UPGRADE
DZN
DZN
ELECTRICDOUBLE
DOUBLELAYER
LAYERCAPACITORS
CAPACITORS“DYNACAP”
“DYNACAP”
ELECTRIC
High Power Type Capacitors
GREEN
CAP
70˚C
Low ESR
2.5V
2.7V
Low internal resistance allows boosting charge and heavy-current discharge.
(ampere level)
Pollution-Free ; with no pollutants such as Cd or Pb.
High power
Unlike batteries, excellent charge and
discharge characteristics with no chemical
DZN
DZ
reaction
Marking color : White print on a blue sleeve
Specifications
Item
Performance
Category temperature range (℃)
ー25 to +70
Tolerance at rated capacitance (%)
ー20 to +80
Internal resistance
at 1 kHz
Refer to the following page
Characteristics at high
and low temperature
Percentage of capacitance change
Endurance (70℃)
Within ±30% of the value at 20℃
Less than five times of the value at 20℃
Internal resistance
1000 hours
Test time
Within ±30% of the initial measured value
Internal resistance
Less than four times of the initial specified value
Shelf life (70℃)
Test time : 1000 hours ; Same as endurance.
Applicable standards
Conforms to JIS C5160-1 2009 (IEC 62391-1 2006)
Outline Drawing
Unit : mm
φ6.3 to φ18
φd±0.05
copper clad steel wire (tinned)
Sleeve
Vent
φ25, 35
2‒φ2
Sleeve
φD+0.5max.
φD
F
φd
6.3
2.5
α
5
min.
15min.
8
10 12.5
3.5
5.0
0.6
2.0
16
7.5
0.8
L+2max.
6.3±1
Vent
18
2.6
6.8
1.5±0.1
Markings
(‒) Negative terminal
indicated by cross notching
Position of printed
circuit board holes
7.5
φD+1max.
F±0.5
L+αmax.
1
0.
10
10
Lug terminal details
0.9±0.1 Thickness : 0.8t
2.1
Part numbering system (example : 2.5V10F)
DZN
Series code
2R5
D
106
(Z6)(S)
Max. operating voltage
symbol
Terminal
code
Rated capacitance
symbol
Casing
symbol
T ̶
Taping (Forming)
symbol
Part number is refer to the following page.
EDLC
CAT.No.2015/2016E
214
NOTE : Design,
Specifications are subject to change without notice.
It is recommended that you shall obtain technical specifications
from ELNA to ensure that the component is suitable for your use.
Standard Ratings (Series DZN 2.5V)
Max. operating voltage (V) Rated capacitance (F) Max. Leakage Current (mA) after 24h
ELNA Parts No.
φD×L (mm)
Internal resistance
(Ω max.) at 1kHz
DZN
UPGRADE
ELECTRIC DOUBLE LAYER CAPACITORS “DYNACAP”
Internal resistance (mΩ max.)
(DCR)
2.5
1
0.1
DZN-2R5D105F4T
6.3×14
0.4
1500
2.5
1
0.1
DZN-2R5D105G3T
8×12
0.3
1000
2.5
2.7
0.2
DZN-2R5D275G5ST
8×20
0.3
500
2.5
3.3
0.2
DZN-2R5D335H5T
10×20
0.2
350
2.5
4.7
0.3
DZN-2R5D475H5T
10×20
0.1
400
2.5
5.6
0.3
DZN-2R5D565H5T
10×20
0.1
350
2.5
6.8
0.4
DZN-2R5D685H6T
10×25
0.1
300
2.5
10
0.5
DZN-2R5D106H8T
10×35
0.1
200
2.5
10
0.5
DZN-2R5D106Z6ST
12.5×25
0.1
200
2.5
15
0.7
DZN-2R5D156Z8ST
12.5×35
0.1
150
2.5
15
0.7
DZN-2R5D156J5T
16×20
0.1
150
2.5
22
0.8
DZN-2R5D226J6T
16×25
0.1
120
2.5
33
0.8
DZN-2R5D336J8T
16×35.5
0.1
100
2.5
40
0.8
DZN-2R5D406K9T
18×40
0.1
75
2.5
50
1.0
DZN-2R5D506T
25×40
0.03
60
2.5
100
1.0
DZN-2R5D107S37T
25×50
0.03
50
2.5
200
2.0
DZN-2R5D207S57T
35×50
0.03
40
We tailor packaged product in series and parallel arrangements according to voltage and capacitance as required.
Standard Ratings (Series DZN 2.7V)
ELNA Parts No.
φD×L (mm)
Internal resistance
(Ω max.) at 1kHz
(DCR)
2.7
1
0.2
DZN-2R7D105F4T
6.3×14
0.4
1500
2.7
1
0.2
DZN-2R7D105G3T
8×12
0.3
1000
2.7
2.7
0.3
DZN-2R7D275G5ST
8×20
0.3
500
2.7
3.3
0.3
DZN-2R7D335H5T
10×20
0.2
350
2.7
4.7
0.4
DZN-2R7D475H5T
10×20
0.1
400
2.7
5.6
0.4
DZN-2R7D565H5T
10×20
0.1
350
2.7
6.8
0.5
DZN-2R7D685H6T
10×25
0.1
300
2.7
10
0.6
DZN-2R7D106H8T
10×35
0.1
200
2.7
10
0.6
DZN-2R7D106Z6ST
12.5×25
0.1
200
2.7
15
0.8
DZN-2R7D156Z8ST
12.5×35
0.1
150
2.7
15
0.8
DZN-2R7D156J6T
16×25
0.1
150
2.7
22
1.0
DZN-2R7D226J7T
16×31.5
0.1
120
2.7
33
1.0
DZN-2R7D336J9T
16×40
0.1
100
EDLC
NOTE : Design,
215
CAT.No.2015/2016E
很抱歉,暂时无法提供与“DZN-2R5D335H5T”相匹配的价格&库存,您可以联系我们找货
