708
Data Sheet
02.11
708 Combustion Analyzer
Test the TPI Advantage
Features
Specifications
QUICK AND SIMPLE
SET UP All TPI
analyzers feature
quick and simple
set up. Fast purge
and the ability to
perform fuel
selectionduring start
up enable tests to be
performed quickly
without requiring
extra set-up time
after initial startup.
TPI analyzers also
use the last selected
fuel as the default
setting. This feature
prevents the need
toperform fuel
selection every
time the analyzer
is turned on.
• Calculates
combustion
efficiency
• Pump driven for
fast response
• Will not shut off if
15 ppm CO is
present for
increased safety
• Ten selectable fuels
• Optional A740 IR
printer available for
hard copies of test
results
• Built-in differential
thermometer
• Store function to
save up to 50
readings
• Store function to
save up to 50
readings
• Large easy to read
backlit display
www.tpithevalueleader.com
Instrument
Operating Temperature Range
14°F to +122°F (-10°C to +50°C)
Battery / Batery Life
AA (3) / > 6 Hours
Fuels
Natural Gas, LPG, Light Oil, Heavy
Oil, Bituminous Coal, Anthracite
Coal, Coke, Butane, Wood, Bagasse
Gases
Oxygen
Carbon Monoxide
Carbon Dioxide
CO/CO2 Ratio
Combustion Eff.
Display
3 Line Backlit LCD w/ annunciators
Data Storage
50 sets of readings
Time & Date
24 Hour Real Time Clock
Dimensions
7.8” x 3.5” x 2.4”
Weight
1.1lbs
Range
0-25%
0-10,000 ppm
0-25%
0-0.999
0-100%
Temperature Measurement
Input Type
Range
Resolution
Accuracy
A787 Soft Carrying Case
GK11M K-type
thermocouple
Copyright © 2010 Test Products International, Inc.
Resolution
0.1%
1 ppm
0.1%
0.001
0.1%
Accuracy
+/- 0.3%
+/- 5 ppm or 5%
Calculated
Calculated
Calculated
K-Type thermocouple
-58°F to 1832°F (-50°C to 1000°C)
1°F (1°C)
+/- (0.3% of rdg + 2°F) or +/- (0.3% of rdg + 1°C)
A763 Mini pump
protection filter
A770 Flue Probe
很抱歉,暂时无法提供与“708C7”相匹配的价格&库存,您可以联系我们找货
