Telpower® DC Power Protection Systems
Telpower® DC Power Distribution Fuses
Bussmann®
TPB
170 Volts DC, 1000-2000 Amps
Catalog Symbol: TPB
Current-Limiting
Ampere Rating: 1000 to 2000A
Voltage Rating: 170Vdc
Interrupting Rating: 100,000A
Agency Information:
UL Recognized, Guide JFHR2, File E91958
Catalog Number
TPB-1000-E
TPB-1000-M
TPB-1200-E
TPB-1200-M
TPB-1600-E
TPB-1600-M
TPB-2000-E
TPB-2000-M
Amp
1000
1000
1200
1200
1600
1600
2000
2000
Qty.
1
1
1
1
1
1
1
1
Weight*
Lbs.
4.25
4.25
4.25
4.25
4.25
4.25
4.25
4.25
Kg.
1.9
1.9
1.9
1.9
1.9
1.9
1.9
1.9
* Weight per carton.
General Information:
• Telpower® BLUE™ label fuses are specifically designed
for dc power distribution systems.
• Minimum I2t short-circuit let-through levels.
• Current-limiting capability.
• Complete system coordination capability.
Mounting Alignment
TPB fuses are not meant as fixing isolators. Excessive push,
pull and tensional forces due to misalignments between fuse
and bus bars, which might occur like in the example shown
below, should be avoided. If possible the fuse installation
should be made starting with a fixed input busbar. The fuse
should then be mounted to the input busbar, followed by the
output busbar. Finally, the output busbar should be rigidly
fixed within the system equipment.
TABLE A
PART NUMBER
TPB-1000-E
TPB-1200-E
TPB-1600-E
TPB-2000-E
TPB-1000-M
TPB-1200-M
TPB-1600-M
TPB-2000-M
AMP
TIGHTENING TORQUE
THREADS
RATING
1000
1200
ENGLISH
29 lbf-ft 14.7 lbf-ft
1600
3/8-24 x .590DEEP
2000
1000
1200
METRIC
40N-m
20N-m
1600 M10 x 15mm DEEP
2000
Bussmann recommends a calibrated torque wrench with a
tolerance of max. ±4%.
*) Ungreased thread
**) Thread greased with Rhodorsil Paste 4 (Rhone-Poulenc) etc.
Tightening torque and contact pressure
TPB fuses are electro-mechanical devices. Their function is
very much dependent of the quality of the contact between
the fuse and the connecting bus bars. A poor thermal connection can result in overheating of the fuse and reduced lifetime. The number one rule is therefore to observe the right
tightening torque when mounting the fuse. See Table A.
Fuses with flush end contacts
For all types of flush end fuses Bussmann recommends
(screw in) studs. The studs must be tightened carefully applying a torque of 5-8Nm (3.7 -5.9 lbf-ft). As a general rule the
tightening torque for the nuts relates to the dimension of the
threaded hole in the fuse contact. See Table A for the recommended nut tightening torques.
The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin
is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change
design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained
in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
3-26-03
SB03087
Look for Telpower® BLUE™ fuses exclusively from Cooper Bussmann.
Form No. TPB
Page 1 of 2
Data Sheet: 5025
Bussmann®
TPB
Time-Current Characteristic Curve–Average Melt
3-26-03
SB03087
Form No. TPB
Page 2 of 2
Data Sheet: 5025
很抱歉,暂时无法提供与“TPB-1600-E”相匹配的价格&库存,您可以联系我们找货
