Effective May 2016
Supersedes December 1998
Technical Data 1035
BUSSMANN
SERIES
Edison base plug fuses – time-delay, 125 volts,
15-30 amps
Recommended fuse holders
Catalog
numbers
SOU
SRU
SSU
SOW
SRW
SSW
SOX
Catalog symbol:
TL - (amps)
BP/TL - (amps)
TL - (amps)RK4
SRX
Bussmann series time-delay, loaded link
Edison base plug fuse.
2 3/4”
handy
4”
octagon
Type
box
4”
square
Single
gang
SSN
Quantity
Weight
Amp
ratings
Per
box
Per
card
Per
box
Per 5
cards
15 to 30 A
4
3
0.24
1.04
Features:
Specifications:
Ratings
Volts — 125 Vac or less
Amps — 15 to 30 A
Interrupting rating — 10 kA RMS Sym
Agency Information
UL® Listed, Std. 248-11, Guide JEFV, File
E12112
CE
Catalog numbers (amps)
TL - 20
2 1/4”
handy
Catalog
numbers
SOY
SRY
SSY
SSY-RL
STY
SCY
SOY-B
Package quantity and weight
Description:
TL - 15
Type
box
TL - 25
TL - 30
Medium duty time-delay plug fuse
Will withstand typical motor starting surges
Use in residential or light-duty circuits that
contain electric motors
Edison base size
These fuses thread into fuse receptacles or
box cover units for supplemental protection
Technical Data 1035
time-delay, 125 volts, 15–30 amps
Effective May 2016
15
30
Time-current curve – average melt
100
Amp
rating
Time in seconds
10
1
2000
1000
100
10
0.01
4
0.1
Current in amps
The only controlled copy of this Data Sheet is the electronic read-only version located on the Eaton Network Drive. All other copies of this
document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical
information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction
of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice,
any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible
applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
Eaton.com/bussmannseries
© 2016 Eaton
All Rights Reserved
Printed in USA
Publication No. 1035 – SB98107
May 2016
For Eaton’s Bussmann series
product information,
call 1-855-287-7626 or visit:
Eaton and Bussmann are valuable
trademarks of Eaton in the US and other
countries. You are not permitted to use the
Follow us on social media to get the
Eaton trademarks without prior written
latest product and support information.
consent of Eaton.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
很抱歉,暂时无法提供与“TL-20PK4”相匹配的价格&库存,您可以联系我们找货
