PA40-44-33-DP(-PP) Data Sheet
40 pin DIP socket/44 pin PLCC plug
Supported Device/Footprints
Adapter Construction
These adapters accept 40 pin DIP devices and plugs into 44 pin
PLCC production sockets. They allow DIP devices, or emulators
with DIP plugs, to be used during development of PLCC based
products.
The adapter is made up of 2 sub-assemblies. They assemble via
connectors making the adapter modular. This way the subassemblies can be easily replaced.
The following DIP devices footprint are converted to the
indicated PLCC footprint.
Zilog: Z86E30/ E31/ E33/ 733/ E34/ E40/E43/743/E44
Footprint: Same device 44PLCC
Other devices that require the same wiring would also be supported.
Adapter Dimensions
The following chart lists the adapters described by this datasheet
and their subassemblies.
Adapter
Test
Top
Bottom
Socket
Board
Board
PA40-44-33-DP
40-ADZ *
44-40-33-DIP
44PLUG
PA40-44-33-DP-PP
none *
44-40-33-DIP
44PLUG
* The top board always has a 40 pin DIP production socket. The
optional test socket plugs into the production socket.
Test Sockets
LSC #
40ADZ
Style
DIP ZIF
Mfgr/Pn
Aries 40-6554-11
When disassembling the adapter take care not to bend the pins.
When reassembling the adapter note the pin 1 indicators to align
the parts correctly.
Test Points
are available using the two rows of header pins.
Adapter Wiring
The following chart shows the connections from the DIP device
to the adapter’s PLCC plug.
PA40-44-33-DP
DEVICE
1
2
3
4
5
6
7
8
9
10
11
11
12
13
14
15
16
17
18
19
SIGNAL
NC
R/WP25
P26
P27
P04
P05
P06
P14
P15
P07
VCC
VCC
P16
P17
XTAL2
XTAL1
P31
P32
P33
P34
AS-
PLUG
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
PLUG
34
35
36
37
38
39
40
41
42
43
44
1
2
3
4
5
6
7
8
9
10
11
SIGNAL
R/RLRST
P35
P37
P36
P30
P00
P01
P10
P11
P02
GND
GND
P12
P13
P03
P20
P21
P22
P23
P24
DS-
DEVICE
21
22
23
24
25
26
27
28
29
30
31
31
32
33
34
35
36
37
38
39
40
Skip short notation: 1, 12, 23, 34 (1-2), (23-24)PLCC rotated CCW (+11).
PA40-44-33-DP-PP
Logical Systems Corporation
PO Box 6184, Syracuse, NY 13217-6184 USA
Tel (315) 478-0722, FAX (315) 479-6753
S Y S T E M S www.logicalsys.com, Email: info@logicalsys.com
Doc: 404433DP.DOC
Rev 02/08/00
Page 1 of 1
很抱歉,暂时无法提供与“PA40-44-33-DP”相匹配的价格&库存,您可以联系我们找货
