FW72 series
72 Watt AC Adapter
6.50" [165mm]
3.85" [98 mm]
2.60" [66mm]
Features
Electrical Specifications
Wide range AC input
Fully regulated output
High efficiency
5 year warranty
RoHS compliant version available
Input
Voltage................................ 100 - 240 VAC
Current................................ 2.0 Amp @ 100 VAC
Frequency........................... 47 - 63 Hz
AC cord.............................. Optional
Input connector................... 3 Pin IEC 320 input receptacle
Environmental
Output
Line regulation.................... TYP +/- 1%
Load regulation................... TYP +/- 5%
Set point.............................. +/- 3% at 60% load
Hold up time........................ 20 ms min at full load, 115 VAC
Over voltage protection....... Built-in
Over current protection....... Built-in
Short circuit protection........ Pulsing mode, auto recovery
Efficiency............................. 80% min at full load and 115 VAC
Transient response............. 2 ms for 50% load change typical
Ripple/noise (Vp-p)............... +/- 1% (20 MHz bandwidth)
Output connector................ 5 pin DIN
Operating temperature.......... 0 C to 40 C
Storage temperature............. -55 C to 85 C
Weight = 2.5 lbs
EMI/EMC
Meets FCC class B, CISPR 22 class B
Safety
CSA Certified to CSA 950
NRTL/C : UL 1950, CSA 950
CE Marked
Polarity
DIN-5
1
2
3
DIN-5
4
Com Com +V Com
5
+V
1
3
4 2 5
Model No.
Polarity, 760:
FW7212-D5-NC
Com
FW7212-D5F-NC
+V
Ordering Information
FW =
72 =
XX =
D5 =
F=
NC =
Series
Watts DC Output
Voltage DC Output
Output Connector (options available)
RoHS Compliant
No AC input Cord (options available)
FW7224-D5-NC
Voltage Power Current
12V
72W
6.0A
24V
72W
3.0A
FW7224-D5F-NC
FW7224-760-NC
FW7224-760F-NC
Rev 1005
Elpac Power Supplies 1562 Reynolds Ave. Irvine, CA 92614 USA TEL +1 949-476-6070 www.elpac.com info@elpac.com
很抱歉,暂时无法提供与“FW7212-D5-NC”相匹配的价格&库存,您可以联系我们找货
