DZN
*5((1
&$3
+LJKSRZHUW\SH&DSDFLWRUV
ELECTRIC DOUBLE LAYER CAPACITORS “DYNACAP”
9
Ý&
/RZ(65
9
Low internal resistance allows boosting charge and heavy-current discharge.
(ampere level)
Pollution-Free ; with no pollutants such as Cd or Pb.
+LJKSRZHU
Unlike batteries, excellent charge and
discharge characteristics with no chemical
'=1
reaction
Marking color : White print on a blue sleeve
Specifications
Item
Performance
Category temperature range (℃)
ー25 to +70
Tolerance at rated capacitance (%)
ー20 to +80
Internal resistance
at 1 kHz
Refer to the following page
Characteristics at high
and low temperature
Percentage of capacitance change
Endurance (70℃)
Within ±30% of the value at 20℃
Internal resistance
Less than five times of the value at 20℃
1000 hours
Test time
Within ±30% of the initial measured value
Internal resistance
Less than four times of the initial specified value
Shelf life (70℃)
Test time : 1000 hours ; Same as endurance.
Applicable standards
Conforms to JIS C5160-1 2009 (IEC 62391-1 2006)
Outline Drawing
Unit : mm
φ6.3 to φ18
9HQW
φd±0.05
copper clad steel wire (tinned)
Sleeve
φ25, 35
2‒φ2
Sleeve
φD+0.5max.
5
min.
15min.
L+2max.
φD
F
φd
6.3
2.5
α
8
10 12.5
3.5
5.0
0.6
2.0
16
6.3±1
Vent
18
7.5
0.8
2.6
6.8
1.5±0.1
Markings
(‒) Negative terminal
indicated by cross notching
Position of printed
circuit board holes
7.5
φD+1max.
F±0.5
L+αmax.
1
0.
10
10
Lug terminal details
0.9±0.1 Thickness : 0.8t
2.1
Part numbering system (example : 2.5V10F)
DZN
Series code
2R5
D
106
(H8)
Rated voltage
symbol
Terminal
code
Rated capacitance
symbol
Casing
symbol
T
Part number is refer to the following page.
Electric Double Layer Capacitors
CAT.No.2013/2014E
204
NOTE
Design, Specifications are subject to change without notice.
Ask factory for technical specifications before purchase and/or use.
DZN
Standard Ratings (Series DZ 2.5V)
Max. operating voltage (V) Rated capacitance (F) Max. Leakage Current (mA) after 24h
ELNA Parts No.
φD×L (mm)
Internal resistance
(Ω max.) at 1kHz
Internal resistance (mΩ)
at 1kHz (measurement value)
2.5
0.7
0.1
DZN-2R5D704G4T
8.0×15.0
0.4
200
2.5
0.9
0.1
DZN-2R5D904F4T
6.3×14.0
0.4
300
2.5
1.0
0.1
DZN-2R5D105G3T
8.0×12.0
0.3
150
2.5
1.0
0.1
DZN-2R5D105G4T
8.0×15.0
0.3
150
2.5
1.0
0.1
DZN-2R5D105T
8.0×22.0
0.3
120
2.5
2.7
0.2
DZN-2R5D275G5T
8.0×22.0
0.3
120
2.5
3.3
0.2
DZN-2R5D335H5T
10.0×20.0
0.2
60
2.5
3.3
0.2
DZN-2R5D335T
12.5×23.0
0.2
60
2.5
4.7
0.3
DZN-2R5D475H5T
10.0×20.0
0.1
70
2.5
4.7
0.3
DZN-2R5D475T
12.5×31.5
0.1
35
6.8
0.4
DZN-2R5D685H7T
10.0×30.0
0.1
40
0.5
DZN-2R5D106H8T
10.0×35.0
0.1
35
30
2.5
2.5
10
2.5
10
0.5
DZN-2R5D106Z8T
12.5×36.5
0.1
2.5
10
0.5
DZN-2R5D106T
18.0×35.0
0.1
25
2.5
15
0.7
DZN-2R5D156J5T
16.0×20.0
0.1
30
2.5
DZN-2R5D206K8T
18.0×35.0
0.1
25
2.5
DZN-2R5D206T
18.0×40.0
0.1
22
0.8
DZN-2R5D226J6T
16.0×25.0
0.1
25
2.5
30
0.8
DZN-2R5D306K9T
18.0×40.0
0.1
25
2.5
33
0.8
DZN-2R5D336J8T
16.0×35.5
0.1
25
2.5
50
1.0
DZN-2R5D506T
25.0×40.0
0.03
15
2.5
100
1.0
DZN-2R5D107S37T
25.0×50.0
0.03
15
2.5
100
1.0
DZN-2R5D107T
35.0×50.0
0.03
8
2.5
200
2.0
DZN-2R5D207S57T
35.0×50.0
0.03
8
We tailor packaged product in series and parallel arrangements according to voltage and capacitance as required.
Standard Ratings (Series DZ 2.7V)
Internal resistance
(Ω max.) at 1kHz
ELNA Parts No.
φD×L (mm)
2.7
0.7
0.2
DZN-2R7D704G4T
8.0×15.0
0.4
200
2.7
0.9
0.2
DZN-2R7D904F4T
6.3×14.0
0.4
300
2.7
1.0
0.2
DZN-2R7D105G3T
8.0×12.0
0.3
150
2.7
1.0
0.2
DZN-2R7D105G4T
8.0×15.0
0.3
150
2.7
1.0
0.2
DZN-2R7D105G5T
8.0×22.0
0.3
120
2.7
2.7
0.3
DZN-2R7D275G5T
8.0×22.0
0.3
120
2.7
3.3
0.3
DZN-2R7D335H5T
10.0×20.0
0.2
90
2.7
3.3
0.3
DZN-2R7D335Z6T
12.5×23.0
0.2
60
2.7
4.7
0.4
DZN-2R7D475H5T
10.0×20.0
0.1
70
2.7
4.7
0.4
DZN-2R7D475Z7T
12.5×31.5
0.1
35
6.8
0.5
DZN-2R7D685H7T
10.0×30.0
0.1
40
0.6
DZN-2R7D106H8T
10.0×35.0
0.1
35
30
2.7
2.7
10
2.7
10
0.6
DZN-2R7D106Z8T
12.5×36.5
0.1
2.7
10
0.6
DZN-2R7D106K8T
18.0×35.0
0.1
25
2.7
15
0.8
DZN-2R7D156J6T
16.0×25.0
0.1
40
2.7
DZN-2R7D206K8T
18.0×35.0
0.1
25
2.7
DZN-2R7D206K9T
18.0×40.0
0.1
25
2.7
22
1.0
DZN-2R7D226J7T
16.0×31.5
0.1
25
2.7
30
1.0
DZN-2R7D306K9T
18.0×40.0
0.1
25
2.7
33
1.0
DZN-2R7D336J9T
16.0×40.0
0.1
25
NOTE
205
CAT.No.2013/2014E
很抱歉,暂时无法提供与“DZN-2R7D335Z6T”相匹配的价格&库存,您可以联系我们找货
