ESP32S2MINI1 &
ESP32S2MINI1U
Datasheet
2.4 GHz WiFi (802.11 b/g/n) module
Built around ESP32S2 series of SoC, Xtensa® singlecore 32bit LX7 microprocessor
4 MB flash and optional 2 MB PSRAM in chip package
37 GPIOs, rich set of peripherals
Onboard PCB antenna or external antenna connector
Version 1.0
Espressif Systems
Copyright © 2021
www.espressif.com
About This Document
This document provides the specifications for ESP32-S2-MINI-1 and ESP32-S2-MINI-1U modules.
Document Updates
Please always refer to the latest version on https://www.espressif.com/en/support/download/documents.
Revision History
For revision history of this document, please refer to the last page.
Documentation Change Notification
Espressif provides email notifications to keep customers updated on changes to technical documentation.
Please subscribe at www.espressif.com/en/subscribe.
Certification
Download certificates for Espressif products from www.espressif.com/en/certificates.
1 Module Overview
1 Module Overview
1.1 Features
(compatible with ISO 11898-1), USB OTG 1.1,
CPU and OnChip Memory
ADC, DAC, touch sensor, temperature sensor
• ESP32-S2FH4 or ESP32-S2FN4R2 chip
embedded, Xtensa® single-core 32-bit LX7
microprocessor, up to 240 MHz
Integrated Components on Module
• 40 MHz crystal oscillator
• 128 KB ROM
• 320 KB SRAM
Antenna Options
• 16 KB SRAM in RTC
• On-board PCB antenna (ESP32-S2-MINI-1)
• 4 MB embedded flash
• External antenna via a connector
• 2 MB embedded PSRAM (ESP32-S2FN4R2 only)
(ESP32-S2-MINI-1U)
WiFi
Operating Conditions
• 802.11 b/g/n
• Operating voltage/Power supply: 3.0 ~ 3.6 V
• Bit rate: 802.11n up to 150 Mbps
• Operating ambient temperature: –40 ~ 85 °C
• A-MPDU and A-MSDU aggregation
• 0.4 µs guard interval support
Certification
• Green certification: RoHS/REACH
• Center frequency range of operating channel:
2412 ~ 2484 MHz
• RF certification: FCC/CE-RED/SRRC/IC
Peripherals
Test
• GPIO, SPI, LCD, UART, I2C, I2S, Camera
interface, IR, pulse counter, LED PWM, TWAI
• HTOL/HTSL/uHAST/TCT/ESD
1.2 Description
ESP32-S2-MINI-1 and ESP32-S2-MINI-1U are two powerful, generic Wi-Fi MCU modules that have a rich set of
peripherals. They are an ideal choice for a wide variety of application scenarios relating to Internet of Things (IoT),
wearable electronics and smart home.
The ordering information of the two modules is listed as follows:
Table 1: Ordering Information
Module
ESP32-S2-MINI-1 (ANT)
ESP32-S2-MINI-1U (CONN)
Ordering code
Chip embedded
ESP32-S2-MINI-1-N4
ESP32-S2FH4
ESP32-S2-MINI-1-N4R2
ESP32-S2FN4R2
ESP32-S2-MINI-1U-N4
ESP32-S2FH4
ESP32-S2-MINI-1U-N4R2
ESP32-S2FN4R2
Module dimensions (mm)
15.4 × 20.0 × 2.4
15.4 × 15.4 × 2.4
Notes:
For dimensions of the external antenna connector, please see Section 7.3.
Espressif Systems
3
ESP32-S2-MINI-1 & ESP32-S2-MINI-1U Datasheet v1.0
Submit Documentation Feedback
1 Module Overview
ESP32-S2-MINI-1 comes with a on-board PCB antenna, and ESP32-S2-MINI-1U with an U.FL connector for
external antenna. Both ESP32-S2-MINI-1 and ESP32-S2-MINI-1U have two variants:
• integrating the ESP32-S2FH4 chip (which is embedded with a 4 MB high-temperature flash), or
• integrating the ESP32-S2FN4R2 chip (which is embedded with a 4 MB flash and 2 MB PSRAM)
The two variants only differ in the chip integrated. In this datasheet unless otherwise stated, ESP32-S2-MINI-1
refers to both ESP32-S2-MINI-1-N4 and ESP32-S2-MINI-1-N4R2, whereas ESP32-S2-MINI-1U refers to both
ESP32-S2-MINI-1U-N4 and ESP32-S2-MINI-1U-N4R2.
The ESP32-S2FH4 chip and the ESP32-S2FN4R2 chip falls into the same category, namely ESP32-S2 chip
series. ESP32-S2 series of chips has an Xtensa® 32-bit LX7 CPU that operates at up to 240 MHz. It has a
low-power co-processor that can be used instead of the CPU to save power while performing tasks that do not
require much computing power, such as monitoring of peripherals.
ESP32-S2 series integrates a rich set of peripherals, ranging from SPI, I2S, UART, I2C, LED PWM, TWAI® , LCD,
Camera interface, ADC, DAC, touch sensor, temperature sensor, as well as up to 43 GPIOs. It also includes a
full-speed USB On-The-Go (OTG) interface to enable USB communication.
The ESP32-S2FH4 chip and the ESP32-S2FN4R2 chip vary in:
• temperature of embedded flash
• whether a PSRAM is embedded
For details, please refer to Section Family Member Comparison in ESP32-S2 Series Datasheet.
1.3 Applications
• Generic Low-power IoT Sensor Hub
• Smart Building
• Generic Low-power IoT Data Loggers
• Industrial Automation
• Cameras for Video Streaming
• Smart Agriculture
• Over-the-top (OTT) Devices
• Audio Applications
• USB Devices
• Health Care Applications
• Speech Recognition
• Wi-Fi-enabled Toys
• Image Recognition
• Wearable Electronics
• Mesh Network
• Home Automation
• Retail & Catering Applications
• Smart Home Control Panel
• Smart POS Machines
Espressif Systems
4
Contents
Contents
1
Module Overview
3
1.1
Features
3
1.2
Description
3
1.3
Applications
4
2
Block Diagram
8
3
Pin Definitions
9
3.1
Pin Layout
9
3.2
Pin Description
10
3.3
Strapping Pins
12
4
Electrical Characteristics
14
4.1
Absolute Maximum Ratings
14
4.2
Recommended Operating Conditions
14
4.3
DC Characteristics (3.3 V, 25 °C)
14
4.4
Current Consumption Characteristics
15
4.5
Wi-Fi RF Characteristics
16
4.5.1
Wi-Fi RF Standards
16
4.5.2
Transmitter Characteristics
16
4.5.3
Receiver Characteristics
16
5
Schematics
18
6
Peripheral Schematics
Physical Dimensions and PCB Land Pattern
21
7.1
Physical Dimensions
21
7.2
Recommended PCB Land Pattern
23
7.3
Dimensions of External Antenna Connector
25
8
Product Handling
26
8.1
Storage Condition
26
8.2
ESD
26
8.3
Reflow Profile
26
9
MAC Addresses and eFuse
27
10 Learning Resources
28
10.1
Must-Read Documents
28
10.2
Must-Have Resources
28
Revision History
Espressif Systems
29
5
List of Tables
List of Tables
1
2
Pin Definitions
10
3
Strapping Pins
12
4
14
5
14
6
14
7
Current Consumption Depending on RF Modes
15
8
Current Consumption Depending on Work Modes
15
9
Wi-Fi RF Standards
16
10
16
11
17
Espressif Systems
3
6
List of Figures
List of Figures
1
ESP32-S2-MINI-1 Block Diagram
8
2
ESP32-S2-MINI-1U Block Diagram
8
3
ESP32-S2-MINI-1 Pin Layout (Top View)
9
4
ESP32-S2-MINI-1U Pin Layout (Top View)
10
5
ESP32-S2-MINI-1 Schematics
18
6
ESP32-S2-MINI-1U Schematics
19
7
ESP32-S2-MINI-1 Physical Dimensions
21
9
ESP32-S2-MINI-1U Physical Dimensions
22
10
ESP32-S2-MINI-1 Recommended PCB Land Pattern
23
11
ESP32-S2-MINI-1U Recommended PCB Land Pattern
24
12
25
13
Reflow Profile
26
Espressif Systems
7
2 Block Diagram
2 Block Diagram
ESP32-S2-MINI-1
40 MHz
Crystal
40 MHz
Crystal
3V3
3V3
ESP32-S2-MINI-1
Antenna
Antenna
RF Matching
EN
EN
ESP32-S2FH4
ESP32-S2FN4R2
ESP32-S2FH4
ESP32-S2FN4R2
FLASH
PSRAM(opt.)
(QSPI)
(QSPI)
FLASH
(QSPI)
PSRAM(opt.)
(QSPI)
RF Matching
GPIOs
GPIOs
Figure 1: ESP32S2MINI1 Block Diagram
ESP32-S2-MINI-1U
40 MHz
Crystal
40 MHz
Crystal
3V3
3V3
ESP32-S2-MINI-1U
Antenna
Antenna
RF Matching
EN
EN
ESP32-S2FH4
ESP32-S2FN4R2
ESP32-S2FH4
RF Matching
GPIOs
FLASH
PSRAM(opt.)
ESP32-S2FN4R2
(QSPI)
(QSPI)
FLASH
(QSPI)
GPIOs
PSRAM(opt.)
(QSPI)
Figure 2: ESP32S2MINI1U Block Diagram
Espressif Systems
8
3 Pin Definitions
3 Pin Definitions
3.1 Pin Layout
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
Pin 59
Pin 58
Pin 57
Pin 56
Pin 55
Pin 54
Pin 53
Pin 52
Pin 51
Pin 50
Pin 49
Pin 48
Pin 47
Pin 46
Pin 62
GND
Pin 60
Keepout Zone
Pin 65
GND
GND
Pin 1
Pin 45
EN
GND
Pin 2
Pin 44
IO46
3V3
Pin 3
Pin 43
GND
IO0
Pin 4
Pin 42
GND
IO1
Pin 5
Pin 41
IO45
IO2
Pin 6
Pin 40
RXD0
IO3
Pin 7
Pin 39
TXD0
Pin 38
IO42
Pin 37
IO41
Pin 36
IO40
IO4
Pin 8
IO5
Pin 9
GND
GND
GND
GND
Pin 61
GND
GND
GND
GND
GND
Pin 27
Pin 28
Pin 29
Pin 30
NC
IO33
IO34
GND
Pin 63
GND
Pin 26
IO35
IO26
Pin 31
Pin 25
Pin 15
IO21
IO11
Pin 24
IO36
IO20
Pin 32
IO19
Pin 14
Pin 23
IO10
IO18
IO37
Pin 22
Pin 33
IO17
Pin 13
Pin 21
IO9
IO16
IO38
Pin 20
Pin 34
IO15
Pin 12
Pin 19
IO8
IO14
IO39
Pin 18
Pin 35
IO13
Pin 11
Pin 17
IO7
Pin 16
Pin 10
IO12
IO6
Pin 64
GND
Figure 3: ESP32S2MINI1 Pin Layout (Top View)
Espressif Systems
9
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
Pin 60
Pin 59
Pin 58
Pin 57
Pin 56
Pin 55
Pin 54
Pin 53
Pin 52
Pin 51
Pin 50
Pin 49
Pin 48
Pin 47
Pin 46
3 Pin Definitions
Pin 62
GND
Pin 65
GND
GND
Pin 1
Pin 45
EN
GND
Pin 2
Pin 44
IO46
3V3
Pin 3
Pin 43
GND
IO0
Pin 4
Pin 42
GND
Pin 41
IO45
Pin 40
RXD0
IO1
Pin 5
IO2
Pin 6
IO3
Pin 7
IO4
Pin 8
IO5
Pin 9
IO6
Pin 10
GND
GND
GND
GND
Pin 61
GND
GND
GND
GND
GND
Pin 39
TXD0
Pin 38
IO42
Pin 37
IO41
Pin 36
IO40
Pin 29
Pin 30
IO34
GND
Pin 28
IO33
IO26
Pin 27
Pin 26
IO21
NC
Pin 24
Pin 25
IO20
Pin 22
Pin 23
Pin 63
GND
IO19
IO35
IO18
Pin 31
Pin 21
Pin 15
Pin 20
IO36
IO11
IO17
IO10
Pin 32
IO16
IO37
Pin 14
Pin 19
Pin 33
Pin 18
Pin 13
IO14
IO38
IO9
IO15
IO8
Pin 17
IO39
Pin 34
Pin 16
Pin 35
IO12
Pin 11
Pin 12
IO13
IO7
Pin 64
GND
Figure 4: ESP32S2MINI1U Pin Layout (Top View)
Note:
The pin diagram shows the approximate location of pins on the module. For the actual mechanical diagram, please refer
to Figure 7.1 Physical Dimensions.
3.2 Pin Description
The module has 65 pins. See pin definitions in Table 2.
Table 2: Pin Definitions
Name
No.
Type
Function
GND
1, 2, 30, 42, 43, 46-65
P
Ground
3V3
3
P
Power supply
IO0
4
I/O/T
RTC_GPIO0, GPIO0
IO1
5
I/O/T
RTC_GPIO1, GPIO1, TOUCH1, ADC1_CH0
IO2
6
I/O/T
RTC_GPIO2, GPIO2, TOUCH2, ADC1_CH1
IO3
7
I/O/T
RTC_GPIO3, GPIO3, TOUCH3, ADC1_CH2
IO4
8
I/O/T
RTC_GPIO4, GPIO4, TOUCH4, ADC1_CH3
IO5
9
I/O/T
RTC_GPIO5, GPIO5, TOUCH5, ADC1_CH4
IO6
10
I/O/T
RTC_GPIO6, GPIO6, TOUCH6, ADC1_CH5
IO7
11
I/O/T
RTC_GPIO7, GPIO7, TOUCH7, ADC1_CH6
IO8
12
I/O/T
RTC_GPIO8, GPIO8, TOUCH8, ADC1_CH7
Espressif Systems
10
3 Pin Definitions
Name
No.
Type
Function
IO9
13
I/O/T
RTC_GPIO9, GPIO9, TOUCH9, ADC1_CH8, FSPIHD
IO10
14
I/O/T
RTC_GPIO10, GPIO10, TOUCH10, ADC1_CH9, FSPICS0, FSPIIO4
IO11
15
I/O/T
RTC_GPIO11, GPIO11, TOUCH11, ADC2_CH0, FSPID, FSPIIO5
IO12
16
I/O/T
RTC_GPIO12, GPIO12, TOUCH12, ADC2_CH1, FSPICLK, FSPIIO6
IO13
17
I/O/T
RTC_GPIO13, GPIO13, TOUCH13, ADC2_CH2, FSPIQ, FSPIIO7
IO14
18
I/O/T
RTC_GPIO14, GPIO14, TOUCH14, ADC2_CH3, FSPIWP, FSPIDQS
IO15
19
I/O/T
RTC_GPIO15, GPIO15, U0RTS, ADC2_CH4, XTAL_32K_P
IO16
I/O/T
RTC_GPIO16, GPIO16, U0CTS, ADC2_CH5, XTAL_32K_N
IO17
21
I/O/T
RTC_GPIO17, GPIO17, U1TXD, ADC2_CH6, DAC_1
IO18
22
I/O/T
RTC_GPIO18, GPIO18, U1RXD, ADC2_CH7, DAC_2, CLK_OUT3
IO19
23
I/O/T
RTC_GPIO19, GPIO19, U1RTS, ADC2_CH8, CLK_OUT2, USB_D-
IO20
24
I/O/T
RTC_GPIO20, GPIO20, U1CTS, ADC2_CH9, CLK_OUT1, USB_D+
IO21
25
I/O/T
RTC_GPIO21, GPIO21
IO26
26
I/O/T
SPICS1, GPIO26
NC
27
IO33
28
I/O/T
SPIIO4, GPIO33, FSPIHD
IO34
29
I/O/T
SPIIO5, GPIO34, FSPICS0
IO35
31
I/O/T
SPIIO6, GPIO35, FSPID
IO36
32
I/O/T
SPIIO7, GPIO36, FSPICLK
IO37
33
I/O/T
SPIDQS, GPIO37, FSPIQ
IO38
34
I/O/T
GPIO38, FSPIWP
IO39
35
I/O/T
MTCK, GPIO39, CLK_OUT3
IO40
36
I/O/T
MTDO, GPIO40, CLK_OUT2
IO41
37
I/O/T
MTDI, GPIO41, CLK_OUT1
IO42
38
I/O/T
MTMS, GPIO42
TXD0
39
I/O/T
U0TXD, GPIO43, CLK_OUT1
RXD0
40
I/O/T
U0RXD, GPIO44, CLK_OUT2
IO45
41
I/O/T
GPIO45
IO46
44
I
GPIO46
NC
High: on, enables the chip.
EN
45
I
Low: off, the chip powers off.
Note: Do not leave the EN pin floating.
Notice:
1. IO18 on the module is pulled up to VDD33 through a 10 kΩ resistor. For details, please refer to Figure 5 and Figure
6.
2. IO26 is used by the embedded PSRAM on the ESP32-S2-MINI-1-N4R2 and ESP32-S2-MINI-1U-N4R2 modules,
and cannot be used for other purposes.
3. For peripheral pin configurations, please refer to ESP32-S2 Series Datasheet.
Espressif Systems
11
3 Pin Definitions
3.3 Strapping Pins
ESP32-S2 series of chips has three strapping pins: GPIO0, GPIO45, GPIO46. The pin-pin mapping between
ESP32-S2 series of chips and the module is as follows, which can be seen in Chapter 5 Schematics:
• GPIO0 = IO0
• GPIO45 = IO45
• GPIO46 = IO46
Software can read the values of corresponding bits from register ”GPIO_STRAPPING”.
During the chip’s system reset (power-on-reset, RTC watchdog reset, brownout reset, analog super watchdog
reset, and crystal clock glitch detection reset), the latches of the strapping pins sample the voltage level as
strapping bits of ”0” or ”1”, and hold these bits until the chip is powered down or shut down.
IO0, IO45 and IO46 are connected to the internal pull-up/pull-down. If they are unconnected or the connected
external circuit is high-impedance, the internal weak pull-up/pull-down will determine the default input level of
these strapping pins.
To change the strapping bit values, users can apply the external pull-down/pull-up resistances, or use the host
MCU’s GPIOs to control the voltage level of these pins when powering on ESP32-S2 series of chips.
After reset, the strapping pins work as normal-function pins.
Refer to Table 3 for a detailed boot-mode configuration of the strapping pins.
Table 3: Strapping Pins
VDD_SPI Voltage 1
Pin
IO45
3
Default
3.3 V
Pull-down
1.8 V
1
Booting Mode
2
Pin
Default
SPI Boot
Download Boot
IO0
Pull-up
1
IO46
Pull-down
Don’t-care
Enabling/Disabling ROM Code Print During Booting
4 5
Pin
Default
Enabled
Disabled
IO46
Pull-down
See the fifth note
See the fifth note
Note:
1. Firmware can configure register bits to change the settings of ”VDD_SPI Voltage”.
2. The strapping combination of GPIO46 = 1 and GPIO0 = 0 is invalid and will trigger unexpected behavior.
3. Internal pull-up resistor (R1) for IO45 is not populated in the module, as the flash in the module works at 3.3 V by
default (output by VDD_SPI). Please make sure IO45 will not be pulled high when the module is powered up by
external circuit.
4. ROM code can be printed over TXD0 (by default) or DAC_1 (IO17), depending on the eFuse bit.
5. When eFuse UART_PRINT_CONTROL value is:
0, print is normal during boot and not controlled by IO46.
1 and IO46 is 0, print is normal during boot; but if IO46 is 1, print is disabled.
Espressif Systems
12
3 Pin Definitions
2 and IO46 is 0, print is disabled; but if IO46 is 1, print is normal.
3, print is disabled and not controlled by IO46.
Espressif Systems
13
4 Electrical Characteristics
4.1 Absolute Maximum Ratings
Table 4: Absolute Maximum Ratings
Symbol
Parameter
Min
Max
VDD33
TST ORE
Unit
Power supply voltage
–0.3
3.6
V
Storage temperature
–40
105
°C
4.2 Recommended Operating Conditions
Table 5: Recommended Operating Conditions
Symbol
Parameter
Min
Typ
Max
Unit
VDD33
3.0
3.3
3.6
V
IV DD
Current delivered by external power supply
0.5
A
TA
–40
85
°C
Humidity
Humidity condition
85
%RH
4.3 DC Characteristics (3.3 V, 25 °C)
Table 6: DC Characteristics (3.3 V, 25 °C)
Symbol
Parameter
Min
CIN
Pin capacitance
VIH
High-level input voltage
Typ
2
0.75 × VDD
1
Max
Unit
pF
1
VDD + 0.3
1
V
VIL
Low-level input voltage
–0.3
0.25 × VDD
IIH
High-level input current
50
nA
Low-level input current
50
nA
IIL
2
High-level output voltage
0.8 × VDD
V
VOL 2
Low-level output voltage
0.1 × VDD
V
40
mA
28
mA
45
kΩ
45
kΩ
1
VOH
IOH
IOL
High-level source current (VDD1 = 3.3 V, VOH
>= 2.64 V, PAD_DRIVER = 3)
Low-level sink current (VDD1 = 3.3 V, VOL =
0.495 V, PAD_DRIVER = 3)
RP U
Pull-up resistor
RP D
Pull-down resistor
VIH_nRST
VIL_nRST
Chip reset release voltage
0.75 × VDD
Chip reset voltage
Espressif Systems
1
V
–0.3
14
1
VDD + 0.3
0.25 × VDD
1
V
V
Note:
1. VDD is the I/O voltage for a particular power domain of pins.
2. VOH and VOL are measured using high-impedance load.
4.4 Current Consumption Characteristics
With the use of advanced power-management technologies, the module can switch between different power
modes. For details on different power modes, please refer to Section RTC and Low-Power Management in
Table 7: Current Consumption Depending on RF Modes
Work mode
Description
TX
Active (RF working)
RX
Peak (mA)
802.11b, 20 MHz, 1 Mbps, @19.5 dBm
310
802.11g, 20 MHz, 54 Mbps, @15 dBm
220
802.11n, 20 MHz, MCS7, @13 dBm
200
802.11n, 40 MHz, MCS7, @13 dBm
160
802.11b/g/n, 20 MHz
63
802.11n, 40 MHz
68
Note:
• The current consumption measurements are taken with a 3.3 V supply at 25 °C of ambient temperature at the RF
port. All transmitters’ measurements are based on a 100% duty cycle.
• The current consumption figures for in RX mode are for cases when the peripherals are disabled and the CPU idle.
Table 8: Current Consumption Depending on Work Modes
Work mode
Modem-sleep
Description
The CPU is
powered on
Light-sleep
240 MHz
22 mA
160 MHz
17 mA
Normal speed: 80 MHz
14 mA
550 µA
The ULP co-processor is powered on.
235 µA
ULP sensor-monitored pattern
Deep-sleep
Power off
Current consumption (Typ)
22 µA @1% duty
RTC timer + RTC memory
25 µA
RTC timer only
20 µA
CHIP_PU is set to low level, the chip is powered off.
1 µA
Note:
• The current consumption figures in Modem-sleep mode are for cases where the CPU is powered on and the cache
idle.
• When Wi-Fi is enabled, the chip switches between Active and Modem-sleep modes. Therefore, current consumption changes accordingly.
Espressif Systems
15
• In Modem-sleep mode, the CPU frequency changes automatically. The frequency depends on the CPU load and
the peripherals used.
• During Deep-sleep, when the ULP co-processor is powered on, peripherals such as GPIO and I2C are able to
operate.
• The ”ULP sensor-monitored pattern” refers to the mode where the ULP coprocessor or the sensor works periodically. When touch sensors work with a duty cycle of 1%, the typical current consumption is 22 µA.
4.5 WiFi RF Characteristics
4.5.1 WiFi RF Standards
Table 9: WiFi RF Standards
Name
Description
Center frequency range of operating channel note1
2412 ~ 2484 MHz
Wi-Fi wireless standard
IEEE 802.11b/g/n
11b: 1, 2, 5.5 and 11 Mbps
20 MHz
Data rate
11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
11n: MCS0-7, 72.2 Mbps (Max)
40 MHz
11n: MCS0-7, 150 Mbps (Max)
Antenna type
PCB antenna, IPEX antenna
1. Device should operate in the center frequency range allocated by regional regulatory authorities. Target center
frequency range is configurable by software.
2. For the modules that use IPEX antennas, the output impedance is 50 Ω. For other modules without IPEX antennas,
users do not need to concern about the output impedance.
4.5.2 Transmitter Characteristics
Table 10: Transmitter Characteristics
Parameter
TX Power note1
Rate
Typ
11b, 1 Mbps
19.5
11b, 11 Mbps
19.5
11g, 6 Mbps
18
11g, 54 Mbps
15
11n, HT20, MCS0
18
11n, HT20, MCS7
13.5
11n, HT40, MCS0
18
11n, HT40, MCS7
13.5
Unit
dBm
1. Target TX power is configurable based on device or certification requirements.
4.5.3 Receiver Characteristics
Espressif Systems
16
Table 11: Receiver Characteristics
Parameter
RX Sensitivity
RX Maximum Input Level
Adjacent Channel Rejection
Espressif Systems
Rate
Typ
1 Mbps
–97
2 Mbps
–95
5.5 Mbps
–93
11 Mbps
–88
6 Mbps
–92
9 Mbps
–91
12 Mbps
–89
18 Mbps
–86
24 Mbps
–83
36 Mbps
–80
48 Mbps
–76
54 Mbps
–74
11n, HT20, MCS0
–92
11n, HT20, MCS1
–88
11n, HT20, MCS2
–85
11n, HT20, MCS3
–82
11n, HT20, MCS4
–79
11n, HT20, MCS5
–75
11n, HT20, MCS6
–73
11n, HT20, MCS7
–72
11n, HT40, MCS0
–89
11n, HT40, MCS1
–85
11n, HT40, MCS2
–83
11n, HT40, MCS3
–79
11n, HT40, MCS4
–76
11n, HT40, MCS5
–72
11n, HT40, MCS6
–70
11n, HT40, MCS7
–68
11b, 1 Mbps
5
11b, 11 Mbps
5
11g, 6 Mbps
5
11g, 54 Mbps
11n, HT20, MCS0
5
11n, HT20, MCS7
11n, HT40, MCS0
5
11n, HT40, MCS7
11b, 11 Mbps
35
11g, 6 Mbps
31
11g, 54 Mbps
14
11n, HT20, MCS0
31
11n, HT20, MCS7
13
11n, HT40, MCS0
19
11n, HT40, MCS7
8
17
Unit
dBm
dBm
dB
5
3
This is the reference design of the module.
3
GND XOUT
C4
TBD
The values of C1 and C4 vary with
the selection of the crystal.
The value of R4 varies with the actual
PCB board.
GND
R4
GND
GND
RF_ANT
1
2
L2
GND
TBD
C11
C12
TBD
TBD
PCB_ANT
GND
GND
The values of C11, L2 and C12
vary with the actual PCB board.
GND
LNA_IN
GPIO0
GPIO1
GPIO2
GPIO3
GPIO4
GPIO5
GPIO6
GPIO7
GPIO8
GPIO9
1
2
3
4
5
6
7
8
9
10
11
12
13
14
VDDA
LNA_IN
VDD3P3
VDD3P3
GPIO0
GPIO1
GPIO2
GPIO3
GPIO4
GPIO5
GPIO6
GPIO7
GPIO8
GPIO9
U1
15
16
17
18
19
22
23
24
25
26
27
28
GND
ANT1
VDD33
C15
0.1uF
GND
61
60
59
58
57
56
55
54
53
52
51
50
49
48
47
46
62
VDD33
0.1uF
GND
GPIO38
GPIO37
GPIO36
GPIO35
GPIO34
GPIO33
SPID
SPIQ
SPICLK
SPICS0
SPIWP
SPIHD
VDD_SPI
SPICS1
42
41
40
39
38
37
36
35
34
33
32
31
30
29
GPIO38
GPIO37
GPIO36
GPIO35
GPIO34
GPIO33
GPIO0
GPIO1
GPIO2
D1 GPIO3
ESD GPIO4
GPIO5
GPIO6
GPIO7
GPIO8
GND
GPIO9
GPIO10
GPIO11
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
63
GND
ESP32-S2-MINI-1
EN
IO46
GND
GND
IO45
RXD0
TXD0
IO42
IO41
IO40
IO39
IO38
IO37
IO36
IO35
GND
GND
U2
GPIO26
C13
C14
0.1uF
1uF
ESP32-S2FH4
ESP32-S2FN4R2 GND
10K
ESP32-S2-MINI-1(pin-out)
GND
VDD33
C16
0.1uF
GND
Figure 5: ESP32S2MINI1 Schematics
GND
GND
GND
3V3
IO0
IO1
IO2
IO3
IO4
IO5
IO6
IO7
IO8
IO9
IO10
IO11
VDD_SPI
R11
GPIO21
0.1uF
GPIO15
GPIO16
GPIO17
GPIO18
GPIO19
GPIO20
C9
0.1uF
C10
56
55
54
53
52
51
50
49
48
47
46
45
44
43
C8
1uF
CHIP_PU
GPIO46
VDDA
XTAL_P
XTAL_N
VDDA
GPIO45
U0RXD
U0TXD
MTMS
MTDI
VDD3P3_CPU
MTDO
MTCK
C7
10uF
GPIO10
GPIO11
GPIO12
GPIO13
GPIO14
C6
GND
VDD33
GPIO10
GPIO11
GPIO12
GPIO13
GPIO14
VDD3P3_RTC
XTAL_32K_P
XTAL_32K_N
DAC_1
DAC_2
GPIO19
GPIO20
VDD3P3_RTC_IO
GPIO21
57
GND
2.0nH
GND
L1
CHIP_PU
GPIO46
GPIO45
U0RXD
U0TXD
GPIO42
GPIO41
GPIO40
GPIO39
GPIO33
GPIO34
0.1uF
VDD33
C
499
R3
C5
18
GND
EPAD
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
VDD33
IO12
IO13
IO14
IO15
IO16
IO17
IO18
IO19
IO20
IO21
IO26
NC
IO33
IO34
GND
GND
40MHz(±10ppm)
100pF
65
CHIP_PU
GPIO46
45
44
43
42
41
40
39
38
37
36
35
34
33
32
31
GPIO45
U0RXD
U0TXD
GPIO42
GPIO41
GPIO40
GPIO39
GPIO38
GPIO37
GPIO36
GPIO35
64
16
17
18
19
22
23
24
25
26
27
28
29
30
C2
GND
GPIO12
GPIO13
GPIO14
GPIO15
GPIO16
GPIO17
GPIO18
GPIO19
GPIO20
GPIO21
GPIO26
1
GND
Y1
2
C1
TBD
GND
C3
1uF
XIN
GND
4
GND
VDD33
A
1
5 Schematics
VDD33
B
2
5 Schematics
Espressif Systems
D
4
GND
5
3
3
C4
TBD
PCB board.
GND
R4
RF_ANT
L2
GND
TBD
ANT1
C11
C12
IPEX
TBD
TBD
GND
GND
LNA_IN
GPIO0
GPIO1
GPIO2
GPIO3
GPIO4
GPIO5
GPIO6
GPIO7
GPIO8
GPIO9
1
2
3
4
5
6
7
8
9
10
11
12
13
14
VDDA
LNA_IN
VDD3P3
VDD3P3
GPIO0
GPIO1
GPIO2
GPIO3
GPIO4
GPIO5
GPIO6
GPIO7
GPIO8
GPIO9
U1
VDD33
C15
GND
61
60
59
58
57
56
55
54
53
52
51
50
49
48
47
46
VDD33
0.1uF
GND
GPIO38
GPIO37
GPIO36
GPIO35
GPIO34
GPIO33
SPID
SPIQ
SPICLK
SPICS0
SPIWP
SPIHD
VDD_SPI
SPICS1
42
41
40
39
38
37
36
35
34
33
32
31
30
29
GPIO38
GPIO37
GPIO36
GPIO35
GPIO34
GPIO33
GPIO0
GPIO1
GPIO2
D1 GPIO3
ESD GPIO4
GPIO5
GPIO6
GPIO7
GPIO8
GND
GPIO9
GPIO10
GPIO11
GND
GND
GND
3V3
IO0
IO1
IO2
IO3
IO4
IO5
IO6
IO7
IO8
IO9
IO10
IO11
GND
U2
GND
ESP32-S2-MINI-1U
EN
IO46
GND
GND
IO45
RXD0
TXD0
IO42
IO41
IO40
IO39
IO38
IO37
IO36
IO35
GND
65
CHIP_PU
GPIO46
45
44
43
42
41
40
39
38
37
36
35
34
33
32
31
GPIO45
U0RXD
U0TXD
GPIO42
GPIO41
GPIO40
GPIO39
GPIO38
GPIO37
GPIO36
GPIO35
64
GPIO26
C13
C14
0.1uF
1uF
ESP32-S2FH4
ESP32-S2FN4R2 GND
10K
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
63
VDD_SPI
R11
0.1uF
62
GPIO33
GPIO34
4
3
2
GND
GND
ESP32-S2-MINI-1U(pin-out)
GND
VDD33
C16
GPIO21
GND
15
16
17
18
19
22
23
24
25
26
27
28
GND
GPIO15
GPIO16
GPIO17
GPIO18
GPIO19
GPIO20
0.1uF
C10
56
55
54
53
52
51
50
49
48
47
46
45
44
43
C9
0.1uF
CHIP_PU
GPIO46
VDDA
XTAL_P
XTAL_N
VDDA
GPIO45
U0RXD
U0TXD
MTMS
MTDI
VDD3P3_CPU
MTDO
MTCK
C8
1uF
GND
VDD33
GPIO10
GPIO11
GPIO12
GPIO13
GPIO14
VDD3P3_RTC
XTAL_32K_P
XTAL_32K_N
DAC_1
DAC_2
GPIO19
GPIO20
VDD3P3_RTC_IO
GPIO21
57
C7
10uF
GND
C6
1
A
GND
2.0nH
GPIO10
GPIO11
GPIO12
GPIO13
GPIO14
19
0.1uF
VDD33
L1
499
R3
C5
CHIP_PU
GPIO46
GPIO45
U0RXD
U0TXD
GPIO42
GPIO41
GPIO40
GPIO39
EPAD
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
IO12
IO13
IO14
IO15
IO16
IO17
IO18
IO19
IO20
IO21
IO26
NC
IO33
IO34
GND
VDD33
16
17
18
19
22
23
24
25
26
27
28
29
30
GND
40MHz(±10ppm)
100pF
GPIO12
GPIO13
GPIO14
GPIO15
GPIO16
GPIO17
GPIO18
GPIO19
GPIO20
GPIO21
GPIO26
4
1
C2
GND
GND XOUT
C1
TBD
Y1
2
C3
1uF
GND
GND
XIN
VDD33
GND
B
1
GND
VDD33
C
2
5 Schematics
Espressif Systems
D
4
0.1uF
GND
Figure 6: ESP32S2MINI1U Schematics
GND
6 Peripheral Schematics
This is the typical application circuit of the module connected with peripheral components (for example, power
supply, antenna, reset button, JTAG interface, and UART interface).
C1
C3
22uF
0.1uF
GND
IO0
IO1
IO2
IO3
IO4
IO5
IO6
IO7
IO8
IO9
IO10
IO11
GND
JP4
1
2
1
2
Boot Option
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
63
GND
GND
GND
GND
3V3
IO0
IO1
IO2
IO3
IO4
IO5
IO6
IO7
IO8
IO9
IO10
IO11
EN
IO46
GND
GND
IO45
RXD0
TXD0
ESP32-S2-MINI-1/ESP32-S2-MINI-1U IO42
IO41
IO40
IO39
IO38
IO37
IO36
IO35
GND
IO12
IO13
IO14
IO15
IO16
IO17
IO18
IO19
IO20
IO21
IO26
NC
IO33
IO34
GND
VDD33
GND
U1
GND
65
45
44
43
42
41
40
39
38
37
36
35
34
33
32
31
EN
IO46
C2
R1
GND
C7 12pF(NC)
0(NC)
0(NC)
R6
R4
X1: ESR = Max. 70 KΩ
UART
JP2
TMS
TDI
TDO
TCK
1
2
3
4
1
2
3
4
JTAG
R7
GND
C6
NC: No component.
1
2
3
4
GND
64
IO33
IO34
IO12
IO13
IO14
IO15
IO16
IO17
IO18
IO19
IO20
IO21
IO26
R3
R5
NC
2
X1
32.768kHz(NC)
1
2
3
4
TBD
SW1
R2
1
C4 12pF(NC)
GND
JP1
IO45
RXD0
TXD0
IO42
IO41
IO40
IO39
IO38
IO37
IO36
IO35
C8
GND
TBD
VDD33
16
17
18
19
22
23
24
25
26
27
28
29
30
62
EPAD
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
GND
61
60
59
58
57
56
55
54
53
52
51
50
49
48
47
46
GND
TBD
0 EN
0.1uF
GND
JP3
USB_D+
USB_D-
2
1
C5
USB OTG
2
1
TBD
GNDGND
Figure 7: Peripheral Schematics
Note:
• Soldering the EPAD to the ground of the base board is not a must, though doing so can get optimized thermal
performance. If users do want to solder it, they need to ensure that the correct quantity of soldering paste is applied.
• To ensure the power supply to the ESP32-S2 series of chips during power-up, it is advised to add an RC delay
circuit at the EN pin. The recommended setting for the RC delay circuit is usually R = 10 kΩ and C = 1 µF. However,
specific parameters
should be adjusted based on the power-up
4
3 timing of the module and the power-up and reset
2
sequence timing of the chip. For ESP32-S2’s power-up and reset sequence timing diagram, please refer to Section
Power Scheme in ESP32-S2 Series Datasheet.
Espressif Systems
7 Physical Dimensions and PCB Land Pattern
Unit: mm
0.8
0.7
Top view
4.5
1.2
2.4±0.15
15.5
14.8
13.2
12.3
11.5
10.6
0.5
13.55
Ø
0.
5
0.6
1.2
14
0.6
20±0.15
4.5
15.4±0.15
4.5
10.6
11.5
12.3
13.2
14.8
Side view
Bottom view
Figure 8: ESP32S2MINI1 Physical Dimensions
Espressif Systems
21
Unit: mm
0.8
0.85
0.6
1.2
0.7
Top view
4.5
1.2
0.5
14
0.6
14.8
13.2
12.3
11.5
10.6
3.2
13.55
15.4±0.15
1.6
15.4±0.15
2.4±0.15
4.5
10.6
11.5
12.3
13.2
14.8
Side view
Bottom view
Figure 9: ESP32S2MINI1U Physical Dimensions
Note:
For information about tape, reel, and product marking, please refer to Espressif Module Package Information.
Espressif Systems
22
7.2 Recommended PCB Land Pattern
Unit: mm
: Pad
Antenna Area
Pin 1
1.2
4.5
0.6
4.5
1.2
13.2
12.3
11.5
10.6
0.6
4.5
15.4
10.6
11.5
12.3
13.2
14.8
Figure 10: ESP32S2MINI1 Recommended PCB Land Pattern
Espressif Systems
23
Unit: mm
: Pad
15.4
Pin 1
4.5
0.6
15.4
14.8
13.2
12.3
11.5
10.6
4.5
1.2
1.2
0.6
10.6
11.5
12.3
13.2
14.8
Figure 11: ESP32S2MINI1U Recommended PCB Land Pattern
Espressif Systems
24
7.3 Dimensions of External Antenna Connector
ESP32-S2-MINI-1U uses the third generation external antenna connector as shown in Figure 12. This connector
is compatible with the following connectors:
• W.FL Series connector from Hirose
• MHF III connector from I-PEX
• AMMC connector from Amphenol
Unit: mm
Tolerance: +/-0.1 mm
CONTACT
1.7
2.00±0.10
A
A
GROUND CONTACT
2.05±0.10
0.85
0.57
1.7
CONTACT
1.40
0.10
HOUSING
HOUSING MATERIAL: THERMOPLASTIC, WHITE, UL 94V-0;
SHELL
CONTACT MATERIAL: COPPER ALLOY, GOLD PLATED ALL OVER;
SECTION: A-A
SCALE: 1:1
SHELL MATERIAL: COPPER ALLOY, GOLD PLATED ALL OVER;
PERFORMANCE:
CONTACT RESISTANCE: 20mOHM Max.
DIELECTRIC WITHSTANDING VOLTAGE: 200V AC FOR 1MINUTE;
INSULATION RESISTANCE: 500MOHM Min.
Figure 12: Dimensions of External Antenna Connector
Espressif Systems
25
8 Product Handling
8 Product Handling
8.1 Storage Condition
The products sealed in Moisture Barrier Bag (MBB) should be stored in a noncondensing atmospheric
environment of < 40 °C/90%RH.
The module is rated at moisture sensitivity level (MSL) 3.
After unpacking, the module must be soldered within 168 hours with factory conditions 25±5 °C and /60%RH.
The module needs to be baked if the above conditions are not met.
8.2 ESD
• Human body model (HBM): 2000 V
• Charged-device model (CDM): 500 V
• Air discharge: 6000 V
• Contact discharge: 4000 V
Temperature (℃)
8.3 Reflow Profile
Peak Temp.
235 ~ 250 ℃
250
Preheating zone
150 ~ 200 ℃
60 ~ 120 s
217
200
Reflow zone
217 ℃ 60 ~ 90 s
Cooling zone
–1 ~ –5 ℃/s
Soldering time
> 30 s
Ramp-up zone
1 ~ 3 ℃/s
100
50
25
Time (sec.)
100
150
200
250
Ramp-up zone — Temp.: 25 ~ 150 ℃ Time: 60 ~ 90 s Ramp-up rate: 1 ~ 3 ℃/s
Preheating zone — Temp.: 150 ~ 200 ℃ Time: 60 ~ 120 s
Reflow zone — Temp.: >217 ℃
60 ~ 90 s; Peak Temp.: 235 ~ 250 ℃ Time: 30 ~ 70 s
Cooling zone — Peak Temp. ~ 180 ℃ Ramp-down rate: –1 ~ –5 ℃/s
Solder — Sn-Ag-Cu (SAC305) lead-free solder alloy
Figure 13: Reflow Profile
Note:
Solder the module in a single reflow.
Espressif Systems
26
9 MAC Addresses and eFuse
The eFuse in ESP32-S2 family of chips has been burnt into 48-bit mac_address. The actual addresses the chip
uses in station or AP modes correspond to mac_address in the following way:
• Station mode: mac_address
• AP mode: mac_address + 1
There are seven blocks in eFuse for users to use. Each block is 256 bits in size and has independent write/read
disable controller. Six of them can be used to store encrypted key or user data, and the remaining one is only
used to store user data.
Espressif Systems
27
10
Learning Resources
10.1
MustRead Documents
The following link provides documents related to ESP32-S2.
• ESP32-S2 Datasheet
This document provides an introduction to the specifications of the ESP32-S2 hardware, including
overview, pin definitions, functional description, peripheral interface, electrical characteristics, etc.
• ESP-IDF Programming Guide
It hosts extensive documentation for ESP-IDF ranging from hardware guides to API reference.
• ESP32-S2 Technical Reference Manual
The manual provides detailed information on how to use the ESP32-S2 memory and peripherals.
• Espressif Products Ordering Information
10.2
MustHave Resources
Here are the ESP32-S2-related must-have resources.
• ESP32-S2 BBS
This is an Engineer-to-Engineer (E2E) Community for ESP32-S2 where you can post questions, share
knowledge, explore ideas, and help solve problems with fellow engineers.
Espressif Systems
28
Revision History
Revision History
Date
Version
Release notes
• Added module variants embedded with the ESP32-S2FN4R2 chip
• Added module description to the title page
2021-06-25
V1.0
• Updated Chapter 1 Module Overview
• Added description in Section 7.3 Dimensions of External Antenna Connector
• Replaced ”chip family” with ”chip series” following Espressif’s taxonomy
• Added TWAI to Chapter 1 Module Overview
• Updated Table 7 Current Consumption Characteristics
2020-12-17
V0.6
• Updated the capacitance value of RC delay circuit to 1 µF in Chapter 6
• Updated note in Section 8.3 Reflow Profile
2020-09-23
V0.5
Espressif Systems
Preliminary release.
29
Disclaimer and Copyright Notice
Information in this document, including URL references, is subject to change without notice.
ALL THIRD PARTY’S INFORMATION IN THIS DOCUMENT IS PROVIDED AS IS WITH NO
WARRANTIES TO ITS AUTHENTICITY AND ACCURACY.
NO WARRANTY IS PROVIDED TO THIS DOCUMENT FOR ITS MERCHANTABILITY, NONINFRINGEMENT, FITNESS FOR ANY PARTICULAR PURPOSE, NOR DOES ANY WARRANTY
OTHERWISE ARISING OUT OF ANY PROPOSAL, SPECIFICATION OR SAMPLE.
All liability, including liability for infringement of any proprietary rights, relating to use of information
in this document is disclaimed. No licenses express or implied, by estoppel or otherwise, to any
intellectual property rights are granted herein.
The Wi-Fi Alliance Member logo is a trademark of the Wi-Fi Alliance. The Bluetooth logo is a
registered trademark of Bluetooth SIG.
www.espressif.com
All trade names, trademarks and registered trademarks mentioned in this document are property
of their respective owners, and are hereby acknowledged.
Copyright © 2021 Espressif Systems (Shanghai) Co., Ltd. All rights reserved.
