1675
    ADAFRUIT
    JACK .032-.046".236"L SLD MNT
1675 数据手册
10-pin 2x5 Socket-Socket 1.27mm IDC (SWD) Cable - 150mm long PRODUCT ID: 1675  Description These little cables are handy when programming or debugging a tiny board that uses 10-pin 1.27mm (0.05") pitch SWD programming connectors. We see these connectors often on ARM Cortex dev kits, and have a few handy in our ARM-dev box. We thought you may want a backup cable as well, so now they are in the Adafruit shop! One cable per order. The ribbon cable is 0.06mm/0.025" pitch and the connector is a 1.27mm (0.05") pitch 2x5 box. These are not for use with programming most AVRs or other large devices that have 0.1" pitch connectors so be aware which you need!  Technical Details o o o Dimensions: 150mm long x 6mm wide / 5.9" x .3" Connector: 5mm x 3mm Weight: 1.9g        Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“1675”相匹配的价格&库存,您可以联系我们找货
