PA40DP-44QF-34
PA40DP-44QF-34
    LOGICALSYSTEMS(Logical Systems)
    PIC16C64A, 65A(B), 67, 662, 74A(B), 774, 77, F874, F877 - Socket Module - DIP
PA40DP-44QF-34 数据手册
PA40Dx-44QF-34 Data Sheet 40 pin DIP socket/44 pin QFP plug Supported Device/Footprints Adapter Construction These adapters accept 40 pin DIP devices and have a removable 44 pin QFP solder-down plug. They allow DIP devices, or emulators with DIP plugs, to be used during development of QFP based products. The adapter is made up of 3 or 4 sub-assemblies. They assemble via connectors making the adapter modular. This way the sub-assemblies can be replaced easily. The following DIP device footprints are converted to the indicated QFP footprint. When disassembling the adapter take care not to bend the pins. When reassembling the adapter note the pin 1 indicators to align the parts correctly. Zilog: Z86C34/ C35/ C36/ C44/ C45/ C46 Footprint: Same device 44QFP The following chart lists the adapters described by this datasheet and their subassemblies. Other devices that require the same wiring and footprint would also be supported. This QFP plug will fit most 44 pin. 0.8mm pitch, QFP land patterns. Usually the pads extend from the body past the tip of the device leads. This plug will fit on pads that have a minimum span of 10.0mm or less and a maximum span of 12.0mm or more. Inner pad span Outer pad span 10.0mm or less 12.0mm or more Adapter PA40DZ-44QF-34 PA40DP-44QF-34 Test Socket 40-ADZ * none * Board QFP Plug PA51-DP-34Q PQF-44 PA51-DP-34Q PQF-44 * The top board always has a 40 pin DIP production socket. The optional test socket plugs into the production socket. Test Socket LSC # 40ADZ Style DIP ZIF Mfgr/Pn Aries 40-6554-11 Adapter Wiring The QFP Plug’s leads are dimensioned as follows. The following chart shows the connections from the DIP device to the adapter’s QFP plug. Plug PQF-44 Body 10.0 mm typ Knee 9.6 mm typ Tip 12.0 mm typ Pitch 0.8 mm Adapter Dimensions PA40DP-44QF-34 DIP Socket 1 2 3 4 5 6 7 8 9 10 11 11 12 13 14 15 16 17 18 19 20 - SIGNAL R/W P25 P26 P27 P04 P05 P06 P14 P15 P07 Vcc Vcc P16 P17 XTAL2 XTAL1 P31 P32 P33 P34 AS R/RL QFP Plug 40 41 42 43 44 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 QFP Plug 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 22 21 20 19 18 SIGNAL N/C DS P24 P23 P22 P21 P20 P03 P13 P12 GND GND P02 P11 P10 P01 P00 P30 P36 P37 P35 RESET DIP Socket 40 39 38 37 36 35 34 33 32 31 31 30 29 28 27 26 25 24 23 22 21 Skip short notation (1, 12, 23, 34) (12-13), (34-35) using “header” pin numbers. PA40DZ-44QF-34 Logical Systems Corporation PO Box 6184, Syracuse, NY 13217-6184 USA Tel (315) 478-0722, FAX (315) 479-6753 S Y S T E M S www.logicalsys.com, Email: info@logicalsys.com PA40Dx-44QF-34 Data Sheet Doc: 404434DQ.DOC Rev 02/09/00 Page 1 of 1
PA40DP-44QF-34 价格&库存
很抱歉,暂时无法提供与“PA40DP-44QF-34”相匹配的价格&库存,您可以联系我们找货
