3 x AAA Battery Holder with On/Off Switch, JST,
and Belt Clip
PRODUCT ID: 3286
Description
This battery holder connects 3 AAA batteries together in series for powering all kinds of projects.
We spec'd these out because the box is slim, and 3 AAA's add up to about 3.3-4.5V, a very similar
range to Lithium Ion/polymer (Li-Ion) batteries, plus it has a nifty on-off switch. That makes them
ideal for use with 3.3V projects that have a 2-pin JST connector meant for one of our Li-Ion/Poly
batteries. (Of course, you can't recharge them like Li-Ion/Polys, so don't try to plug this into one of
our Li-Ion/Poly charger boards!) It also features an ergonomic belt clip for taking your power on
the go.
Fits any standard AAA battery. When using rechargeable NiMH the output voltage will range from
about 3.7V with charged batteries to 2.7V at the end of life with a nominal voltage of 3.6V. When
using alkalines, the output will range from 4.6V with new batteries to 3.3V at the end of life with a
nominal voltage of about 4.5V.
The polarity matches that of our 2-pin JST cable and Li-Ion/Poly batteries. Uses a genuine JST
connector so it wont 'catch and tear' in JST connectors.
Technical Details
Cable Length: 6" long, terminated with a genuine JST-PH 2 pin connector
Product Dimensions: 63.0mm x 37.0mm x 28.0mm / 2.5" x 1.5" x 1.1"
Product Weight: 24.6g / 0.9oz
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3286”相匹配的价格&库存,您可以联系我们找货
