2-Port USB 2.0 Desktop Extension Cable (M/2xF),
5 ft. (1.52 m)
MODEL NUMBER: U024-005-DSK2
Highlights
Features one USB 2.0
data/power port and one poweronly port
Supports data transfer rates up
to 480 Mbps
Premium foil and braid shielding
Backward compatible with
earlier USB generations
Twisted 28/24 AWG data/power
lines
System Requirements
Computer, laptop or other
device with USB-A port
Package Includes
Converts your computer’s USB-A port to 2 USB-A ports and extends them up to 5 ft away. Ideal for
connecting thumb drives, digital cameras and other USB-A devices.
Features
Expands an Existing USB-A Port to 2 Ports and Extends Them an Extra 5 ft.
● Move a hard-to-reach USB port within easy access
Ideal for connecting external hard drives, thumb drives, digital cameras and other USB-A devices
Features one USB 2.0 data/power port and one power-only port
Supports data transfer rates up to 480 Mbps
Backward compatible with earlier USB generations
First-Rate Construction for Superior Signal Transfer
● Premium foil and braid shielding for EMI/RFI noise protection
Molded nickel-plated connectors for optimal signal quality
Integral strain relief for long life
Twisted 28/24 AWG data/power lines
Flexible PVC jacket easy to install in tight spaces
Black padded non-sliding base
Specifications
OVERVIEW
UPC Code
037332199348
Technology
USB; USB 2.0 (High Speed)
USB Cable Type
Passive
1/3
U024-005-DSK2 2-Port USB 2.0
Hi-Speed Desktop Extension
Cable (M/2xF), 5 ft.
INPUT
Maximum Input Amps
2
CHARGING
Total Charging Watts
10
PHYSICAL
Material of Construction
PVC
Cable Jacket Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
4.5mm
Cable Length (ft.)
5
Cable Length (m)
1.52
Shipping Dimensions (hwd / in.)
5.31 x 3.94 x 0.50
Shipping Dimensions (hwd / cm)
13.49 x 10.01 x 1.27
Shipping Weight (lbs.)
0.20
Shipping Weight (kg)
0.09
Unit Packaging Type
Polybag
ENVIRONMENTAL
Operating Temperature Range
32 to 104 F (0 to 40 C)
Storage Temperature Range
14 to 131 F (-10 to 55 C)
Relative Humidity
5% to 90% RH, Non-Condensing
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
Power Provided to Connected
Device(s)
10W (5V/2A)
CONNECTIONS
Side A - Connector 1
USB A (MALE)
Side B - Connector 1
(2) USB A (FEMALE)
Connector Plating
Nickel
Contact Plating
Gold
FEATURES & SPECIFICATIONS
Data Transfer Rate
480 Mbps
2/3
USB Specification
USB 2.0 (up to 480 Mbps)
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
3/3
很抱歉,暂时无法提供与“U024-005-DSK2”相匹配的价格&库存,您可以联系我们找货
