183a
Data Sheet
03.10
True RMS DMM with capacitance, low-pass
183a filter, duty cycle, and temperature
Test the TPI advantage
• True RMS DMM
• Duty cycle (% pulse
width modulation) for
measuring modulating
gas valves
• Low pass filter for noisy
environments
• Separate fuse (2) and
battery compartment
• IR serial interface that
can be used to input data
to PC with optional A183
• High resolution (0.01)
low DC microamp range
for measuring flame
safety control circuit
• Frequency, capacitance,
temperature, data hold,
min/max record, relative
mode
• AC/DC volts, AC/DC
amps, resistance,
audible continuity
and diode test
• CAT II - 1000V
• CAT III - 600V
• cULus 61010-1
• True RMS for more accurate measurements
• Duty cycle (% pulse width modulation) for
measuring modulating gas valves
• Low pass filter for noisy environments
• Separate fuse and battery compartment
Separate Fuse
Compartment
Protective Boot
• 3 year limited warranty
www.tpithevalueleader.com
Separate Battery
Compartment
Tilt Stand
Copyright © 2010 Test Products International, Inc.
TPI 183A
Range Selection
Auto / Manual
Display Specifications
4000 Count Display
Analog Bar Graph
Backlight
Basic Functions
AC / DC Volts, AC / DC Amps
Resistance, Diode Test
Audible Continuity
Additional Functions
True RMS, Frequency,
Capacitance,Temperature
Duty Cycle (% of pulse width
modulation (PWM))
Data Hold
Min / Max Record
Relative Mode
Active Low Pass Filter Function
PC Output
Sleep Mode / Auto Off
Additional Features
Frequency Check in Volt Mode
Closed Case Calibration
Separate Fuse / Battery Access
Protective Boot
Range & Resolution
Basic DC Accuracy
DC Voltage (maximum)
Input Impedance
Resolution (maximum)
AC Voltage (maximum)
Input Impedance
DC Amps (maximum)
AC Amps (maximum)
Resistance (maximum)
Frequency (maximum)
Temperature (maximum)
Capacitance (maximum)
Duty Cycle
Agency Approval
CE IEC 61010
cULus 61010
List Price
0.5%
1000V
10M
0.01mV
750V
10M
0.01mV
10A
0.01A
10A
0.1A
40M
0.1
10MHz
0.01Hz
2372°F
0.1°F
4000F
0.01nF
0.1 to 99.9%
CAT II 1000V /
CAT III 600V /
$159.95
PC OUTPUT:
Isolated optical to
USB output (Optional
A183 cable &
software required)
Hz / DUTY:
Select between
frequency and duty
cycle while measuring
AC volts
4000 count
display with
analog bargraph
and backlight
REL:
Display measured
values relative to a
stored value
RANGE:
Select between
auto and
manual ranging
HOLD /
Freezes measured
values on the display
/ Activates the
backlight
REC:
Display the
minimum and
maximum
reading being
measured
LPF:
Activates the low
pass filter.
FUNCTION:
Use to select
between multiple
functions at each
selector position
LOW DC
MICROAMP
RANGE:
High resolution (0.01uA)
range for flame safety
measurements
RESISTANCE,
CONTINUITY
BUZZER, DIODE
TEST
CAPACITANCE:
Test capacitors
AC VOLTS:
Measure AC
voltage, frequency,
and duty cycle
TEMP:
TPI 183A comes with:
A085
silicone test leads
with alligator clips
A106 temperature input
adapter
GK11M beaded K-type tem
perature probe
Photo is actual size
With Protective Boot
3.4” x 7.4” x 1.3"
Measure temperature
(K-type thermocouple
and banana adapter
included)
很抱歉,暂时无法提供与“183A”相匹配的价格&库存,您可以联系我们找货
