AP105-DF58-2830S(61) 数据手册
NEW
Small-Sized, Low Profile 1.0mm Height, Wire-to-Board Connectors for Power Supply
DF58 Series
Small-sized, low profile connector
5.8mm
3 pos.)
mm
7
4.9
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
1mm
Fig.1
■Features
Description of the ViSe Lock Design
1. Small-sized, low profile connector
Insertion operation appears to be vertical mating.
However, it is actually inserted at an angle which
ensures high retention force in upper direction.
Low profile design of 1.0mm stacking height, the
connector is suitable for small-sized devices.
2. Leveling of the vertical mating cable
Before mating
Ver tical inser tion of the connector for mating
enhances the assembly operation within device.
3. Proprietary ViSe Lock design
The cable side lock has been strengthened with our
proprietary ViSe Lock mechanism*, preventing the
cables from being easily disconnected due to tough
routing or an excessive load. (*ViSe Lock: Verticalinsertion Swing-extraction)(Fig.2)*Patent pending
After mating
4. High current capability up the maximum
of 3.0A (2pos. : When 28AWG is used)
By adopting high conductivity material and lowering
contact resistance through optimized contact force,
high-current capability is achieved in spite of its
small size.
5. Highly reliable contact design
Effective mating length of 0.29mm is achieved in
spite of low profile 1.0mm stacking height. The
2-point clipping contact stabilizes contact resistance.
Fig.2
Contact design
Effective mating
length of 0.29mm
2-points of contact
6. Halogen-free*
*As defined by IEC 61249-2-21
Br-900ppm max, Cl-900ppm max, Br+Cl-1,500ppm max
Cross sectional view of contact face
Fig.3
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2016.11
1
DF58 Series●Small-Sized, Low Profile 1.0mm Height, Wire-to-Board Connectors for Power Supply
■Product Specifications
Current rating
Rating
28AWG
30AWG
2pos.
3pos.
3.0A
2.5A
2.5A
2.0A
4.Vibration
5.Shock
6.Humidity
7.Temperature
cycle
8.Durability
9.Resistance to
soldering heat
6pos.
2.0A
1.5A
Operating temperature range -55ç to 85ç (Note 1)
Operating humidity range 20% to 80% (Note 2)
Storage temperature range -10ç to 60ç (Note 3)
Storage humidity range 40% to 70% (Note 3)
100V AC/DC
Voltage rating
Item
1.Insulation
resistance
2.Withstanding
voltage
3.Contact
resistance
4pos.
Specification
Conditions
100Mø min.
100V DC
No flashover or insulation breakdown
500V AC / 1 minute
10mø max.
20mV max. at 1mA.
No electrical discontinuity of 1µs or longer
No damage, cracks or parts dislocation.
Contact resistance : 20mø max.,
Insulation resistance : 100Mø min.
Frequency : 10 to 55Hz, single amplitude of 0.75mm,
10 cycles, 3 direction
Acceleration of 490m/s2, 11ms duration, sine halfwave, 3 cycles in each of the 3 axis
No deformation of components affecting
performance
96 hours at 40 ±2ç, and humidity of 90 to 95%
-55°C → 5 to 35°C → 85°C → 5 to 35°C
Times : 30 min. → 2 min. to 3 min. → 30 min. → 2 min.
to 3 min. 5 cycles
10 cycles
Reflow : See recommended temperature profile (Page 6)
Manual soldering : 350°C for 3 seconds
Note 1 : Includes temperature rise caused by operating current.
Note 2 : Use in environments without condensation.
Note 3 : The term "storage" refers to products stored for a long period prior to soldering or usage.
The operating temperature and humidity range covers the non-conducting condition of installed connectors in storage,
shipment or during transportation.
Materials / Finish
Product
Part
Insulator
Contacts
Insulator
Contacts
Header
Crimp socket
Crimp contacts
Material
Finish
LCP
Copper Alloy
LCP
Copper Alloy
Black
Tin Plated
Natural
Tin Plated
Remarks
UL94V-0
--------------UL94V-0
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Header
DF 58 − * P 1.2 V
❹
❺
Series name:DF
Contact pitch:1.2mm
Series No.:58
Termination section
Number of contacts:2, 3, 4, 6 V:Straight SMT
❻
Connector type
P:Header
●Crimp socket
Series name:DF
DF 58 − * S − 1.2 C
❹
❺
❻
Contact pitch:1.2mm
Series No.:58
Termination section
Number of contacts:2, 3, 4, 6 C:Crimp socket
Connector type
S:Socket
●Crimp contact
DF 58 − 2830 SCF
2
Applicable wire size
2830 : 28 to 30AWG
Packaging
SCF:Female crimp contact / reel
■Header (SMT)
A
B
C
P=1.2
0.95
1.55
4.72
4.77
1.49
Contact No.1
CAV No.
Recommended PCB layout
D
HRS mark
0.65±0.05
C±0.05
0.6
+0.05
1.5min
2
(0.15)
P=1.2±0.05
1.34±0.05
4.7±0.05
Vacuum area
Dmin
0.85
+0.05
1±0.05
[Specification number]
(21) : Tin plated, Embossed tape
packaging (6,000pcs/reel)
Unit:mm
Part No.
HRS No.
No. of contacts
A
B
C
D
DF58-2P-1.2V(21)
666-1001-0 21
2
4.5
3.6
1.2
2.5
DF58-3P-1.2V(21)
666-1002-0 21
3
5.7
4.8
2.4
3.7
DF58-4P-1.2V(21)
666-1003-0 21
4
6.9
6.0
3.6
4.9
DF58-6P-1.2V(21)
666-1005-0 21
6
9.3
8.4
6.0
7.3
Note 1 : Embossed tape reel packaging (6,000pcs/reel).
Note 2 : The crossed-hatched area is a no conductive trace area.
3
●Packaging Specification
1.75±0.1
DMAX
+0.3
Product label
Ø1.
5 sprocket
hole far side
Ø1
R1
0.2
G
F
F-F
+0.2
3±
8
0.
1±
Ø2
F
E
Ø80±1
Ø380±2
G-G
0.5
2±
C±0.1
G
A −0.1
0.1
.5
8±0.1
B 0
Ø1
4±0.1
2±0.1
●Reel Shape
Extraction Direction
Unit:mm
Part No.
DF58-2P-1.2V(21)
DF58-3P-1.2V(21)
DF58-4P-1.2V(21)
DF58-6P-1.2V(21)
A
B
C
D
E
16
14.25
7.5
22.4
16.4
24
22.25
11.5
30.4
24.4
Crimp socket
A
Contact No.1 mark
0.975
HRS mark
4.47
CAV No.
B
C
D
P=1.2
Unit:mm
Part No.
HRS No.
No. of contacts
A
B
C
D
DF58-2S-1.2C
666-1006-0 00
2
4.6
2.6
3.21
1.2
DF58-3S-1.2C
666-1007-0 00
3
5.8
3.8
4.41
2.4
DF58-4S-1.2C
666-1008-0 00
4
7.0
5.0
5.61
3.6
DF58-6S-1.2C
666-1010-0 00
6
9.4
7.4
8.01
6.0
Note 1 : Please order by number of packing (1,000pcs/packing).
4
■Crimp contact
1.4
3
3.95
0.45
1.6
0.7
3.5
0.965
t=0.12
1.4
P=4
Unit:mm
Part No.
HRS No.
Packaging
Quantity
Finish
DF58-2830SCF
666-1011-0 00
Reel
40,000
Tin plated
Note : This product is delivered in 40,000 pieces per reels.
Please place orders in multiples of 40,000 pieces.
●Applicable wire (Tin plated annealed copper wire)
Wire size
(Stranded wire conductor)
28AWG
(7/Ø0.127mm)
(7/Ø0.102mm)
30AWG
Unit:mm
Jacket outer diameter
Recommended cable
Strip length
Ø0.5 to 0.6mm
UL1571
(Thin wire)
1.0 to 1.4mm
Note 1 : When using other than the recommended wire, contact your nearest Hirose sales representative.
Note 2 : The strip length is a reference value. Please make adjustments so finished crimps will meet the specified values.
Refer to the crimping quality standards (ATAD-H0848-00) for details.
BTools
Unit:mm
Type
Part No.
HRS No.
Applicator
AP105-DF58-2830S
901-4649-0 00
Press
CM-105C
901-0001-0 00
Hand crimping tool
HT307/DF58-2830HC
Under development
Contact extraction tool
DF-C-PO
(B)
550-0179-2 00
Applicable contact
DF58-2830SCF
Note : If any trouble has occurred due to tools other than the designated tool, Hirose bears no respoisibility for any trouble.
5
BOperating Precautions
1. Recommended Temperature Profile
(Lead-free soldering possible)
10sec MAX
MAX 250
250
220ç
TEMPERATURE
(ç)
200
180ç
150
100
50
TIME
(sec)
90‒120sec
60sec
PRE-HEATING TIME
SOLDERING TIME
[Applicable Conditions]
1. Peak Temperature : MAX 250℃
2. Heated Area : 220℃ or above, within 60 sec.
3. Pre-heating Area : 150-180℃, 90-120 sec.
4. Number of Operation : Twice or less
* The contact lead area was measured.
The conditions may change depending on the types and manufacturers of
cream solder, PCB size, and conditions of other materials used for
soldering. Please fully check the soldering condition before use.
[Remarks 1] This temperature profile is our recommended value.
2. Recommended Hand Solder Conditions
3. Recommended Screen Thickness, Aperture
Opening Rate (Pattern Area Ratio)
4. PCB Warpage
Soldering iron temperature : 350 ± 10℃, soldering time : within 3 seconds
Thickness 0.1mm, aperture opening rate : 100%
Max 0.02mm at the center of connector with the both edges of the connector
as the baseline.
5. Cleaning Condition
Cleaning with IPA is possible. (Cleaning is not recommended as it may
change the feel of insertion/extraction, etc. Please consult with us when
using other types of cleaning agents.)
6. Precautions
■ Insertion/extraction of the connector while not mounted to the PCB may
cause breakage or deformation to the contact.
■ Do not apply flux at the time of hand soldering, as it may result in flux rise.
■ This product may have slightly different hue on molded items, however,
they do not affect the product performance.
■ See the separate “DF58 Insertion/Extraction Procedure Manual” for
handling precautions at the time of insertion and extraction.
6
BUsage Recommendation
7. Insertion
and removal
operation
method
Mating
(1) Placing the crimp socket
Insert the crimp socket by aligning to the housing outline.
If crimp socket is correctly aligned, the top face of the
crimp socket becomes parallel to the PCB.
(2) Insertion
Press down in the center of the crimp socket, and mating is complete.
Press down in the center.
Mating is finished.
(3) Checking the mated state
Check if the crimp socket is securely mated.
If one end floats or is mated at an angle, unmate, and mate it again.
If the connector is inserted when the crimp socket isn't placed correctly, only the friction lock on
the non-cable side may be inserted as shown in the Figure below. In this case, unmate, and
mate it again. Forced mating will lower the retention force.
Insert it over again.
7
BRecommended Usage
7. Insertion
and removal
operation
method
Pull-out operation
Pull-out operation starts by hooking on either side of the protrusion to release the crimp socket and
pull up to release the friction lock. Raise the entire crimp socket and complete the operation.
Protrusion for release
Raise either side of the
and complete the pull-out
protrusion
operation
Use the protrusion for release at the time of pull-out operation.
If you forcibly remove it by pulling the cable, cable disconnection and connector breakage will occur.
8
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 11/2016. Contents are subject to change without notice for the purpose of improvements.
