RV2
*5((1
&$3
&KLS7\SH6WDQGDUG&DSDFLWRUVKHLJKWPP
VERTICAL CHIP TYPE ALUMINUM ELECTROLYTIC CAPACITORS
60'
$QWL
FOHDQLQJ
VROYHQW
Compatible with surface mounting for 5.5mm high capacitors.
Supplied with carrier taping.
Guarantees 2000 hours at 85℃.
Convert to chip
RV2
RC3
Marking color : Black print
Specifications
Item
Performance
ー40 to +85
±20
Less than 0.01CV or 3 whichever is larger (after 2 minutes) C : Rated capacitance (µF) ; V : Rated voltage (V)
Category temperature range (℃)
Tolerance at rated capacitance (%)
Leakage current (µA)
Rated voltage (V)
Tangent of loss angle
(tanδ)
φ3
φ4 to φ6.3
tanδ (max.)
Rated voltage(V)
Z−25℃/Z+20℃
φ3
Impedance ratio
Z−40℃/Z+20℃
(max.)
Z−25℃/Z+20℃
φ4 to
Z−40℃/Z+20℃
φ6.3
Chip Type
Aluminum Electrolytic Capacitors
Characteristics at high
and low temperature
4
0.42
0.42
6.3
0.30
0.28
10
0.24
0.24
16
0.22
0.20
25
0.16
0.14
35
0.14
0.12
50
0.12
0.10
4
7
17
7
15
6.3
4
10
3
8
10
3
8
3
5
16
2
6
2
4
25
2
4
2
3
35
2
3
2
3
50
2
3
2
3
Tangent of the loss angle
Shelf life (85℃)
Test time : 1000hours ; other items are the same as those for the endurance. Voltage application treatment : According to JIS C5101-1
JIS C5101-1 1998, -18 1999 (IEC 60384-1 1992, -18 1993)
0.4±0.2
Unit : mm
0.3MAX
(P)
B±0.2
C
1.5
2.0
2.3
2.7
RV2
P
0.8
1.0
1.5
2.0
1k
10k・100k
1
1
1
1.15
1.25
1.35
1.25
1.40
1.50
16
V
Rated voltage
symbol
Series code
W
0.45 to 0.75
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
120
0.80
0.80
0.80
• φ3 (example : 16V10µF)
(C)
φD±0.5
B
3.3
4.3
5.3
6.6
50・60
Part numbering system
W
A
3.3
4.3
5.3
6.6
L
5.3±0.2
5.3±0.2
5.3±0.2
5.3±0.2
Frequency (Hz)
4 to 16
25 to 35
50
( ) : Reference size
φD
3
4
5
6.3
Coefficient of Frequency for Rated Ripple Current
Rated voltage (V)
(C)
A±0.2
L
(120Hz)
Applicable standards
Outline Drawing
(20℃,120Hz)
2000 hours (φ3 : 1000 hours)
The initial specified value or less
Within ±20% of initial value (4WV : ±30%)
200% or less of the initial specified value (4WV : 300%)
Test time
Leakage current
Percentage of capacitance change
Endurance (85℃)
(Applied ripple current)
(20℃,120Hz)
(20℃)
100
M
B55 U ̶
Rated capacitance
Capacitance
symbol
tolerance symbol
Casing
symbol
Taping
symbol
• φ4 to φ6.3 (example : 16V47µF)
Casing symbol
B55
RV2
16
V
Rated voltage
symbol
Series code
470
M
U ̶
Rated capacitance
Capacitance
symbol
tolerance symbol
Additional
symbol
Taping
symbol
Should add“S”
, when there is a black point in standard ratings.
Soldering conditions are described on page 13.
Land pattern size are described on page 11.
The taping spesifications are described on page 14.
Standard Ratings
Rated voltage
(V)
Rated
capacitance
(µF)
4
Item Case
0.1
φD (mm)
Casing
symbol
6.3
ESR
Rated ripple
current
Case
(Ω)(mArms)φD (mm)
Casing
symbol
10
ESR
Rated ripple
current
Case
(Ω)(mArms)φD (mm)
Casing
symbol
16
ESR
Rated ripple
current
Case
φD (mm)
(Ω)(mArms)
Casing
symbol
25
ESR
Rated ripple
current
Case
(Ω)(mArms)φD (mm)
Casing
symbol
35
ESR
Rated ripple
current
Case
(Ω)(mArms)φD (mm)
Casing
symbol
50
ESR
Rated ripple
current
Case
(Ω)(mArms)φD (mm)
B55 1990
1
905
754
603
503
424
353
199
166
75
50
2
5
3
6
4
7
6
10
15
19
35
26
17
44
0.33
0.47
1
2.2
3.3
8
9
11
19
B55 106
B55 70
B55 57
̶ 49
3
3
4.7
3
4
4
42
4
40
23
4
5
5
6.3
21
14
10
5.0
31
44
52
89
5
5
6.3
6.3
18
12
8.5
4.0
39
48
67
98
3
4
5
6.3
6.3
● 6.3
B55
22
33
47
100
220
3
B55 32
14
̶ 21
4
31
̶ 15
4
37
5
7.0 63
6.3 ̶
3.2 110
Rated ripple
current
B55
B55
B55
B55
0.22
37
18
33
26
15
44
10
63
7.1 75
3.3 103
ESR
(Ω)(mArms)
3
3
4
3
4
3
4
3
4
4
4
10
Casing
symbol
5
23
32
5
6.3
6.3
6.3
11
7.0
55
67
6.3
9.1
59
(Note) Rated ripple current : 85℃, 120Hz ; ESR : 20℃, 120Hz
CAT.No.2013/2014E
50
NOTE
Design, Specifications are subject to change without notice.
Ask factory for technical specifications before purchase and/or use.
很抱歉,暂时无法提供与“RV2-35V4R7MU-R”相匹配的价格&库存,您可以联系我们找货
