YR2.DIODE
YR2.DIODE
    PULS
    REDUNDANCYMODULE10-60VDC20A
YR2.DIODE 数据手册
YR2.DIODE DC 12-48V, 20A, DUAL REDUNDANCY MODULE Y-Series REDUNDANCY MODULE ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ Cost Effective Solution to Build Redundant Systems Dual Input with Single Output Two Diodes (Common Cathode) DC 12-48V ±25% Wide-range Input Full Power Between -40°C and +60°C Width only 32mm Rugged Metal Housing Quick-connect Spring-clamp Terminals Easy Wiring: Distribution Terminal for Negative Pole Included 3 Year Warranty PRODUCT DESCRIPTION SHORT-FORM DATA The YR2.DIODE is a redundancy module, which can be used to build 1+1 and N+1 redundant systems. It is equipped with two input channels, which can be connected to power supplies with up to 10A output current and one output, which can carry nominal currents up to 20A. The module is suitable for power supplies with constant current overload behavior as well as any kind of “Hiccup” overload behavior. Input voltage Input voltage range Input current The YR2.DIODE is the perfect solution to use in a redundant system, if the power supply itself is equipped with a DC-OK signal (e.g.: DIMENSION Q-Series). In addition to the YR2.DIODE is the YRM2.DIODE which has a monitoring circuitry included. LEDs and relay contacts signal when one of the two DC-input voltages is not in range due to a non-functioning power supply. Another interesting application for this diode module is to separate sensitive loads from non-sensitive loads. This avoids the distortion of the power quality for the sensitive loads which can cause controller failures. Unique quick-connect spring-clamp terminals allow a safe and fast installation and a large international approval package for a variety of applications makes this unit suitable for nearly every situation. ORDER NUMBERS Output current Input to output voltage drop Power losses Temperature range Derating Dimensions DC 12-48V ±25% 9-60Vdc 2x 0-10A 2x 0-16A 0-20A 20-32A 25A typ. 0.78V typ. 0.85V typ. 0.85V typ. 0W typ. 7.8W typ. 8.5W typ. 17W -40°C to +70°C 0.5A/°C 32x124x102mm continuous for 5 seconds continuous for 5 seconds at cont. overload/ short circuit input: 2x5A input: 1x10A input: 2x10A at no load input: 2x5A input: 1x10A input: 2x10A operational, +60 to +70°C WxHxD MAIN APPROVALS Redundancy Module YR2.DIODE DC 12-48V Accessory ZM1.WALL Wall/ panel mount bracket ZM11.SIDE Side mount bracket For details and the complete approval list, see chapter 14 UL 508 UL 60950-1 Class I Div 2 ATEX IECEx Marine Aug. 2022 / Rev. 1.8 DS-YR2.DIODE-EN All parameters are specified at 24V, 20A output current, 25°C ambient and after a 5 minutes run-in time unless otherwise noted www.pulspower.com Phone +49 89 9278 0 Germany 1/21 YR2.DIODE DC 12-48V, 20A, DUAL REDUNDANCY MODULE Y-Series INDEX Page 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. Intended Use ................................................................ 3 Installation Instructions ................................................ 3 Input and Output Characteristics ................................. 5 Power Losses ................................................................ 6 Lifetime Expectancy and MTBF .................................... 7 Terminals and Wiring ................................................... 8 Functional Diagram ...................................................... 9 Front Side and User Elements ...................................... 9 EMC ............................................................................ 10 Environment ............................................................... 11 Protection Features .................................................... 12 Safety Features........................................................... 12 Dielectric Strength ...................................................... 12 Approved, Fulfilled or Tested Standards .................... 13 Regulatory Product Compliance ................................. 14 Page 16. Physical Dimensions and Weight ............................... 15 17. Accessories................................................................. 16 17.1. ZM1.WALL - Wall mounting bracket ................ 16 17.2. ZM11.SIDE - Side mounting bracket ................. 16 18. Application Notes....................................................... 17 18.1. Recommendations for Redundancy ................. 17 18.2. Inductive and Capacitive Loads ........................ 17 18.3. Example: 1+1 Redundancy up to 10A ............... 17 18.4. Example: N+1 Redundancy up to 30A .............. 18 18.5. Example: Battery Back-up ................................ 18 18.6. Example: Redundancy for Controls .................. 19 18.7. Example: Decoupling of Branches .................... 20 18.8. Use in a Tightly Sealed Enclosure ..................... 20 18.9. Mounting Orientations ..................................... 21 The information presented in this document is believed to be accurate and reliable and may change without notice. No part of this document may be reproduced or utilized in any form without permission in writing from the publisher. TERMINOLOGY AND ABREVIATIONS PE and symbol PE is the abbreviation for Protective Earth and has the same meaning as the symbol . This document uses the term “earth” which is the same as the U.S. term “ground”. t.b.d. To be defined, value or description will follow later. DC 24V A figure displayed with the AC or DC before the value represents a nominal voltage with standard tolerances (usually ±15%) included. E.g.: DC 12V describes a 12V battery disregarding whether it is full (13.7V) or flat (10V) 24Vdc A figure with the unit (Vdc) at the end is a momentary figure without any additional tolerances included. may A key word indicating flexibility of choice with no implied preference shall A key word indicating a mandatory requirement should A key word indicating flexibility of choice with a strongly preferred implementation 1+1 Redundancy Use of two identical power supplies in parallel to provide continued operation following most failures in a single power supply. The two power supply N+1 1+1 Redundancy Redundancy outputs should be isolated from each other by AC AC AC AC AC AC AC AC utilizing diodes or other switching arrangements. DC DC DC DC DC DC DC DC E.g. two 10A power supplies are needed to achieve a 10A redundant system. N+1 Redundancy IN 1 IN 2 IN 1 IN 2 Use of three or more identical power supplies in parallel to provide continued operation following OUT OUT most failures in a single power supply. All power supply outputs should be isolated from each other by utilizing diodes or other switching Load arrangements. E.g.: To achieve a 40A redundant system, five 10A power supplies are needed in a N+1 redundant system. Aug. 2022 / Rev. 1.8 DS-YR2.DIODE-EN All parameters are specified at 24V, 20A output current, 25°C ambient and after a 5 minutes run-in time unless otherwise noted www.pulspower.com Phone +49 89 9278 0 Germany IN 1 IN 2 IN 1 IN 2 OUT OUT + + Earth, Ground - Load 2/21 YR2.DIODE DC 12-48V, 20A, DUAL REDUNDANCY MODULE Y-Series 1. INTENDED USE This device is designed for installation in an enclosure and is intended for commercial use, such as in industrial control, process control, monitoring and measurement equipment or the like. Do not use this device in equipment where malfunction may cause severe personal injury or threaten human life. The redundancy module can be used with any type of power supply as long as the maximum output current ratings are not exceeded. It is suitable for power supplies with continuous overload current as well as any kind of intermittent (Hiccup) overload behavior. 2. INSTALLATION INSTRUCTIONS WARNING - Risk of electrical shock, fire, personal injury or death. Turn power off before working on the device and protect against inadvertent re-powering. Do not open, modify or repair the device. Use caution to prevent any foreign objects from entering into the housing. Do not use in wet locations or in areas where moisture or condensation can be expected. Do not touch during power-on, and immediately after power-off. Hot surface may cause burns. Obey the following installation instructions: This device may only be installed and put into operation by qualified personnel. This device does not contain serviceable parts. The tripping of an internal fuse is caused by an internal defect. If damage or malfunction should occur during installation or operation, immediately turn power off and send unit to the factory for inspection. Install the device in an enclosure providing protection against electrical, mechanical and fire hazards. Do not ground or earth the positive output pole which could prevent redundancy in case of a ground failure. Ground the negative output pole, when needed. Use only power supplies with a negligible output ripple voltage in the low frequency range between 50Hz and 10kHz when used in marine applications according to the GL regulations. Install the device onto a DIN rail according to EN 60715 with the input terminals on the top of the device. Other mounting orientations require a reduction in output current. Make sure that the wiring is correct by following all local and national codes. Use appropriate copper cables that are designed for a minimum operating temperature of 60°C for ambient temperatures up to +45°C, 75°C for ambient temperatures up to +60°C and 90°C for ambient temperatures up to +70°C. Ensure that all strands of a stranded wire enter the terminal connection. The device is designed for pollution degree 2 areas in controlled environments. No condensation or frost is allowed. The enclosure of the device provides a degree of protection of IP20. The input must be powered from a PELV or SELV source or an “Isolated Secondary Circuit” in order to maintain a SELV or PELV output. Check correct input polarity. The device will not operate when input voltage is reversed. The device is designed as “Class of Protection III” equipment according to IEC 61140. A PE (ground) connection is not required. However, connecting the chassis ground terminal to ground can be beneficial to gain a high EMI immunity. The device is designed for convection cooling and does not require an external fan. Do not obstruct airflow and do not cover ventilation grid! The device is designed for altitudes up to 6000m (19685ft). See additional requirements in the product datasheet for use above 2000m (6560ft). Keep the following minimum installation clearances: 40mm on top, 20mm on the bottom, 5mm left and right side. Increase the 5mm to 15mm in case the adjacent device is a heat source. When the device is permanently loaded with less than 50%, the 5mm can be reduced to zero. The maximum surrounding air temperature is +70°C (+158°F). The operational temperature is the same as the ambient or surrounding air temperature and is defined 2cm below the device. Aug. 2022 / Rev. 1.8 DS-YR2.DIODE-EN All parameters are specified at 24V, 20A output current, 25°C ambient and after a 5 minutes run-in time unless otherwise noted www.pulspower.com Phone +49 89 9278 0 Germany 3/21 YR2.DIODE DC 12-48V, 20A, DUAL REDUNDANCY MODULE Y-Series The device is designed to operate in areas between 5% and 95% relative humidity. Installation Instructions for Hazardous Location Areas The device is suitable for use in Class I Division 2 Groups A, B, C, D locations and for use in Group II Category 3 (Zone 2) environments. Hazardous Location classification: ATEX: EPS 11 ATEX 1 312 X, II 3G Ex ec IIC T4 Gc WARNING EXPLOSION HAZARDS! Substitution of components may impair suitability for this environment. Do not disconnect the device unless power has been switched off or the area is known to be non-hazardous. A suitable enclosure must be provided for the end product which has a minimum protection of IP54 and fulfils the requirements of the EN 60079-0. Aug. 2022 / Rev. 1.8 DS-YR2.DIODE-EN All parameters are specified at 24V, 20A output current, 25°C ambient and after a 5 minutes run-in time unless otherwise noted www.pulspower.com Phone +49 89 9278 0 Germany 4/21 YR2.DIODE DC 12-48V, 20A, DUAL REDUNDANCY MODULE Y-Series 3. INPUT AND OUTPUT CHARACTERISTICS Number of inputs Number of outputs Input voltage Input voltage range Voltage drop, input to output Input current Peak input current Output current Reverse current Reverse voltage Note 1: Note 2: nom. typ. typ. typ. nom. nom. nom. max. nom. nom. max. max. max. 2 1 DC 12-48V ±25% The input circuitry must meet the SELV requirements stipulated by IEC/EN/UL 60950-1. 9-60Vdc 0.78V 0.85V 0.85V 2x 0-10A 1x 0-20A 2x 10-16A 150A at 2x5A, see Fig. 3-1 at 1x10A, see Fig. 3-2 at 2x10A, see Fig. 3-1 continuous continuous, see note 1 for 5 seconds for maximal 10ms per input 20A 20-32A 25A 2mA 200Vdc continuous for 5 seconds at continuous overload or short circuit, see note 2 per input, -40°C to +60°C voltage applied to the output, continuously allowed Each input can be loaded up to 20A. At currents above 10A, the other input should not be loaded. It is preferable to parallel the two inputs in order to minimize the power loss in such cases. Ensure that the continuous output current does not exceed 25A. Check the short-circuit current of the power sources and if the power source can deliver more than 25A together, use an appropriate fuse on the output. Aug. 2022 / Rev. 1.8 DS-YR2.DIODE-EN All parameters are specified at 24V, 20A output current, 25°C ambient and after a 5 minutes run-in time unless otherwise noted www.pulspower.com Phone +49 89 9278 0 Germany 5/21 YR2.DIODE DC 12-48V, 20A, DUAL REDUNDANCY MODULE Y-Series Fig. 3-1 Input to output voltage drop when both inputs draw current (typical 1+1 redundant case, when the output voltages of the two units are equal or set into “parallel use” mode) Voltage Drop, typ. QS/QT10 1000mV I1 A 24V,10A + 800mV A V U1 B A... 25°C B... 60°C 400mV 10A 2x5A UOUT V I2 A + Input, Output Current 5A 2x2.5A Output Variable Load, 0-20A QS/QT10 24V,10A 200mV Output: 0 Input: 0 Input 1 IOUT A - 600mV 0mV Output YR2 / YRM2 15A 20A 2x7.5A 2x10A V U2 Input 2 I1 = I2 U1 = U2 Voltage Drop = U1 - UOUT Fig. 3-2 Input to output voltage drop when only one input draws current QS/QT20 Voltage Drop, typ. I1 A 24V,20A 1000mV + 800mV A V U1 Output YR2 / YRM2 Input 1 IOUT A Output Variable Load, 0-20A UOUT V - B 600mV A... 25°C B... 60°C 400mV Not used or power supply with lower voltage 200mV Output Current 0mV 0 5A 10A 15A Input 2 20A Voltage Drop = U1 - UOUT 4. POWER LOSSES Power losses DC 24V 7.8W 8.5W 17.0W typ. typ. typ. typ. Standby power losses 0W input: 2x5A input: 1x10A input: 2x10A at no output current Fig. 4-1 Power losses Power Losses, typ. 24W 20 16 12 8 4 Output Current 0 0 5 10 15 20 25A Aug. 2022 / Rev. 1.8 DS-YR2.DIODE-EN All parameters are specified at 24V, 20A output current, 25°C ambient and after a 5 minutes run-in time unless otherwise noted www.pulspower.com Phone +49 89 9278 0 Germany 6/21 YR2.DIODE DC 12-48V, 20A, DUAL REDUNDANCY MODULE Y-Series 5. LIFETIME EXPECTANCY AND MTBF The redundancy module has two input channels which are completely independent from each other. Each control circuit, auxiliary voltage source, or other circuitry in the module are designed separately for each input. The dual input redundancy module can be considered as two single redundancy modules combined together in one housing. The only common point is the circuit trace that ties the two separate circuits together at the output. The MTBF figures below are for the entire dual input module. If the MTBF number of only one path is needed, simply double the value from the table. The redundancy module does not have electrolytic capacitors included. Therefore, the lifetime expectancy is extremely high. Input / output current conditions Lifetime expectancy *) MTBF **) SN 29500, IEC 61709 MTBF **) MIL HDBK 217F min. min. Input: 2x10A Output: 20A 25 years 25 years 46 500 000h 70 000 000h 36 200 000h 41 100 000h Input: 2x5A Output: 10A 25 years 25 years 55 700 000h 84 000 000h 43 500 000h 49 300 000h at 24V and 40°C at 24V and 25°C at 24V 40°C at 24V 25°C at 24Vand 40°C (Ground Benign GB40) at 24Vand 25°C (Ground Benign GB25) *) The Lifetime expectancy shown in the table indicates the minimum operating hours (service life). **) MTBF stands for Mean Time Between Failure, which is calculated according to statistical device failures, and indicates reliability of a device. It is the statistical representation of the likelihood of a unit to fail and does not necessarily represent the life of a product. The MTBF figure is a statistical representation of the likelihood of a device to fail. A MTBF figure of e.g. 1 000 000h means that statistically one unit will fail every 100 hours if 10 000 units are installed in the field. However, it can not be determined if the failed unit has been running for 50 000h or only for 100h. Aug. 2022 / Rev. 1.8 DS-YR2.DIODE-EN All parameters are specified at 24V, 20A output current, 25°C ambient and after a 5 minutes run-in time unless otherwise noted www.pulspower.com Phone +49 89 9278 0 Germany 7/21 YR2.DIODE DC 12-48V, 20A, DUAL REDUNDANCY MODULE Y-Series 6. TERMINALS AND WIRING Type Solid wire Stranded wire American Wire Gauge Max. wire diameter Wire stripping length Pull-out force Input and output Bi-stable, quick-connect spring clamp terminals. IP20 Finger safe construction. Suitable for field- and factory installation. Shipped in open position. 0.5-6mm2 0.5-4mm2 20-10 AWG 2.8mm (including ferrule) 10mm / 0.4inch 10AWG:80N, 12AWG:60N, 14AWG:50N, 16AWG:40N (according to UL486E) Instructions: a) Use appropriate copper cables that are designed for minimum operating temperatures of: 60°C for ambient up to 45°C and 75°C for ambient up to 60°C and 90°C for ambient up to 70°C minimum. b) Follow national installation codes and installation regulations! c) Ensure that all strands of a stranded wire enter the terminal connection! d) Ferrules are allowed. e) Do not connect or disconnect the wires from the terminals below -25°C (-13°F). Fig. 6-1 Connecting a wire 1. Insert the wire 2. Snap the lever To disconnect wire: same procedure vice versa Aug. 2022 / Rev. 1.8 DS-YR2.DIODE-EN All parameters are specified at 24V, 20A output current, 25°C ambient and after a 5 minutes run-in time unless otherwise noted www.pulspower.com Phone +49 89 9278 0 Germany 8/21 YR2.DIODE DC 12-48V, 20A, DUAL REDUNDANCY MODULE Y-Series 7. FUNCTIONAL DIAGRAM Fig. 7-1 Functional diagram Input 1 + - + Input 2 - + - Output Chassis Ground 8. FRONT SIDE AND USER ELEMENTS Fig. 8-1 Front side A Output terminals B Chassis ground terminal Connection of the chassis to ground is optional and not required since the unit fulfils the requirements according to protection class III. C Input terminals for input 1 D Input terminals for input 2 Aug. 2022 / Rev. 1.8 DS-YR2.DIODE-EN All parameters are specified at 24V, 20A output current, 25°C ambient and after a 5 minutes run-in time unless otherwise noted www.pulspower.com Phone +49 89 9278 0 Germany 9/21 YR2.DIODE DC 12-48V, 20A, DUAL REDUNDANCY MODULE Y-Series 9. EMC The redundancy module is suitable for applications in industrial environment as well as in residential, commercial and light industry environment without any restrictions. A detailed EMC report is available on request. EMC Immunity Electrostatic discharge Electromagnetic RF field Fast transients (Burst) Surge voltage on input lines Surge voltage on output lines Conducted disturbance Power-frequency magnetic field *) According generic standards: EN 61000-6-1 and EN 61000-6-2 EN 61000-4-2 Contact discharge Air discharge EN 61000-4-3 80MHz-2.7GHz EN 61000-4-4 Input lines Output lines EN 61000-4-5 +/- → Chassis ground EN 61000-4-5 +/- → Chassis ground EN 61000-4-6 0.15-80MHz EN 61000-4-8 50Hz 8kV 15kV 10V/m 2kV 2kV 1kV 1kV 10V 30A/m Criterion A Criterion A Criterion A Criterion A Criterion A Criterion A Criterion A Criterion A Criterion A Criterions: A: Redundancy module shows normal operation behavior within the defined limits. Notes: *) A test is not applicable according to EN 61000-6-2, since the device does not contain components susceptible to magnetic fields, e.g. hall elements, electrodynamic microphones, etc. EMC Emission Conducted emission According generic standards: EN 61000-6-3 and EN 61000-6-4 IEC/CISPR 16-1-2, IEC/CISPR 16-2-1 Class B, input lines *) IEC/CISPR 16-1-2, IEC/CISPR 16-2-1 Class B, output lines *) Radiated emission EN 55011, EN 55032 Class B This device complies with FCC Part 15 rules. Operation is subjected to following two conditions: (1) this device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. *) Provided, that power sources connected on the inputs fulfill the class B requirements too. Aug. 2022 / Rev. 1.8 DS-YR2.DIODE-EN All parameters are specified at 24V, 20A output current, 25°C ambient and after a 5 minutes run-in time unless otherwise noted www.pulspower.com Phone +49 89 9278 0 Germany 10/21 YR2.DIODE DC 12-48V, 20A, DUAL REDUNDANCY MODULE Y-Series 10. ENVIRONMENT Operational temperature *) Output derating Storage temperature Humidity **) Vibration sinusoidal ***) -40°C to +70°C (-40°F to 158°F) 0.5A/°C -40 to +85°C (-40°F to 185°F) 5 to 95% r.H. 2-17.8Hz: ±1.6mm 17.8-500Hz: g 2 hours / axis 30g 6ms, 20g 11ms 3 bumps / direction 18 bumps in total 0 to 2000m (0 to 6 560ft) 2000 to 5000m (6 560 to 16 400ft) Shock ***) Altitude Altitude derating Over-voltage category 1.25A/1000m or 5°C/1000m not applicable Degree of pollution 2 Reduce output power above +60°C 60-70°C (140°F to 158°F), see for storage and transportation IEC 60068-2-30 IEC 60068-2-6 IEC 60068-2-27 without any restrictions reduce output power or ambient temperature, see Fig. 10-2 > 2000m (6500ft), see Fig. 10-2 The concept of the overvoltage category is used for equipment energized directly from the low voltage mains (IEC 60664-1 §4.3.3.2.1). IEC 62103, EN 50178, not conductive *) Operational temperature is the same as the ambient temperature and is defined as the air temperature 2cm below the unit. **) Do not energize while condensation is present ***) Tested in combination with DIN rails according to EN 60715 with a height of 15mm and a thickness of 1.3mm and standard mounting orientation. Fig. 10-1 Output current vs. ambient temp. Allowed Output Current Allowed Output Current 30A 30A 25 Fig. 10-2 Output current vs. altitude at overload / short circuit 20 normal mode 15 10 10 5 5 Ambient Temperature 0 20 normal mode 20 15 0 -40 -25 overload / short circuit 25 40 A A... Tamb < 60°C B... Tamb < 50°C C... Tamb < 40°C 0 2000 4000 Aug. 2022 / Rev. 1.8 DS-YR2.DIODE-EN All parameters are specified at 24V, 20A output current, 25°C ambient and after a 5 minutes run-in time unless otherwise noted www.pulspower.com Phone +49 89 9278 0 Germany C Altitude 0 60 70°C B 6000m 11/21 YR2.DIODE DC 12-48V, 20A, DUAL REDUNDANCY MODULE Y-Series 11. PROTECTION FEATURES Output over-current protection Reverse input polarity protection Degree of protection Penetration protection Over-temperature protection Input transient protection Output transient protection Internal input fuse not included included IP 20 > 3.6mm not included not included included not included unit does not start when input voltage is reversed EN/IEC 60529 e.g. screws, small parts see EMC chapter 12. SAFETY FEATURES Input / output separation no galvanic separation Safety level of output voltage The output voltage is regarded to be SELV (EN 60950-1) or PELV (EN 60204-1, EN 50178, IEC 60364-4-41) if the input voltage fulfil the requirements for a SELV source or PELV source. III PE (Protective Earth) or chassis connection not required < 0.1Ohm between housing and chassis-ground terminal Class of protection PE resistance 200V epitaxial diode between input and output 13. DIELECTRIC STRENGTH The input and output voltages have the same reference, are floating and have no ohmic connection to ground. Type and factory tests are conducted by the manufacturer. Field tests may be conducted in the field using the appropriate test equipment which applies the voltage with a slow ramp (2s up and 2s down). Connect input/output terminals together before conducting the test. When testing, set the cut-off current settings to the value in the table below. Type test 60s A 500Vac Factory test 5s 500Vac Field test 5s 500Vac Fig. 13-1 Dielectric strength In- / Output + - Chassis A Cut-off current setting Aug. 2022 / Rev. 1.8 DS-YR2.DIODE-EN All parameters are specified at 24V, 20A output current, 25°C ambient and after a 5 minutes run-in time unless otherwise noted www.pulspower.com Phone +49 89 9278 0 Germany > 2mA 12/21 YR2.DIODE DC 12-48V, 20A, DUAL REDUNDANCY MODULE Y-Series 14. APPROVED, FULFILLED OR TESTED STANDARDS UL 508 IEC 60950-1 UL 60950-1 ATEX IECEx Class I Div 2 Marine (DNV) Marine (ABS) IEC 60068-2-60 UL Certificate Listed equipment for category NMTR - Industrial Control Equipment Applicable for US and Canada E-File: E198865 CB Scheme Certificate General safety requirements for Information Technology Equipment (ITE) UL Certificate Recognized component for category QQGQ - Information Technology Equipment (ITE) Applicable for US and Canada E-File: E137006 Agency Certificate (Bureau Veritas) EN 60079-0 Explosive atmospheres - General requirements EN 60079-7 Equipment protection by type of protection "e" Certificate: EPS 11 ATEX 1 312 X Temperature Code: T4 Type of Protection: ec nC IECEx Certificate IEC 60079-0 Explosive atmospheres - General requirements IEC 60079-7 Equipment protection by type of protection "e” Certificate: IECEx EPS 12.0032 X Temperature Code: T4 Type of Protection: ec CSA Certificate Power Supplies for Hazardous Location Applicable for Canada and US CSA Class: 5318-01 (Canada), 5318-81 (USA) Temperature Code: T4 Groups: A, B, C and D DNV Certificate DNV Type approved product Certificate: TAA00001JT Temperature: Class D Humidity: Class B Vibration: Class C EMC: Class A Enclosure: Class A ABS Design Assessment Certificate ABS (American Bureau of Shipment) assessed product Certificate: 17-HG1599236-PD Manufacturer's Declaration (Online Document) Environmental Tests, Flowing Mixed Gas Corrosion Test Test Ke - Method 4 H2S: 10ppb NO2: 200ppb Cl2: 10ppb SO2: 200ppb Test Duration: 3 weeks, which simulates a service life of 10 years. Aug. 2022 / Rev. 1.8 DS-YR2.DIODE-EN All parameters are specified at 24V, 20A output current, 25°C ambient and after a 5 minutes run-in time unless otherwise noted www.pulspower.com Phone +49 89 9278 0 Germany 13/21 YR2.DIODE DC 12-48V, 20A, DUAL REDUNDANCY MODULE Y-Series ISA-71.04 G3 Manufacturer's Declaration (Online Document) Airborne Contaminants Corrosion Test Severity Level: G3 Harsh H2S: 100ppb NOx: 1250ppb Cl2: 20ppb SO2: 300ppb Test Duration: 3 weeks, which simulates a service life of 10 years Paint Wetting Impairment Substances Test (or LABS-Test) Tested for Zone 2 and test class C1 according to VDMA 24364-C1-L/W for solvents and water-based paints VDMA 24364 15. REGULATORY PRODUCT COMPLIANCE EU Declaration of Conformity REACH Regulation (EU) WEEE Regulation UKCA CCC The CE mark indicates conformance with the - EMC directive - ATEX directive - RoHS directive Manufacturer's Declaration EU regulation regarding the Registration, Evaluation, Authorisation and Restriction of Chemicals (REACH) fulfilled. EU Regulation (EC) 1907/2006. Manufacturer's Declaration EU Regulation on Waste Electrical and Electronic Equipment Registered as business to business (B2B) products. EU Regulation 2012/19/EU UKCA Declaration of Conformity Trade conformity assessment for England, Scotland and Wales The UKCA mark indicates conformity with the UK Statutory Instruments 2016 No.1101, 2016 No.1091, 2012 No.3032 CCC Certificate China Compulsory Certification (CNCA-C23-01:2019) Certificate for devices made in Suzhou/China (PULS Electronics): 2021122303114443 Certificate for devices made in Chomutov/Czech Republic (PULS investiční): 2021122303114444 CCC-Ex Aug. 2022 / Rev. 1.8 DS-YR2.DIODE-EN All parameters are specified at 24V, 20A output current, 25°C ambient and after a 5 minutes run-in time unless otherwise noted www.pulspower.com Phone +49 89 9278 0 Germany 14/21 YR2.DIODE DC 12-48V, 20A, DUAL REDUNDANCY MODULE Y-Series 16. PHYSICAL DIMENSIONS AND WEIGHT Weight DIN rail Installation clearances 290g / 0.64lb Use 35mm DIN rails according to EN 60715 or EN 50022 with a height of 7.5 or 15mm. The DIN rail depth must be added to the unit depth (102mm) to calculate the total required installation depth. See chapter 2 Fig. 16-1 Front view Fig. 16-2 Side view Aug. 2022 / Rev. 1.8 DS-YR2.DIODE-EN All parameters are specified at 24V, 20A output current, 25°C ambient and after a 5 minutes run-in time unless otherwise noted www.pulspower.com Phone +49 89 9278 0 Germany 15/21 YR2.DIODE DC 12-48V, 20A, DUAL REDUNDANCY MODULE Y-Series 17. ACCESSORIES 17.1. ZM1.WALL - WALL MOUNTING BRACKET This standard bracket is used to mount the YR40 redundancy module onto a flat surface without utilizing a DIN rail. Fig. 17-1 ZM1.WALL Wall mounting bracket Fig. 17-2 Assembled wall mounting bracket 17.2. ZM11.SIDE - SIDE MOUNTING BRACKET This bracket is used to mount the YR80 redundancy module sideways with or without utilizing a DIN rail. The two aluminum brackets and the black plastic slider of the unit have to be detached, so that the steel brackets can be mounted. For sideway DIN rail mounting, the removed aluminum brackets and the black plastic slider need to be mounted on the steel bracket. Fig. 17-3 ZM11.SIDE Side mounting bracket Fig. 17-4 Side mounting with DIN rail brackets Aug. 2022 / Rev. 1.8 DS-YR2.DIODE-EN All parameters are specified at 24V, 20A output current, 25°C ambient and after a 5 minutes run-in time unless otherwise noted www.pulspower.com Phone +49 89 9278 0 Germany 16/21 YR2.DIODE DC 12-48V, 20A, DUAL REDUNDANCY MODULE Y-Series 18. APPLICATION NOTES 18.1. RECOMMENDATIONS FOR REDUNDANCY Recommendations for the configuration of redundant power systems: • Use separate input fuses for each power supply. • Use three-phase power supplies to gain functional safety if one phase fails. • When single-phase power supplies are utilized connect them to different phases or mains circuits if possible. • Set the power supply in “Parallel-Use” mode if this feature is available • It is desirable to set the output voltages of all power supplies to the same value. 18.2. INDUCTIVE AND CAPACITIVE LOADS The unit is designed to supply any kind of loads, including unlimited capacitive and inductive loads. 18.3. EXAMPLE: 1+1 REDUNDANCY UP TO 10A 1+1 Redundancy up to 10A requires two 10A power supplies and one YR2.DIODE redundancy module. Fig. 18-1 Wiring diagram, 1+1 Redundancy, 10A output current Failure Monitor ++ -- 24V,10A Adj DCok Overload QS10.241 Power Supply L N PE +- +- IN 1 IN 2 YR2.Diode Redundancy Module ++ -- 24V,10A Adj DCok Overload QS10.241 Power Supply OUT L N PE + - optional I I 10A Load L N PE Note: Use separate mains systems for each power supply whenever it is possible Aug. 2022 / Rev. 1.8 DS-YR2.DIODE-EN All parameters are specified at 24V, 20A output current, 25°C ambient and after a 5 minutes run-in time unless otherwise noted www.pulspower.com Phone +49 89 9278 0 Germany 17/21 YR2.DIODE DC 12-48V, 20A, DUAL REDUNDANCY MODULE Y-Series 18.4. EXAMPLE: N+1 REDUNDANCY UP TO 30A N+1 Redundancy up to 30A requires four 10A power supplies and two YR2.DIODE redundancy modules. Fig. 18-2 Wiring diagram, n+1 Redundancy, 30A output current Failure Monitor ++ -- 24V,10A Adj DCok Overload QS10.241 Power Supply L N PE +- +- IN 1 IN 2 YR2.Diode Redundancy Module ++ -- ++ 24V,10A Adj DCok Overload QS10.241 Power Supply QS10.241 Power Supply OUT L N PE + - I -- 24V,10A Adj DCok Overload +- +- IN 1 IN 2 YR2.Diode Redundancy Module I L N PE + - I -- QS10.241 Power Supply OUT L N PE L N PE ++ 24V,10A Adj DCok Overload I optional 30A Load Note: Use separate mains systems for each power supply whenever it is possible 18.5. EXAMPLE: BATTERY BACK-UP A battery back-up with 10A requires one 10A power supply and one YR2.DIODE redundancy module. Please note: Set output voltage of power supply to 26.5Vdc minimum to ensure, that the load current is delivered from the power supply and not from charger (battery). Use a fuse between battery and YR2.DIODE! Fig. 18-3 Wiring diagram, 10A Battery back-up Failure Monitor I + 24V Battery ++ -- +- +- IN 1 IN 2 24V,10A Adj DCok Overload Battery Charger QS10.241 Power Supply YR2.Diode Redundancy Module OUT L N PE L N PE + - optional 10A Load Aug. 2022 / Rev. 1.8 DS-YR2.DIODE-EN All parameters are specified at 24V, 20A output current, 25°C ambient and after a 5 minutes run-in time unless otherwise noted www.pulspower.com Phone +49 89 9278 0 Germany 18/21 YR2.DIODE DC 12-48V, 20A, DUAL REDUNDANCY MODULE Y-Series 18.6. EXAMPLE: REDUNDANCY FOR CONTROLS The example shows a cost effective solution to get redundant power for a PLC or controller system. In many cases, two power supplies are used; one for the demanding loads and another one for the controls and sensitive loads. The power supply for the demanding loads can be used as a redundant source to supply the controls. Traditional approach: Improved approach: PS1 Load PS2 PLC PS1 Load YR2 PS2 PLC Fig. 18-4 Wiring diagram, redundancy for sensitive loads Failure Monitor Heavy Loads e.g. Motors ++ -- +- +- IN 1 IN 2 24V,20A Adj DCok Overload QT20.241 Power Supply YR2.Diode Redundancy Module OUT L1 L2 L3 PE I L1 L2 L3 N PE I + - I optional ++- - 24V, 5A Adj DCok Overload QS5.241 Power Supply L N PE Sensitive Load e.g. Controller I Note: Use separate mains systems for each power supply whenever it is possible Aug. 2022 / Rev. 1.8 DS-YR2.DIODE-EN All parameters are specified at 24V, 20A output current, 25°C ambient and after a 5 minutes run-in time unless otherwise noted www.pulspower.com Phone +49 89 9278 0 Germany 19/21 YR2.DIODE DC 12-48V, 20A, DUAL REDUNDANCY MODULE Y-Series 18.7. EXAMPLE: DECOUPLING OF BRANCHES Buffer energy supplied from a DC-UPS or buffer module is not wasted in “power branches”. Please note: Set output voltage of the power supply to a level that the buffer unit or DC-UPS will not start unexpected. Take the voltage drop of the YR2.DIODE into account. Fig. 18-5 Wiring diagram, decoupling of buffered branches Failure Monitor Load e.g. Motor ++ -- +- +- IN 1 IN 2 24V,20A Adj DCok Overload QT20.241 Power Supply YR2.Diode Redundancy Module L1 L2 L3 PE OUT Buffer Module + - + - I I Buffered Load e.g. Controller I L1 L2 L3 PE optional Note: Use separate mains systems for each power supply whenever it is possible 18.8. USE IN A TIGHTLY SEALED ENCLOSURE When the redundancy module is installed in a tightly sealed enclosure, the temperature inside the enclosure will be higher than outside. The inside temperature defines the ambient temperature for the redundancy module. Results from such an installation: Power supply is placed in the middle of the box, no other heat producer inside the box Enclosure: Load: Input: Temperature inside enclosure: Temperature outside enclosure: Temperature rise: 33.2K Rittal Typ IP66 Box PK 9516 100, plastic, 110x180x165mm 24V, 16A; (=80%) load is placed outside the box 24Vdc 57.8°C (in the middle of the right side of the power supply with a distance of 2cm) 24.6°C Aug. 2022 / Rev. 1.8 DS-YR2.DIODE-EN All parameters are specified at 24V, 20A output current, 25°C ambient and after a 5 minutes run-in time unless otherwise noted www.pulspower.com Phone +49 89 9278 0 Germany 20/21 YR2.DIODE DC 12-48V, 20A, DUAL REDUNDANCY MODULE Y-Series 18.9. MOUNTING ORIENTATIONS Mounting orientations other than input terminals on the bottom and output on the top require a reduction in continuous output power or a limitation in the maximum allowed ambient temperature. Fig. 18-6 Mounting Orientation A (Standard orientation) Output Current INPUT 20A 16 12 8 4 0 10 Redundancy Module OUTPUT Fig. 18-7 Mounting Orientation B (Upside down) 30 40 50 60°C OUTPUT 20A 16 12 8 4 0 10 Ambient Temperature 20 30 40 50 60°C Redundancy M odule INPUT Output Current 20A 16 12 8 4 0 10 Ambient Temperature 20 30 40 50 60°C Output Current INPUT Redundancy M odule OUTPUT 20A 16 12 8 4 0 10 Ambient Temperature 20 30 40 50 60°C OUTPUT Redundancy M odule Output Current INPUT Fig. 18-10 Mounting Orientation E (Horizontal ccw) 20 Output Current Fig. 18-8 Mounting Orientation C (Table-top mounting) Fig. 18-9 Mounting Orientation D (Horizontal cw) Ambient Temperature 20A 16 12 8 4 0 10 Ambient Temperature 20 30 40 50 60°C Aug. 2022 / Rev. 1.8 DS-YR2.DIODE-EN All parameters are specified at 24V, 20A output current, 25°C ambient and after a 5 minutes run-in time unless otherwise noted www.pulspower.com Phone +49 89 9278 0 Germany 21/21
YR2.DIODE 价格&库存
很抱歉,暂时无法提供与“YR2.DIODE”相匹配的价格&库存,您可以联系我们找货
