1-Port USB 3.0 SuperSpeed Desktop Extension
Cable (A M/F), 6 ft. (1.83 m)
MODEL NUMBER: U324-006-DSK1
Highlights
Supports data transfer rates up
to 5 Gbps
Bi-directional interface allows
data to flow both directions
Backward compatible with
previous USB generations
Double-shielded protection
against EMI/RFI line noise
Black padded non-sliding base
System Requirements
Computer, laptop or other
device with USB 3.0 port (to
achieve USB 3.0 speeds)
Package Includes
Extends your desktop computer’s existing USB 3.0 port up to 6 ft. away. Ideal for connecting external hard
drives, thumb drives, digital cameras and other USB-A devices.
Features
Extends an Existing USB 3.0 Port an Extra 6 ft.
● Move a hard-to-reach USB port within easy access
Ideal for connecting external hard drives, thumb drives, digital cameras and other USB-A devices
Enjoy SuperSpeed Transfer Rates in High-End Applications
● Supports data transfer rates up to 5 Gbps—10x the speed of USB 2.0
Bi-directional interface allows data to flow both directions at the same time, increasing theoretical
bandwidth by 10x
Backward compatible with earlier USB generations
First-Rate Construction for Superior Signal Transfer
● Premium foil and braid shielding blocks EMI/RFI interference
Molded nickel-plated connectors ensure excellent connectivity
Integral strain relief for cable and connectors’ long life
Twisted 28/24 AWG data/power lines
Flexible PVC jacket easy to install in tight spaces
Specifications
OVERVIEW
UPC Code
037332199461
1/3
U324-006-DSK1 1-Port USB 3.0
Cable (M/F), 6 ft.
Technology
USB; USB 3.x
USB Cable Type
Passive
INPUT
Maximum Input Amps
2
CHARGING
Total Charging Watts
10
PHYSICAL
Material of Construction
PVC
Cable Jacket Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
5.5mm
Cable Length (ft.)
6
Cable Length (m)
1.83
Unit Packaging Type
Polybag
ENVIRONMENTAL
Operating Temperature Range
32 to 104 F (0 to 40 C)
Storage Temperature Range
14 to 131 F (-10 to 55 C)
Relative Humidity
5% to 90% RH, Non-Condensing
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
Power Provided to Connected
Device(s)
10W (5V/2A)
CONNECTIONS
Side A - Connector 1
USB A (MALE)
Side B - Connector 1
USB A (FEMALE)
Connector Plating
Nickel
Contact Plating
Gold
FEATURES & SPECIFICATIONS
Data Transfer Rate
5 Gbps
Over Current Protection
Yes
USB Specification
USB 3.2 Gen 1 (up to 5 Gbps)
2/3
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
3/3
很抱歉,暂时无法提供与“U324-006-DSK1”相匹配的价格&库存,您可以联系我们找货
