265
Product Sheet
09.10
265 Clamp-On Tester with Frequency
and Capacitance
Delivering test and measurement advantages for HVAC/R professionals worldwide
Test the TPI advantage
APPLICATIONS
Why pay more?
Test start and run
capacitors
Perfect for tight, narrow, spaces...
The new TPI 265 with slim jaw and body is
Measure motor run
current
ideal for cramped work areas and crowded
electrical panels.
Measure heat
anticipator current
Features
Determine
thermocouple
voltage
Slim jaw and body design for use in crowded
electrical panels
Test line and control
voltages
4,000 count display
Capacitance range up to 4,000 microfards to
Measure heating
element resistance
test run and start capicitors
Measure and adjust
variable frequency
drives
0.1 DC millivolt resolution to accurately
measure thermocouples and use optional
adapters
0.01 AC Amp resolution to measure heat
anticipator current
Frequency measurement capability
AC/DC volts up to 600V and AC Amps up to 400A
Diode, resistance and audible continuity ranges
ALL THESE PLUS!!
• Auto / manual ranging
Turn over for
technical
information
and accessory
part numbers.
The
Value
Leader™
Copyright © 2010
• Data hold
• Auto power off
• CAT III 600V rated
• cULus 61010
• 3-Year Limited Warranty
Shown Actual Size: 8” x 3”
265
Product Sheet
09.10
and Capacitance
TPI offers a
complete line of…
CO, Combustibles &
Combustion (CEA)
Refrigerant Leak
Detectors
Digital Manometers
Temperature Contact
& IR Instruments
IAQ: Air Flow /
Humidity
Handheld
Oscilloscopes
Instrument Specifications
Basic DC Accuracy:
DC Voltage (maximum):
Resolution (maximum):
AC Voltage (maximum):
AC Amps (maximum):
Resistance (maximum):
Frequency (maximum):
Capacitance (maximum):
Diode:
Continuity:
Digital Multimeters
& Clamp-on Meters
Agency Approval:
Overall Dimensions:
Accessories & Kits
Weight:
Standard Accessories
A040
A265
Optional Accessories
A202
A771
A620
TLS2000RB
A301
A312
A213
Test Products
International, Inc.
Headquarters:
9615 SW Allen Blvd.
Beaverton, OR 97005
USA
503-502-9197
Fax: 503-520-1225
info@tpi-thevalueleader.com
Test Products
International, Ltd.
342 Bronte St. South
Unit 9
Milton, Ontario L9T
5B7
Canada
905-693-8558
Toll-Free: 866-693-8558
Fax: 905-693-0888
0.5%
600V
0.1mV
600V
0.1mV
400A
0.01A
40M
0.1
400MHz
0.001KHz
4,000F
0.001nF
Test Current Max 1.5mA
Buzzer sounds at
很抱歉,暂时无法提供与“A040”相匹配的价格&库存,您可以联系我们找货
