96W TRV-096 Series
Switch Mode LED Drivers
Constant Voltage
Aluminum Housing
Electrical Specifications
Input Voltage Range:
100 - 277 Nom. Vac (90 - 305 V Min/Max)
Frequency:
50/60 Hz Nom. (47-63 Hz Min/Max)
Power Factor:
>0.90 @ full load, 100V through 277V
Input Current:
1.20 A @ 100Vac, 0.60 A @ 220VAC
Inrush Current:
50 A @ 230Vac
Maximum Power:
96W
THD:
_ 20% @ full load
Line Regulation:
± 1%
Load Regulation:
± 2%
Typical Efficiency
88-90% @ full load
Turn-on Delay:
0.80S
Protection:
Over-Voltage, Over-Current, Over-Temperature (110°C),
and Short Circuit Protection with Auto Recovery
• Total Power: 96 Watts
• Input Voltage: 100-277 Vac Nom.
• UL Dry, Damp & Wet Location Rated
• IP67
• Ultra-high Efficiency
• High Power Factor
• UL8750
Environmental Specifications
Minimum Starting Temp:
-35ºC
Maximum Case Temp.
89°C
Storage Temperature:
-40ºC to +85ºC
Humidity:
5% to 100%
Cooling:
Convection
Sound Rating:
Class A
MTBF:
400,000 Hours @ 25ºC, 80% load, 110 Vac on 24V model
Lifetime:
50,000 Hours @ 60ºC max case temperature
Weight:
1.87 lbs (850g)
Model Number
Max. Output
Current (A)
Output Voltage
(Vdc)
Max. Output
Power (W)
Typical
Efficiency
TRV-096S024ST
4.00
24
96
88%
TRV-096S036ST
2.66
36
96
89%
TRV-096S048ST
2.00
48
96
89%
TRV-096S054ST
1.77
54
96
90%
Class 2:
US/Canada
US Only
E332160
Note:
LED drivers are designed and intended to operate LED loads only.
Non-LED loading may be outside the specified design limits of our
LED drivers, and therefore cannot be covered by any warranty.
If you desire to use our LED drivers to operate non-LED loads
please contact us to discuss compatibility.
Specifications subject to change without notice.
Rev 8-27-15
Thomas Research Products • 1225 Bowes Rd • Elgin, IL 60123 • T 847-515-3057 • F 847-515-3047 • www.trpssl.com
TRV-096 Series
SSL Solutions Faster Than The Speed Of Light®
Pg 2 of 2
BLACK (ACL)
WHITE (ACN)
GREEN (GND)
AC INPUT(3*AWG #18)
RED (V+)
BLACK (V-)
Tc = 89°C max
DC OUT(2*AWG #18)
Safety and EMC Compliance
CUL
CE
UL 8750, UL923, UL1012, UL1310 Class 2
EN 61347-1, EN61347-2-13
EN 55015
Conducted emission
EN 61000-3-2
Harmonic current emissions
EN 61000-3-3
Voltage fluctuations and flicker
EN 61000-4-2
Electrostatic discharge
EN 61000-4-3
RFE Field Susceptibility test
EN 61000-4-4
Electrical Fast Transient
EN 61000-4-5
Surge Immunity test
EN 61000-4-6
Conducted Radio Frequency
EN 61000-4-8
Power Frequency Magnetic Field Test
EN 61000-4-11 Voltage Dips
EN 61547
Electromagnetic Immunity
很抱歉,暂时无法提供与“TRV-096S024ST”相匹配的价格&库存,您可以联系我们找货
