708C9
708C9
    TPI(TPI 公司)
    Gas Analyzer For Measuring Combustible Gases Includes Boot, Case, Filter, Probe, Spigot, Thermocoupl...
708C9 数据手册
708 Data Sheet 02.11 708 Combustion Analyzer Test the TPI Advantage Features Specifications QUICK AND SIMPLE SET UP All TPI analyzers feature quick and simple set up. Fast purge and the ability to perform fuel selectionduring start up enable tests to be performed quickly without requiring extra set-up time after initial startup. TPI analyzers also use the last selected fuel as the default setting. This feature prevents the need toperform fuel selection every time the analyzer is turned on. • Calculates combustion efficiency • Pump driven for fast response • Will not shut off if 15 ppm CO is present for increased safety • Ten selectable fuels • Optional A740 IR printer available for hard copies of test results • Built-in differential thermometer • Store function to save up to 50 readings • Store function to save up to 50 readings • Large easy to read backlit display www.tpithevalueleader.com Instrument Operating Temperature Range 14°F to +122°F (-10°C to +50°C) Battery / Batery Life AA (3) / > 6 Hours Fuels Natural Gas, LPG, Light Oil, Heavy Oil, Bituminous Coal, Anthracite Coal, Coke, Butane, Wood, Bagasse Gases Oxygen Carbon Monoxide Carbon Dioxide CO/CO2 Ratio Combustion Eff. Display 3 Line Backlit LCD w/ annunciators Data Storage 50 sets of readings Time & Date 24 Hour Real Time Clock Dimensions 7.8” x 3.5” x 2.4” Weight 1.1lbs Range 0-25% 0-10,000 ppm 0-25% 0-0.999 0-100% Temperature Measurement Input Type Range Resolution Accuracy A787 Soft Carrying Case GK11M K-type thermocouple Copyright © 2010 Test Products International, Inc. Resolution 0.1% 1 ppm 0.1% 0.001 0.1% Accuracy +/- 0.3% +/- 5 ppm or 5% Calculated Calculated Calculated K-Type thermocouple -58°F to 1832°F (-50°C to 1000°C) 1°F (1°C) +/- (0.3% of rdg + 2°F) or +/- (0.3% of rdg + 1°C) A763 Mini pump protection filter A770 Flue Probe
708C9 价格&库存
很抱歉,暂时无法提供与“708C9”相匹配的价格&库存,您可以联系我们找货
