FW100 series
96 Watt AC Adapter
6.50" [165mm]
3.85" [98 mm]
Replace photo
2.60" [66mm]
Features
Electrical Specifications
Wide range AC input
Fully regulated output
High efficiency
5 year warranty
Input
Voltage................................ 100 - 240 VAC
Current................................ 3.0 Amp @ 100 VAC
Frequency........................... 47 - 63 Hz
AC cord.............................. Optional
Input connector................... 3 Pin IEC 320 input receptacle
Environmental
Operating temperature.......... 0 C to 40 C
Storage temperature............. -55 C to 85 C
Weight = 2.5 lbs
Output
Line regulation.................... TYP +/- 1%
Load regulation................... TYP +/- 5%
Set point.............................. +/- 3% at 60% load
Hold up time........................ 20 ms min at full load, 115 VAC
Over voltage protection....... Built-in
Over current protection....... Built-in
Short circuit protection........ Pulsing mode, auto recovery
Efficiency............................. 80% min at full load and 115 VAC
Transient response............. 2 ms for 50% load change typical
Ripple/noise (Vp-p)............... +/- 1% (20 MHz bandwidth)
Output connector................ DIN (5 pin or 8 pin), 760
EMI
Meets FCC class B, CISPR 22 class B
Safety
CSA Certified to CSA 950
NRTL/C : UL 1950, CSA 950
DIN-8
DIN-5
6
1
1
3
4
4 2 5
760
7
8
3
2
5
Model No.
FW10012-D8-NC
Polarity
DIN-5
1
2
Com Com
DIN-8
V1
V1
Voltage Power Current
12V
96W
8.0A
3
4
5
6
7
8
FW10024-D5-NC
24V
96W
4.0A
+V
Com
+V
FW10024-760-NC
24V
96W
4.0A
Com
V1
Com
V1
Com Com
Polarity, 760:
Com
+V
Rev 0404
Elpac Power Supplies 1562 Reynolds Ave. Irvine, CA 92614 USA TEL +1 949-476-6070 www.elpac.com info@elpac.com
很抱歉,暂时无法提供与“FW10024-D5”相匹配的价格&库存,您可以联系我们找货
