SPD81152A
SPD81152A
1-Line, 400W, TVS
Http//:www.sh-willsemi.com
Descriptions
SPD81152A protect sensitive electronics against
voltage transients induced by inductive load switching
and lightning. Ideal for the protection of I/O interfaces,
VCC bus and other integrated circuits.
Features
For surface mount application
Excellent clamping capability
Low profile package
Fast response time: Typically less than
SMA (DO-214AC)
1.0ps from 0V to 16.7V
Low inductance
GPP
Schematic Diagram
Mechanical Data
Case: Molded plastic
Mounting position: Any
Weight: 0.063 grams
YYWW
UM
YY
WW
UM
= Year Code
= Week Code
= Device Code
Marking (Top View)
Order information
Device
SPD81152A-2/TR
Will Semiconductor Ltd.
1
Dim (mm)
Shipping
5.1*2.6*2.1
5000/Tape&Reel
Revision 1.2, 2017/10/17
SPD81152A
Absolute maximum ratings
Rating
Symbol
Value
Units
Peak Pulse Power on 10/1000µs waveform
PPPM
400
W
Peak Pulse Current of on 10/1000µs waveform
IPPM
16.4
A
TJ
-55~150
Operating Temperature
TOP
-40~125
Storage Temperature Range
TSTG
-55~150
Junction Temperature
Notes :
2
1. Mounted on 5.0mm (0.03mm thick) Copper Pads to each teminal
Electrical characteristics (TA=25 oC, unless otherwise noted)
Reverse
Breakdown Voltage
Part
Stand off
VBR@ IT
Number
Voltage
Current
(V)
(Bi)
VR
IT
SPD81152A
(V)
MIN
MAX
15.0
16.7
19.2
Test
Maximum
Maximum
Clamping
Peak Pulse
Voltage VC
Current
@IPP
IPP (A)
(V)
(A)
24.4
16.4
(mA)
1.0
Maximum Reverse
Leakage
IR @ VR
(μA)
1.0
Typical characteristics (TA=25oC, unless otherwise noted)
100
100
10/1000µs
75
% Of Rated Power
PPPM – Peak Pulse Power – (kW)
Non-repetitive pulse waveform
10
1
50
25
0.1
0.1µs
1µs
10µs
100µs
1ms
10ms
td - Pulse Width (sec.)
Fig. 1 Peak Pulse Power
25
50
75
100
125
TA – Ambient Temperature (℃)
Fig. 2 Pulse Derating Curve
2
150
SPD81152A
Package outline dimensions (Unit:mm)
SMA
D
B
A
C
E
F
G
Symbol
H
Dimensions in millimeter
Min.
Max.
A
3.990
4.500
B
2.540
2.790
C
4.930
5.280
D
1.250
1.650
E
0.152
0.305
F
1.980
2.290
G
0.780
1.520
H
0.203
Recommend land pattern (Unit: mm)
2.1
2.0
2.1
Notes:
1.8
This recommended land pattern is for reference
purposes only. Please consult your manufacturing
group to ensure your PCB design guidelines are met.
3
很抱歉,暂时无法提供与“SPD81152A-2/TR”相匹配的价格&库存,您可以联系我们找货
