655
    GREENLEECOMMUNICATIONS(格林利)
    LAMP INCAND T3.25 GLSS WEDGE 28V
655 数据手册
CUTTER KIT, HOLE-CARBIDE • • 7/8, 1-1/8, 1-3/8, 1-3/4, 2Cutter Heads Arbor, Hex Key and Case Cat No: 655 UPC No: 783310058205 Description • • • • • • • • Cuts stainless steel quickly and easily Quick Change arbor allows you to change cutter heads with a simple push and a turn. Use the same arbor for differentsize cutting heads Removable cutter heads available in sizes from 5/8 IN through 3 IN Flange stop prevents over-drilling Ejector spring on all sizes above 3/4 IN makes removal of slug easier Replaceable, cobalt-steel pilot drill with split-point tip to prevent walking Precision carbide teeth for optimum performance and durability Minimum chuck size of 3/8 IN Specifications • • Includes : ƕ 7/8 IN, 1-1/8 IN, 1-3/8 IN Cutter Heads ƕ Arbor, Hex Key, Case, Set Screw, Ejector Spring Replacement Part : 3581 3 MM Hex Key, 54274 Set Screw, 55225, 1/2 IN Ejector Spring
很抱歉,暂时无法提供与“655”相匹配的价格&库存,您可以联系我们找货
