Tuffman Pressure Meter
TPI 635 / 645 / 655
Visit TPI, The Value Leader at:
www.tpi-thevalueleader.com
Table of Contents
Page 3 Introduction & Product Description
Page 4 Safety Considerations
Page 5 Technical Data & International Symbols
Page 6 Features & Benefits
Page 7 Pressure Conversion Table
Page 8 Step by Step Procedures
Page 9 Accessories & Specifications
Page 10 Maintenance
Page 11 Trouble Shooting Guide EC declaration of conformity
Page 12 Warranty Statement
page 1
Introduction
Congratulations!
Thank you for purchasing TPI brand products. This meter is easy to use
and is built to last. It is backed by a 3 year limited warranty. Please
remember to return your product warranty registration card.
Product Description
The TPI 600 Tuffman series is a hand held range Of pressure meters and
can be summarized as follows.
TPI 635 5 PSI pressure range
TPI 645 30 PSI pressure range
TPI655 100 PSI pressure range
All of these models are dual input differential pressure meters with 7
selectable scales to choose from: mbar, kPa, PSI, inHg. mmHg,inH20,
and mH20.
page 2
WARNING: Please follow the manufacture's test procedure whenever
possible. Make sure the pressure to be measured is not outside the
range of the TPI 635/645/655 meter.
General Guidelines
ALWAYS
• Test the pressure meter before use to ensure it is operating properly
• Ensure that the connecting hose you are using is free from kinks or splits
• Double check all connections before testing
NEVER
• Connect the instrument to an unknown pressure source if the source is
twice the working pressure of the instrument the sensor will be damaged
and may cause injury to the user
• Tamper with the instrument or attempt to modify it in any way.
Otherwise accident and injury may occur and the warranty be
comes void.
page 3
Technical Data
Controls TPI 635/645/655
ON
OFF
ZERO
MAX/MIN
HOLD
UNITS
page 4
Switches instrument "ON" for use
Switches instrument "OFF" after use
Automatically "zero's" the instrument
Smoothing function to stabilize rapidly changing readings
Enables user to recall & display both the maximum and
minimum pressure recorded since the function was selected.
Press button once to activate, twice to read minimum and
three times to read the maximum. To cancel the function press
and the hold the "MAXIMIN" button
Maintains the reading on the LCD display
Selects 7 units of measure kPa, PSI, inHg, mmHg, inH20,
mH 20, mbar
Features & Benefils
Auto rangingProvides high resolution & accuracy at low pressures
where it is needed
Auto Power Off- Powers off after 30 minutes to conserve battery life.
Trim ModeSmoothing function to stabilize erratic readings.
It displays the average value of 4 values previously
measured.
Zero functionProvides immediate push-button zeroing for Speed
and accuracy.
Record Max/Min- Enables long term testing of pressure systems for leaks
HoldEnables the user to freeze the display reading, when
working in cramped working conditions, when the
display is not visible.
UnitsChange the display value in anyone of the following
engineering units. kPa, PSI, inHg, mmHg, inH20,
mH20 and mbar.
page 5
Atmos
Atmos
1
mbar
1013.25
in H20
406.8
inHg
29.9213
PSI
14.6959
mH20
10.3323
mmHg
kPa
page 6
760
101.325
mbar
inHg
inH20
9.86923
x 10-4
3.34207
X 10-2
2.45832
X 10-3
2.95301
x 10-2
1
7.35561
X 10-2
1
0.401463
33.8638
13.5951
1.45038
x 10-2
0.491153
1.01972
x 10-2
0.345315
0.750064
0.1
25.4
3.38638
2.49089
1
3.61273
X 10-2
1.86833
2.54
X 10-2
0.249089
PSI
mmHg
mH20
kPa
6.8046
X 10-2
1.31579
X 10-3
9.67841
X 10-3
9.86923
X 10-3
2.036
3.937
X 10-2
2.89591
0.295301
39.3701
4.01463
1.42233
0.145038
73.5561
7.50064
1
0.101972
9.80665
1
68.9476
27.68
1
51.715
0.70307
6.89476
1.33322
0.534
1.934
X 10-2
1
1.35951
X10-2
0.133322
98.0665
10
• Press the "ON" key and the LCD display will be activated if it does not
read 0.00 proceed as follows
• Press the "zero" key and the display should read zero. if not repeat
until it does
• Connect pressure meter to installation or equipment to be tested using
appropriate hose connection in accordance with the manufactures
instructions
• The pressure reading will appear on the display. To activate the backlight
in poor light conditions press the "ON' key at any time
• If the reading is erratic or changing activate the smoothing unction by
pressing the" =" key
• To freeze a reading in awkward or cramped working spaces press
the "Hold" key
• To record maximum & minimum pressures when establishing
pressure decay or carrying out gas line soundness testing press the
"MAXIMIN" key
• To convert the displayed pressure reading to another engineering unit
depress the "Unit" key anytime and scroll through to the desired units
of pressure.
page 7
Standard Accessories
9V ALKALINE battery
Replacement tubing t/4" 00 x 28"(L)
Optional Accessories
Replacement tubing 1/4' 00 x 28" T Fitting
Large Zippered Case
9V lithium battery
Part No.
A009A
A601
Part No.
A605
A904
U9VL
Features
Model
635
645
655
Range
5 PSI
30 PSI
100 PSI
Accuracy
±O.2'% of full scale +3 digits
Over Pressure 14.5 psi (1000 mbar)
58.0 psi (4000 mbar) 145 psi (10 bar)
Power Supply
9V
Relative Humidity
0% to 80% (a· to + 40°C)
Operating Temp.
32° to 104°F (D' to +40°C)
Storage Temp.
14° to 122°F (-10"10 + 50'C)
Auto Power Off
After 30 minutes
Trim Mode
Yes
Zero Adjust
Yes Push Button
Data Hold
Yes
Record
Yes Max/Min
page 8
Maintenance
Battery Replacement
The 635/645/655 will display a iBATi symb 01 when the internal 9V battery
needs replacement. Replace battery as follows:
1. Ensure instrument is switched off
2. Loosen the cross head screw on the battery compartment cover
3. Remove battery compartment cover
4. Remove old battery
5. Replace with new battery 9V NEDA 1604 or equivalent
6. Reassemble the instrument in reverse order from above
7. RE-fit the cross head screw being sure not to over tighten
Cleaning
Use a mild detergent and a slightly damp cloth to clean the surfaces of the
instrument.
page 9
Problem
Pro
Unit does not zero
Unit still does not zero
iBati appears on the display
bable Cause
Zero button has not been operated
If reading is greater than 0.05 and
constantly fluctuation return to
local service centre
Replace battery immediately 9V NEDA
15050cequivalent
EC Declaration 01 Conformity
This is to certify that model 634/645/655 conform to the protection
requirements of the council directive 89/336/EEC, in the approximation of
laws of the member states relating to Electromagnetic compatibility by
application of the following standards
EN50081-1 1992 Emissions Standard
EN50082-1 1992 Immunity Standard
To ensure conformity with these standards, this instrument must be
operated in accordance with the instructions and specifications given in
this manual.
page 10
Warranty Statement
3 Year Limited Warranty
This TPI product is warranted to the purchaser against defect in materials
and workmanship for 3 years from the date of purchase.
Covered by TPI: Repair parts and labour; or replacement of the product at
the option of TPI. Normal transportation charges to the purchaser are also
covered.
Not covered by TPI: Damage to the product which are the result of abuse,
improper use or maintenance are not covered. Any other expense, consequential damages, incidental expenses including damages to property is
not covered. Transportation expense to the company are not covered.
To obtain warranty performance: include with the product your name,
address, phone number, written description of the problem and proof of
purchase date. Carefully package and return to the address printed below.
Test Products International, Ltd.
342 Bronte Sl. South Unit #9
Miltoll, Ontario L9T 5B7
Canada
905-693-8558 Fax: 905 -693-0888
e-mail: inlo@lpicanada.com
page 11
Test Products International, Inc
Headquarters
9615 SW AIlen Blvd.
Beaverton, OR 97005
USA
503-520-91971 Fax: 503-520-1225
e-mail: inlo@tpi-lhevalueleader.com
很抱歉,暂时无法提供与“645”相匹配的价格&库存,您可以联系我们找货
