
400
uA
uA
Maximum reverse recovery time 1)
Trr
45
nS
Cj
50
pF
RθJC
TJ
TSTG
3.5
-65 to +150
-65 to +150
ºC/W
ºC
ºC
Typical junction capacitance
2)
3)
Typical thermal resistance
Operating temperature range
Storage temperature range
Notes: 1. Reverse recovery test conditions: IF=0.5A, IR=1.0A, IRR=0.25A
2. Measured at 1 MHz and applied reverse voltage of 4.0 V D.C.
3. Mounted on heatsink size of 2” x 3” x 0.25” Al-plate.
2 of 2
Rev 1.1 JAN 2014
很抱歉,暂时无法提供与“KIA10TB60BP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.40862
- 10+1.97770
- 30+1.79302
