UPGRADE
DZ,DZH
DZ,DZH
ELECTRIC
DOUBLE
LAYER
CAPACITORS
“DYNACAP”
ELECTRIC
DOUBLE
LAYER
CAPACITORS
“DYNACAP”
Standard, Large Capacitance Type Capacitors
Pollution-Free ; with no pollutants such as Cd or Pb.
Unlike batteries ; excellent charge and
discharge characteristics with no chemical
reactions
60˚C
GREEN
CAP
2.5V
70˚C
2.7V
Large capacitance
DZH
Specifications
DZ
Marking color : White print on a black sleeve
Item
Performance
Series name
Series DZ
Series DZH
Category temperature range (℃)
ー25 to +70
ー25 to +60
Tolerance at rated capacitance (%)
ー20 to +80
ー20 to +80
Internal resistance
at 1kHz
Refer to the following page
Characteristics at high and
low temperature
Endurance
Percentage of capacitance change
Within ±30% of the value at 20℃
Internal resistance
Less than five times of the value at 20℃
Internal resistance
Test temperature
70℃
Test temperature
60℃
Test time
1000 hours
Test time
2000 hours
Within ±30% of the initial measured value
Internal resistance
Less than four times of the initial specified value
Internal resistance
Shelf life
Same as endurance
Less than eight times of the value at 20℃
Same as endurance
Applicable standards
Conforms to JIS C5160-1 2009 (IEC 62391-1 2006)
Outline Drawing
Unit : mm
2‒φ2
Sleeve
φD+1max.
F±0.5
φD+0.5max.
16
7.5
0.8
1
α
8
10 12.5
3.5
5.0
0.6
2.0
0.
6.3
2.5
1.5±0.1
Markings
L+2max.
6.3±1
Vent
18
φD
F
φd
5
min.
15min.
10
10
L+α max.
Lug terminal details
0.9±0.1 Thickness : 0.8t
2.6
φd±0.05
copper clad steel wire (tinned)
Sleeve
Vent
φ25, 35
6.8
7.5
φ6.3 to φ18
(‒) Negative terminal
indicated by cross notching
Position of printed
circuit board holes
2.1
Part numbering system (example : 2.5V10F)
DZ
Series code
2R5
D
106
(Z6)(S)
Max. operating voltage
symbol
Terminal
code
Rated capacitance
symbol
Casing
symbol
T ̶
Taping (Forming)
symbol
Part number is refer to the following page.
EDLC
CAT.No.2015/2016E
212
NOTE : Design,
Specifications are subject to change without notice.
It is recommended that you shall obtain technical specifications
from ELNA to ensure that the component is suitable for your use.
Standard Ratings (Series DZ 2.5V)
Max. operating voltage (V) Rated capacitance (F) Max. Leakage Current (mA) after 24h
ELNA Parts No.
φD×L (mm)
DZ,DZH
Internal resistance
(Ω max.) at 1kHz
UPGRADE
ELECTRIC DOUBLE LAYER CAPACITORS “DYNACAP”
Internal resistance (mΩ)
at 1kHz (measurement value)
2.5
1
0.1
DZ-2R5D105F4T
6.3×14
1.0
400
2.5
1
0.1
DZ-2R5D105G3T
8×12
1.0
200
2.5
2.7
0.2
DZ-2R5D275G5ST
8×20
0.5
150
2.5
3.3
0.2
DZ-2R5D335H5T
10×20
0.3
70
2.5
4.7
0.3
DZ-2R5D475H5T
10×20
0.2
80
2.5
5.6
0.3
DZ-2R5D565H5T
10×20
0.2
70
2.5
6.8
0.4
DZ-2R5D685H6T
10×25
0.2
60
40
2.5
10
0.5
DZ-2R5D106H8T
10×35
0.2
2.5
10
0.5
DZ-2R5D106Z6ST
12.5×25
0.2
40
2.5
15
0.7
DZ-2R5D156Z8ST
12.5×35
0.2
35
2.5
15
0.7
DZ-2R5D156J5T
16×20
0.2
35
2.5
22
0.8
DZ-2R5D226J6T
16×25
0.2
30
2.5
33
0.8
DZ-2R5D336J8T
16×35.5
0.2
30
2.5
40
0.8
DZ-2R5D406K9T
18×40
0.2
30
2.5
50
1.0
DZ-2R5D506T
25×40
0.08
100
1.0
DZ-2R5D107S37T
25×50
0.08
15
2.5
200
2.0
DZ-2R5D207S57T
35×50
0.08
15
We tailor packaged product in series and parallel arrangements according to voltage and capacitance as required.
Standard Ratings (Series DZ 2.7V)
ELNA Parts No.
φD×L (mm)
Internal resistance
(Ω max.) at 1kHz
2.7
1
0.2
DZ-2R7D105F4T
6.3×14
1.0
400
2.7
1
0.2
DZ-2R7D105G3T
8×12
1.0
200
2.7
2.7
0.3
DZ-2R7D275G5ST
8×20
0.5
150
2.7
3.3
0.3
DZ-2R7D335H5T
10×20
0.3
70
2.7
4.7
0.4
DZ-2R7D475H5T
10×20
0.2
80
2.7
5.6
0.4
DZ-2R7D565H5T
10×20
0.2
70
2.7
6.8
0.5
DZ-2R7D685H6T
10×25
0.2
60
40
2.7
10
0.6
DZ-2R7D106H8T
10×35
0.2
2.7
10
0.6
DZ-2R7D106Z6ST
12.5×25
0.2
40
2.7
15
0.8
DZ-2R7D156Z8ST
12.5×35
0.2
35
2.7
15
0.8
DZ-2R7D156J6T
16×25
0.2
35
2.7
22
1.0
DZ-2R7D226J7T
16×31.5
0.2
30
2.7
33
1.0
DZ-2R7D336J9T
16×40
0.2
30
Standard Ratings (Series DZH 2.5V)
ELNA Parts No.
2.5
22
0.8
DZH-2R5D226Z8ST
2.5
50
1.0
DZH-2R5D506K9T
φD×L (mm)
12.5×35
Internal resistance
(Ω max.) at 1kHz
0.2
55
18×40
0.08
30
2.5
100
2.0
DZH-2R5D107S35T
25×40
0.08
300
5.0
DZH-2R5D307S57T
35×50
0.08
15
EDLC
NOTE : Design,
213
CAT.No.2015/2016E
很抱歉,暂时无法提供与“DZ-2R5D206K8T”相匹配的价格&库存,您可以联系我们找货
