Think of Frequency Think of
Precise SMD Temperature
Compensated Crystal Oscillators
5.0 x 3.2 x 1.5 mm 7P Series
come visit our site http://www.txccorp.com
Oscillators
Series
Features
01 * 1
P0
19
TP
. High Stability Over Temperature: ±0.1ppm~±0.28ppm
. Operating Temperature Range: -40℃~85℃
. Holdover 24Hr: ±0.32ppm (Option)
. Free Run Stability for 20 years: ±4.6ppm (Option)
. Frequency: 10 ~ 52MHz
. Supply Voltage: 2.7V ~ 5.5V
. Voltage Control Function Available
. Output Enable/Disable Function Available
. Support Clipped Sinewave and CMOS Output Waveform
. Application: Small Cell, Base Station, Networking Infrastructure
. ROHS Compliant / Pb Free
Electrical Specifications
Item / Type
7P
Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com
Output Type
Clipped Sinewave
Output Load
10KΩ//10pF
Output Voltage
0.8 Vp-p Min.
Supply Current
5 mA Max.
CMOS
15pF
Output Low (VOL)
0.1 * Vcc Max.
Output High (VOH)
0.9 * Vcc Min.
10 mA Max.
Oscillation Mode
Fundamental
Supply Voltage
2.7 ~ 5.5 V
Frequency Range
10 ~ 52 MHz
Initial Frequency Tolerance at 25℃ after 2 Reflows
Vs. Temperature ( - 40 ~ + 85 ℃ )
±2.0 ppm
±0.28 / ±0.5 / ±2.0 ppm
Frequency Tolerance Vs. Load ( ± 5 % )
±0.1 ppm Max.
Vs. Supply Voltage ( ± 5 % )
±0.1 ppm Max.
Storage Temperature Range
Auto Frequency Control Range (Option)
-55 ~ +125 ℃
± 5 ~ ± 16 ppm (1.5 ± 1 V)
Start-up Time
2.5 ms Max.
Harmonics
-5 dBc Max.
Phase Noise at 1KHz Offset
-130 dBc/Hz
Aging
±1 ppm / year Max.
24 Hr Holdover Stability (Option) [#1]
±40 ppb
Free Run Stability for 20 Years (Option) [#2]
±4.6 ppm
[#1] 24 hours at constant temperature after 48 hours operation.
[#2] Inclusive of initial tolerance at 25℃ , temperature, supply voltage ±5%, load ±5%, reflow soldering and ageing 20 years.
Dimensions
Pin Connection
Recommended Land Pattern
Units: mm
92
很抱歉,暂时无法提供与“7P-38.400MBP-T”相匹配的价格&库存,您可以联系我们找货
