MIKROE-2546
MIKROE-2546
    MIKRO
    INTELJOULECLICKSHIELD
MIKROE-2546 数据手册
Intel® Joule™ click SHIELD PID: MIKROE-2546 Intel® Joule™ click SHIELD is an extension for Intel® Joule™ Expansion Board. This click shield allows you to add more than 270 click boards™ to your project. Add displays, WiFi, ZigBee or Bluetooth transceivers, Ethernet modules, sensors, MP3 codec circuit and other features to your prototype with ease. Click boards™ come with examples written in MikroElektronika compilers, so you will have a great base for your future projects. The Intel® Joule™ click SHIELD board includes the MCP3204 ADC - 2.7V 4-Channel/8Channel 12-Bit A/D Converters with SPI™ Serial Interface. The onboard ADC has a 2.048V reference. The board also features 2x40 pin connectors. Note: In case you don't want to use the 5V power supply on the Intel® Joule™ click SHIELD you should remove the jumper on the lower side of the board - marked as 5V EN. Jumpers and settings Intel® Joule™ Expansion Board The expansion board is intended to breakout all I/O interfaces from the Intel® JouleTM module into easily accessible connectors. Intel® Joule™ module This powerful system on module (SoM) was designed to help inventors and IoT developers contribute to a new generation of robots, drones, and IoT devices that are equipped with Intel® HD Graphics, 3D modeling, object recognition, and interactive capabilities. Key features     Two mikroBUS™ sockets  MCP3204 ADC  2x40 connector pins  3.3V and 5V power supply  Specification Product Type Applications On-board modules Power Supply Compatibility Shield Add click board™ connectivity to the Intel® Joule™ Expansion Board Two mikroBUS™ sockets, MCP3204 ADC 3.3V and 5V Intel® Joule™ https://shop.mikroe.com/click/shields/intel-joule-click-shield 4/5/17
MIKROE-2546 价格&库存
很抱歉,暂时无法提供与“MIKROE-2546”相匹配的价格&库存,您可以联系我们找货
MIKROE-2546
    • 1+76.11552
    库存:9
