FW10024-D5-NC
FW10024-D5-NC
    INVENTUSPOWER
    AC/DC DESKTOP ADAPTER 24V 100W
FW10024-D5-NC 数据手册
FW100 series 96 Watt AC Adapter 6.50" [165mm] 3.85" [98 mm] Replace photo 2.60" [66mm] Features Electrical Specifications Wide range AC input Fully regulated output High efficiency 5 year warranty Input Voltage................................ 100 - 240 VAC Current................................ 3.0 Amp @ 100 VAC Frequency........................... 47 - 63 Hz AC cord.............................. Optional Input connector................... 3 Pin IEC 320 input receptacle Environmental Operating temperature.......... 0 C to 40 C Storage temperature............. -55 C to 85 C Weight = 2.5 lbs Output Line regulation.................... TYP +/- 1% Load regulation................... TYP +/- 5% Set point.............................. +/- 3% at 60% load Hold up time........................ 20 ms min at full load, 115 VAC Over voltage protection....... Built-in Over current protection....... Built-in Short circuit protection........ Pulsing mode, auto recovery Efficiency............................. 80% min at full load and 115 VAC Transient response............. 2 ms for 50% load change typical Ripple/noise (Vp-p)............... +/- 1% (20 MHz bandwidth) Output connector................ DIN (5 pin or 8 pin), 760 EMI Meets FCC class B, CISPR 22 class B Safety CSA Certified to CSA 950 NRTL/C : UL 1950, CSA 950 DIN-8 DIN-5 6 1 1 3 4 4 2 5 760 7 8 3 2 5 Model No. FW10012-D8-NC Polarity DIN-5 1 2 Com Com DIN-8 V1 V1 Voltage Power Current 12V 96W 8.0A 3 4 5 6 7 8 FW10024-D5-NC 24V 96W 4.0A +V Com +V - - - FW10024-760-NC 24V 96W 4.0A Com V1 Com V1 Com Com Polarity, 760: Com +V Rev 0404 Elpac Power Supplies 1562 Reynolds Ave. Irvine, CA 92614 USA TEL +1 949-476-6070 www.elpac.com info@elpac.com
FW10024-D5-NC 价格&库存
很抱歉,暂时无法提供与“FW10024-D5-NC”相匹配的价格&库存,您可以联系我们找货
