DEV-12081
DEV-12081
    SPARKFUNELECTRONICS
    WEATHER SHIELD
DEV-12081 数据手册
 SparkFun Weather Shield DE V-12 081 RO HS        13  images are CC BY-NC-SA 3.0 Description: The Weather Shield is an easy to use Arduino shield that grants you access to barometric pressure, relative humidity, luminosity and temperature. There are also connections on this shield to optional sensors such as wind speed, direction, rain gauge and GPS for location and super accurate timing. These Weather Shields utilize the HTU21D humidity, MPL3115A2 barometric pressure, and ALS-PT19 light sensors and relies on the HTU21D and MPL3115A2 Arduino libraries. Each shield comes with two unpopulated RJ11 connector spaces (for optional hook up of rain and wind sensors) and a 6-pin GPS connector (for optional hook up of a GP635T GPS module). Finally, each Weather Shield can operate from 3.3V up to 16V and has built in voltage regulators and signal translators. Note: The Weather Shield comes as a stand-alone board. Headers, connectors, and additional sensors will need to be purchased separately, check the related items or wish list below! Note: This shield was designed for the SparkFun Redboard and Arduino Uno and will not work with other boards (like the Arduino Yun, for example) without modification. Features: • Humidity/Temperature Sensor - HTU21D • Barometric Pressure - MPL3115A2 • Light Sensor - ALS-PT19 https://www.sparkfun.com/products/12081 10/12/2015
DEV-12081 价格&库存
很抱歉,暂时无法提供与“DEV-12081”相匹配的价格&库存,您可以联系我们找货
