PaHUB2
SKU:U040-B
Description
PaHUB2, is an I2C Expandable Hub, which can expand a single I2C HY2.0-4P
interface and connects up to 6 I2C channels. It allows you to mount slave devices
with the same I2C address (by polling control the different channels to achieve
in-device coexistence). Embedded PCA9548AP-I2C multi-channel switch IC, Save
you worries with insufficient I2C interface of the expansion.
Note: When it's connected, the PaHUB2 will be polling control the different
channels to achieve in-device coexistence. Please pay attention to the order of
channels when programming.
Product Features
o
I2C HY2.0-4P PORTA expansion
o
2x LEGO compatible holes
o
Support multiple nesting
o
1-6 expansion
Please refer to the schematic and PCA9548AP data manual, the Unit can modify
the I2C address of the device by adapting the level combination of A0~A2 pins.
(The default address is 0x70)
3 Position of Welding patch are reserved on the PCB board of the Unit, A0-A2
respectively, as shown in the figure below.
After welding the 0 ohm resistor, the corresponding pin will change from low
level to high level. The pin level combination and its corresponding I2C address
are shown in the table below.
Include
o
1x Pahub2 Unit
o
1x HY2.0-4P Cable
Application
o
I2C device expansion
Specification
Specifications
Parameters
Channel Control IC
PCA9548AP
Communication
I2C: 0x70 (can be modified by resistance A0, A1,
protocol
A2)
Net weight
7g
Gross weight
19g
Product size
48 * 24 * 12mm
Packing size
67 * 53 * 12mm
Schematic
Related Link
o
Datasheet
o
PCA9548AP
EasyLoader
Click to download EasyLoader
1.EasyLoader is a concise and fast program burner, which contains the test
program used by Pahub2 & M5Core.
https://docs.m5stack.com/en/unit/pahub2
很抱歉,暂时无法提供与“U040-B”相匹配的价格&库存,您可以联系我们找货
