DEV-14038
DEV-14038
    SPARKFUNELECTRONICS
    PIMORONIBLINKT
DEV-14038 数据手册
Pimoroni Blinkt! DEV-14038 Description: The Pimoroni Blinkt! is a “shield” for the Raspberry Pi, equipped with eight superbright and addressable RGB LEDs that make it ideal for adding visual notifications to your Pi. Each LED is individually controllable and dimmable, allowing you to create gradients, pulsing effects, or just flash them on and off like crazy. Each Pimoroni Blinkt! easily snaps on top of a Raspberry Pi equipped with a 40-pin (2x20) GPIO. Pimoroni has created a GitHub repository bundling the Blinkt! software with a set of examples to get you started in an easy-to-use Python module, so all you have to worry about is setting the color you want each pixel to be. Note: Be careful to plug in your Blinkt! the correct way; it has curves on the top that match the corners of any Raspberry Pi. Features: Eight RGB LED (APA102) Individually controllable pixels Sits directly on top of your Pi in a tiny footprint Fits inside most Pi cases Comes fully assembled SparkFun Electronics ®
DEV-14038 价格&库存
很抱歉,暂时无法提供与“DEV-14038”相匹配的价格&库存,您可以联系我们找货
