M K R 2 U N O A DA P T E R
Code: TSX00005
Simply mount your MKR1000 to this new adapter and plug in any of
your UNO shields!
The MKR2UNO Adapter allows you to turn your Arduino UNO form factor based
project into a MKR based one without too much effort! You can so upgrade your
project with a powerful board with integrated LiPo battery charger.
TECH SPECS
Operating Voltage
Input Voltage (recommended)
Input Voltage (limit)
Analog Input Pins
Analog Output Pins
Digital I/O Pins
DC Current for 3.3V Pin
DC Current for 5V Pin
Length
Width
Weight
3.3V
7‐12V
6‐16V
6
1
14
700 mA
700 mA
68.6 mm
53.4 mm
24 g
OSH: Schematics
MKR2UNO is open‐source hardware! You can build your own board using the
following files:
EAGLE FILES IN .ZIP
https://www.arduino.cc/en/uploads/Main/MKR2UNO‐reference.zip
SCHEMATICS IN .PDF
https://www.arduino.cc/en/uploads/Main/MKR2UNO‐schematic.pdf
Please keep in mind that the MKR2UNO is just a form factor adapter and so is NOT
present any voltage translation. Be careful before connecting a shield since shield
without IOREF level shifting capability may not work properly.
Like in many others Arduino boards this adapter allows to power your MKR board
using a barrel jack with center positive polarity or the VIN pin on the headers.
If you want to use the Arduino MKRZero and the Arduino WIFi shield 101 read
the Arduino WIFi shield 101 reference to change module pins.
Unlike the Arduino UNO, the MKR2UNO Adapter do NOT have I2C signals on A4 and
A5 and SPI on pins 11, 12 and 13.
All the pins on the MKR2UNO Adapter are wired one to one from the MKR to the
UNO form factor with some exception:
MKR form factor pin
UNO form factor pin
1
10
13
1
https://store.arduino.cc/usa/mkr2uno‐adapter 12‐7‐17
很抱歉,暂时无法提供与“TSX00005”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4.663491+0.56430
- 国内价格
- 1+106.17949
- 10+104.34665
- 25+102.65961
- 100+101.10795
