SparkFun Transceiver Breakout - MAX3232
B OB-11 189 ROH S
9
images are CC BY-NC-SA 3.0
3D Download: STL, Blender
Description: The ‘must have’ IC for TTL/CMOS projects finally has its own breakout
board! This is the RS232 converter IC that is capable of running at 3V and
communicating with 5V logic.
We’ve taken the SOIC package MAX3232 and broken out all the pins you need to set
up your RS232 to TTL connection. We’ve also included the necessary 0.1uF charge
pump capacitors. Also remember that because the MAX3232 operates at a broader
voltage range than the 232 (3 - 5.5V) you can use this on both your 3.3 and 5V
projects!
https://www.sparkfun.com/products/11189
10/8/2015
很抱歉,暂时无法提供与“BOB-11189”相匹配的价格&库存,您可以联系我们找货
