AP105-DF50K-2830S(61) 数据手册
1mm Pitch, Board to Cable Lock Connector
DF50 Series
It provides clear tactile click and secure mating
Timing of locking function
Simultaneous timing of locking function and
Figure 1. contact mating provides a clearer tactile click.
Robust structure resistant to wrenching forces
■Features
1. It provides clear tactile click and secure mating
Locking function and contact mating occur simultaneously,
for a clearer tactile click.
(Please refer to Figure 1 on the right)
2. Robust structure resistant to wrenching forces
Thick and robust housing wall provides higher strength
against cracking. Insertion depth for mating housings
protects against wrenching.
(Please refer to Figure 2 on the right)
3. Robust and reliable lance structure
High lance strength by mating with crimp contact on the
surface
(Please refer to Figure 3 on the right)
4. Ensured adsorption area eliminates the need
for adsorption gap.
Insertion depth for mating protects against
wrenching.
Thick and robust outer wall provides higher
Figure 2. strength and prevents cracking.
Adequate adsorption area is ensured despite the small size,
allowing for automatic mounting without adsorption gap.
(*Specifications for adsor ption gap may be provided
according to your requirements)
The lance mates with the crimp
contact on the surface.
5. Insulation outer diameter Ø0.9mm, compatible
with AWG#28
Despite 1 mm Pitch, it is compatible with Ø0.9mm, UL1061·
AWG#28 Cable (Ø0.127×7)
It is possible to visually inspect
the assembled lance.
Figure 3.
2013.4②
1
DF50 Series●1mm Pitch, Board to Cable Lock Connector
■Product Specifications
Current Rating
1A
Operating Temperature Range
Operating Humidity Range
-35 to + 85°C (Note 1)
20 to 80%
Voltage Rating
AC/DC 100V
Storage Temperature Range
Storage Humidity Range
-10 to + 60°C (Note 2)
40 to 70% (Note 2)
Ratings
Items
Specifications
Conditions
1.Insulation resistance
No less than 500Mø
Measured at DC 100V
2.Withstand voltage
No flashover or breakdown
AC300V is applied for one minute
3.Contact resistance
No more than 30mø
Measured at 1mA and no higher than 20mV
4.Vibration Resistance
No electric outage of 1μs or greater
10 cycles in each of three directions at frequency 10-55 Hz,
half amplitude 0.75 mm
5.Shock Resistance
Accelerated velocity: 490m/s for 11ms, half-sine in 3 directions,
3 times for each direction
6.Moisture-resistance
Contact resistance: no more than 50mø;
insulation resistance: no less than 100Mø
Temperature: 40±2°C; humidity: 90 to 95%, left as it is for 96
hours
7.Temperature cycles
insulation resistance: no less than 500Mø
(-55°C for 30 minutes → 5 to 35°C for 2 to 3 minutes → 85°C for
30 minutes → 5 to 35°C for 2 to 3 minutes) in 5 cycles
8.Push-pull durability
life
30 times of push-pull operation
9.Solder Heat
Resistance
There should be no dissolution of the resin part which
will influence the performance.
Reflow: according to the Recommended Temperature Profile
Hand soldering: temperature of soldering iron at 350°C for 3 to 4 seconds
2
(Note 1) Temperature rise at the time of electrification is included.
(Note 2) The term “storage” refers to the long-term storage condition of unused products before PCB mounting.
Operating Temperature Range is applied to the deenergized state after mounting of PCB and the temporary storage state during transportation.
(Note 3) The above specifications are representative of this series. Please refer to “delivery specifications” for official individual agreement.
■Materials
Product
Part
Materials
Color / Treatment
UL Regulation
Header
(on the board side)
Insulator
Contact
Metal fitting
Locking metal fittings (DF50)
LCP
Brass
Brass (Note 1)
Stainless steel
UL94V-0
Crimp socket
Insulator
PBT
Crimp contact
Contact
Phosphorous Bronze
Black
Gold plating
Tin Plating
--------Black (DF50A)
White (DF50S)
Gold plating
UL94V-0
(Note 1) Phosphor bronze is applied a material for only to the single-row straight pin header.
■Product Number Structure
lConnector
lCrimp contact
DF50 − * DP − 1 V **
❶
❷
❸
❹
❶ Series Name: DF50 (Double-row pin header)
DF50S (Double-row crimp socket)
DF50A (Single-row)
❷ Number of contacts: 20, 30, 40, 50 (Double-row)
: 2 to 16 (Single-row)
❸ Connector type
DP: Double-row pin header
DS: Double-row socket
P: Single-row pin header
S: Single-row socket
❹ Contact Pitch: 1mm
❺
❻
DF50 − 2830 SCF A
❶
❽
❺ Wire connection method/Geometry of terminal
C: Crimp socket
V: SMT Straight Type
H: SMT Right Angle Type
❻ Specifications
51: SMT Embossed packaging
52: SMT Embossed packaging (with cap, DF50)
❼ Applicable wire size
2830: AWG28, 30
3032: AWG30, 32 (Under development)
❽ Method type/Packaging type
SCF: Socket contact reel
❾ Plating specifications
A: Gold plating
2
❼
❾
■Double-row straight pin header
A
B
Contact No.2
Contact No.*
P=1
Contact No.1
Contact No. *-1
Contact No.1 mark
7.05
8.15
1.6±0.05
0.9±0.05
Contact No.*
Contact No.1
0.6±0.05
P=1±0.05
Contact No.*-1
B±0.05
*: No. of Contacts
4±0.05
0.85 MIN
Contact No.2
1.6±0.05
1.8±0.05
0.7±0.05
BRecommended pattern schematic
[Specification Number : **, (**) ]
(51): Gold plating, embossed packaging
(52): Gold plating, embossed packaging,
with adsorption cap
Unit : mm
Product No.
HRS No.
No. of Contacts
A
B
C
D
E
F
G
DF50-20DP-1V (**)
CL665-0019-3-**
DF50-30DP-1V (**)
CL665-0001-8-**
30
13.18
9
14.2
28.4
32
38.4
32.4
18.18
14
14.2
28.4
32
38.4
32.4
DF50-40DP-1V (**)
CL665-0005-9-**
DF50-50DP-1V (**)
CL665-0011-1-**
40
23.18
19
20.2
40.4
44
50.4
44.4
50
28.18
24
20.2
40.4
44
50.4
44.4
(Note) Please place orders for embossed packaged products by the multiple of the number of reels. (1,000 connectors per reel)
Contact No.1
.75
R0
A-A
A
Ø1
Product Label
+2
R1
E±0.3
D±0.1
C±0.1
1.75±0.1
8
0.
2±0.1
(2.395)(Center of adsorption area)
1±
A
4±0.1
Ø2
.1
+0 0
5 Unreeling direction
Ø1
0.5
2±
Ø380±2
Unreeling direction
F MAX
G
Ø80±1
.1
+00
B
R
eel Condition Dimensions
3±
0.2
0.2±0.05
BEmboss tape dimensions
(in conformity to JIS C 0806)
12±0.1
3
■Double-row right angle pin header
Contact No.1 mark
A
B
P=1
8.66
Contact No.1
Contact No.*
Contact No.2
9
Contact
No. *-1
1.75±0.05
1.25±0.05
Contact No.*� Contact No.2
0.6±0.05
P=1±0.05
B±0.05
1.6±0.05
1.8±0.05
0.9±0.05
4.1±0.05
Contact No.*-1
Contact No.1
1.6±0.05
*: No. of Contacts
[Specification Number: **, (**)]
Unit : mm
Product No.
HRS No.
No. of Contacts
A
B
C
D
E
F
G
DF50-20DP-1H(**)
CL665-0016-5-**
9
14.2
28.4
32
38.4
32.4
DF50-30DP-1H(**)
CL665-0015-2-**
30
19.35
14
20.2
40.4
44
50.4
44.4
DF50-40DP-1H(**)
CL665-0014-0-**
40
24.35
19
20.2
40.4
44
50.4
44.4
DF50-50DP-1H(**)
CL665-0013-7-**
50
29.35
24
20.2
40.4
44
50.4
44.4
+2
1.75±0.1
C±0.1
4
4±0.1
R1
E±0.3
8
2±0.1
16±0.15
0.
B
Unreeling direction
1±
.1
+0 0
5
Ø1
Ø2
D±0.1
0.5
2±
Ø380±2
Unreeling direction
F MAX
G
Ø80±1
Product Label
Ø1.5 in front of the perforation
±0.
B-B
B
2
.1
+00
5
.7
R0
B
R
Ø13
0.2±0.05
■Single-row straight pin header
A
B
P=1
Contact No.1
Contact No.*
C
5.67
7.05
Contact No.1 mark
B±0.05
P=1±0.05
0.6±0.05
0.7±0.05
4.7±0.05
2.4±0.05
Contact No.1
3.15±0.05
Contact No.*
*: No. of Contacts
1.9±0.05
[Specification Number: **, (**) ]
Unit : mm
HRS No.
No. of Contacts
A
B
C
DF50A-2P-1V (**)
Product No.
CL665-1001-3-**
2
5.25
1
5
DF50A-3P-1V (**)
CL665-1004-1-**
3
6.25
2
6
DF50A-4P-1V (**)
CL665-1006-7-**
4
7.25
3
7
DF50A-5P-1V (**)
CL665-1008-2-**
5
8.25
4
8
DF50A-6P-1V (**)
CL665-1010-4-**
6
9.25
5
9
DF50A-7P-1V (**)
CL665-1012-0-**
7
10.25
6
10
DF50A-8P-1V (**)
CL665-1014-5-**
8
11.25
7
11
DF50A-9P-1V (**)
CL665-1016-0-**
9
12.25
8
12
DF50A-10P-1V (**)
CL665-1017-3-**
10
13.25
9
13
DF50A-11P-1V (**)
CL665-1019-9-**
11
14.25
10
14
DF50A-12P-1V (**)
CL665-1021-0-**
12
15.25
11
15
DF50A-13P-1V (**)
CL665-1023-6-**
13
16.25
12
16
DF50A-14P-1V (**)
CL665-1025-1-**
14
17.25
13
17
DF50A-15P-1V (**)
CL665-1027-7-**
15
18.25
14
18
DF50A-16P-1V (**)
CL665-1029-2-**
16
19.25
15
19
5
B
R
Product Label
A
+0.1
Ø1.5 to the depth
of the perforation
Ø13±
Unreeling direction
0.2
A
8
0.
1±
Ø2
R1
0.5
2±
(24)
22.25 +0.2
11.5±0.1
Ø1.5
30.4MAX
Ø380±2
1.75±0.1
12±0.1
4±0.1
2±0.1
Ø80±1
●DF50A-2P-1V to F50A-8P-1V (Number of contacts: 2 to 8)
Unreeling direction
B
R
±0.
2
0.2±0.05
0.2±0.05
0 .1
A
R0
Unreeling direction
.7 UnreelingAdirection
5 +0
0 .1
8
5 +0
0.
.7
1±
6
R0
Ø2
8
0.
1±
Ø2
R1
0.5
0.5
2±
Ø80±1
Ø380±2
Ø13
Product Label
Ø1.5 to the depth 38.4MAX
+2
of the perforation of 32.4
the perforation
32.4 +20
Ø13
±0. Unreeling directionUnreeling direction
2
Ø80±1
Ø380±2
Product Label
A-A
32±0.3
28.4±0.1
14.2±0.1
4±0.1
Geometry of reelGeometry
(FREE) of reel (FREE)
12±0.1 +0.1
.1
+0
0 A
A 2±0.1
4±0.1
2±0.1
A-A 1.5 0
.5
Ø1
Ø
R1
1.75±0.1
12±0.1
2±
32±0.3
28.4±0.1
14.2±0.1
1.75±0.1
●DF50A-9P-1V to DF50A-16P-1V (Number of contacts: 9 to 16)
■Single-row right angle pin header
A
B
P=1
Contact No.1
Contact No.*
Contact No.1 mark
7.6
6.08
C
B±0.05
P=1±0.05
0.6±0.05
Contact No.*
2.4±0.05
5.67±0.05
7.31±0.05
Contact No.1
1.51±0.05
*: No. of Contacts
1.9±0.05
Unit : mm
HRS No.
No. of Contacts
A
B
C
DF50A-2P-1H (**)
Product No.
CL665-1031-4-**
2
6.81
1
6
DF50A-3P-1H (**)
CL665-1032-7-**
3
7.81
2
7
DF50A-4P-1H (**)
CL665-1033-0-**
4
8.81
3
8
DF50A-5P-1H (**)
CL665-1034-2-**
5
9.81
4
9
DF50A-6P-1H (**)
CL665-1035-5-**
6
10.81
5
10
DF50A-8P-1H (**)
CL665-1037-0-**
8
12.81
7
12
DF50A-10P-1H (**)
CL665-1039-6-**
10
14.81
9
14
DF50A-12P-1H (**)
CL665-1041-8-**
12
16.81
11
16
DF50A-16P-1H (**)
CL665-1045-9-**
16
20.81
15
7
B
R
±0.2
C-C
Ø
Ø380±2
1.75±0.1
C
8
0.
R1
1±
11.5±0.1
Ø2
(24)
Ø13
.1
+0 0
5
1.
Ø1.5 to the depth 30.4 MAX
of the perforation
+2
24.4 0
Unreeling direction
0.5
2±
22.25 +0.2
Product Label
12±0.1
4±0.1
2±0.1
Ø80±1
●DF50A-2P-1H to DF50A-6P-1H (Number of contacts : 2 to 6)
Unreeling direction
C
B
R
●DF50A-8P-1H to DF50A-16P-1H (Number of contacts : 8 to 16)
Product Label
.1
+0 0
C
5
1.
Ø
G MAX
+2
H
Unreeling direction
Ø13
C-C
Ø1.5 to the depth
of the perforation
Ø80±1
4±0.1
2±0.1
±0.2
D±0.1
R1
0.2±0.05
E±0.1
8
0.
C
1±
Ø2
F±0.3
0.5
2±
Ø380±2
1.75±0.1
12±0.1
Unreeling direction
Unit : mm
Product No.
HRS No.
No. of Contacts
D
E
F
G
H
DF50A-8P-1H (**)
CL665-1037-0-**
8
14.2
28.4
32
38.4
32.4
DF50A-10P-1H (**)
CL665-1039-6-**
10
20.2
28.4
32
38.4
32.4
DF50A-12P-1H (**)
CL665-1041-8-**
12
20.2
28.4
32
38.4
32.4
DF50A-16P-1H (**)
CL665-1045-9-**
16
20.2
40.4
44
50.4
44.4
8
■Double-row crimp socket
A
B
Contact No.2
P=1
Contact No.*
Contact No.1
Contact No. *-1
Contact No.1 mark
8.5
6
CAV No.
HRS mark
*: No. of Contacts
Unit : mm
Product No.
HRS No.
No. of Contacts
A
B
DF50S-20DS-1C
CL665-0020-2-00
9
DF50S-30DS-1C
CL665-0021-5-00
30
17.28
14
DF50S-40DS-1C
CL665-0022-8-00
40
22.28
19
DF50S-50DS-1C
CL665-0012-4-00
50
27.28
24
(Note) Sold in 100 piece units.
■Single-row crimp socket
A
B
P=1
Contact No.1 mark
Contact No.*
Contact No.1
6
6.85
*: No. of Contacts
Unit : mm
Product No.
HRS No.
No. of Contacts
A
B
DF50A-2S-1C
CL665-1002-6-00
2
3.95
1
DF50A-3S-1C
CL665-1005-4-00
3
4.95
2
DF50A-4S-1C
CL665-1007-0-00
4
5.95
3
DF50A-5S-1C
CL665-1009-5-00
5
6.95
4
DF50A-6S-1C
CL665-1011-7-00
6
7.95
5
DF50A-7S-1C
CL665-1013-2-00
7
8.95
6
DF50A-8S-1C
CL665-1015-8-00
8
9.95
7
DF50A-9S-1C
CL665-1100-5-00
9
10.95
8
DF50A-10S-1C
CL665-1018-6-00
10
11.95
9
DF50A-11S-1C
CL665-1020-8-00
11
12.95
10
DF50A-12S-1C
CL665-1022-3-00
12
13.95
11
DF50A-13S-1C
CL665-1024-9-00
13
14.95
12
DF50A-14S-1C
CL665-1026-4-00
14
15.95
13
DF50A-15S-1C
CL665-1028-0-00
15
16.95
14
DF50A-16S-1C
CL665-1030-1-00
16
17.95
15
9
■Crimp contact
0.5
4
Ø1.2
3
4.6
1.9
5.05
0.8
0.63
0.12
1.4
2.7
4
Product No.
DF50-2830SCFA
DF50K-2830SCFA
DF50-3032SCFA
HRS No.
Type
Quantity
Treatment
CL665-0002-0-00
Reel contact
30,000 pieces per reel
Gold plating
CL665-0017-8-00
Reel contact
Gold plating
Under development
(Note) As this product is sold per (30,000 piece) reel, please place orders by the multiple of the number of reels.
lApplicable wire (Tinned Annealed Copper Wire)
lStrip length
Recommended wire
Product No.
DF50-2830SCFA
DF50K-2830SCFA
HRS No.
Cable name
Conductor size
(Core structure)
UL1061
AWG28
(7pieces / Ø0.127mm)
UL1061
AWG30
(7pieces / Ø0.102mm)
UL1571
AWG28
(7pieces / Ø0.13mm)
CL0665-0002-0-00
CL0665-0017-8-00
Diameter
of the wire
Ø0.8 to
0.9mm
Ø0.58mm
(Note) Please contact our Sales Department when you are using wires other than applicable wires.
■Applicable crimping tool
Type
Applicator
Press body
Hand tool
Pull-out tool
Product No.
HRS No.
Applicable contact
AP105-DF50-2830S
CL901-4616-0
DF50-2830SCFA
CM-105
CL901-0005-4
HT305/DF50-2830HC
CL902-4634-8
DF50-2830SCFA
DF-C-PO(B)
CL550-0179-2
DF50-2830SCFA
(Note) Problems caused by tools other than our specified ones are out of warranty events.
10
1.3 to 1.7mm
BPrecautions
1.Recommended Temperature Profile
(Compatible with lead-free soldering)
10secMAX
MAX 250℃
TEMPERATURE
250
220℃
200
180℃
150
100
90~120sec
PRE-HEATING TIME
60secMAX
TIME (sec)
SOLDERING TIME
[Applicable Conditions]
1.Peak temperature: a maximum of 250°C for no more than 10 seconds
2.Heating unit: no less than 220°C for no more than 60 seconds
3.Preheating unit: 150 to 180°C for 90 to 120 seconds
4.Number of times: no more than 2 times
* Measurement is conducted at the contact lead part
As it may change depending on the conditions such as solder paste types,
manufacturers, PCB size, and other soldering materials, please fully check the
mounting conditions before use.
(Note 1) This temperature profile is a recommended value.
2.Recommended hand soldering
conditions
Temperature of soldering iron: 350±10°C, soldering time: 3 to 4 seconds
3.Recommended screen thickness and
aperture ratio (Pattern surface ratio)
Thickness: 0.1mm, aperture ratio: 100%
4.Warpage of the Board
A maximum of 0.02mm at the center of connector, as measured from either end of
the connector
5.Cleaning Conditions
IPA cleaning is allowed. (Cleaning is not recommended because cleaning may
change the push/pull feeling etc. Please contact us when you use other cleaning
agents. )
6.Precautions
▪ When inserting a crimp contact into a crimp socket, do not insert it at a slanted
angle in order to maintain the reliability of its performance.
▪ Please refrain from pushing/pulling operation when the PCB is not mounted. It
may cause breakage, contact deformation, etc.
▪ Please refrain from pushing/pulling operation with wires in your hand. It may
cause damage.
▪ During hand soldering, do not apply flux which will cause flux oozing on
connector.
▪ This product may have a little difference in its molded color depending on the
production lot, but the difference doesn't have any influence on the performance.
11
USA:
HIROSE ELECTRIC (U.S.A.), INC. Headquarters
2688 Westhills Court, Simi Valley, CA 93065-6235
Phone : +1-805-522-7958
Fax : +1-805-522-3217
http://www.hiroseusa.com
USA:
HIROSE ELECTRIC (U.S.A.), INC. San Jose Office
3255 Scott Boulevard, Building 7, Suite 101 Santa
Clara, CA 95054
Phone : +1-408-253-9640
Fax : +1-408-253-9641
USA:
HIROSE ELECTRIC (U.S.A.), INC. Detroit Office (Automotive)
37677 Professional Center Drive, Suite #100C
Livonia, MI 48154
Phone : +1-734-542-9963
Fax : +1-734-542-9964
THE NETHERLANDS:
HIROSE ELECTRIC EUROPE B.V.
Hogehillweg #8 1101 CC Amsterdam Z-O
Phone : +31-20-6557460
Fax : +31-20-6557469
http://www.hiroseeurope.com
GERMANY:
HIROSE ELECTRIC EUROPE B.V. German Branch
Herzog-Carl-Strasse 4 D-73760 Ostfildern
(Scharnhauser Park)
Phone : +49-711-4560-02-1
Fax : +49-711-4560-02-299
http://www.hirose.de
UNITED KINGDOM:
HIROSE ELECTRIC EUROPE B.V. UK Branch
22 Vincent Avenue, Crownhill Business Centre,
Crownhill, Milton Keynes, MK8 0AB
Phone : +44-1908-305750
Fax : +44-1908-305768
http://www.hirose.co.uk
CHINA:
HIROSE ELECTRIC TRADING (SHANGHAI) CO., LTD.
1601,Henderson Metropolitan,NO.300 ,East Nanjing
Road,Huangpu District, Shanghai,China 200001
Phone : +86-21-6391-3355
Fax : +86-21-6391-3335
http://www.hirose-china.com.cn
CHINA:
HIROSE ELECTRIC TRADING (SHANGHAI) CO., LTD. Beijing Branch
A1001, Ocean International Center, Building 56# East 4th
Ring Middle Road, Chao Yang District, Beijing, 100025
Phone : +86-10-5165-9332
Fax : +86-10-5908-1381
CHINA:
HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD.
Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre
5002, ShenNanDong Road, ShenZhen City, Guangdong Province, 518008
Phone : +86-755-8207-0851
Fax : +86-755-8207-0873
HONG KONG:
HIROSE ELECTRIC HONGKONG TRADING CO., LTD.
Room 1001, West Wing, Tsim Sha Tsui Centre, 66
Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong
Phone : +852-2803-5338
Fax : +852-2591-6560
http://www.hirose-hongkong.com.hk
TAIWAN:
KOREA:
HIROSE KOREA CO., LTD.
1261-10, Jeoungwhang-Dong, Shihung-City,
Kyunggi-Do 429-450
Phone : +82-31-496-7000,7124
Fax : +82-31-496-7100
http://www.hirose.co.kr
SINGAPORE:
HIROSE ELECTRIC SINGAPORE PTE. LTD.
10 Anson Road #26-1 International Plaza 079903
Phone : +65-6324-6113
Fax : +65-6324-6123
http://www.hirose-singapore.com.sg
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. Bangalore Liaison office
Unit No.03, Ground Floor, Explorer Building International Tech
Park Whitefield Road, Bangalore 560066 Karnataka, India
Fax : +65-6324-6123
HIROSE ELECTRIC TAIWAN CO., LTD.
103 8F, No.87, Zhengzhou Rd., Taipei
Phone : +886-2-2555-7377
Fax : +886-2-2555-7350
http://www.hirose-taiwan.com.tw
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD Delhi Liaison Office
Suite No. 606 5th Floor SB Tower 1A/1 Sector 16
A Filmcity Noida 201301 Uttar Pradesh-India
Phone : +91-120-4804917
Fax : +91-120-4804949
http://www.hirose.com/sg/
MALAYSIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD (Representative office)
1-10-07, Suntech @ Penang Cybercity (1164),Lintang
Mayang Pasir 3,11950, Bayan Baru, Penang, Malaysia.
Phone : +604-619-2564
Fax : +604-619-2574
12
6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 04/2013. Contents are subject to change without notice for the purpose of improvements.
