B126-2A0
B126-2A0
    TRIPPLITE
    HDMIEXTNDR/SPLITTER2-PRT200FT
B126-2A0 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2-Port HDMI over Cat5/6 Active Extender/Splitter, Remote Receiver for Video/Audio, Up to 150 ft. (45 m), TAA MODEL NUMBER: B126-2A0 Highlights ● Supports high-definition video resolutions up to 1080p (60 Hz) ● Supports stereo and 7.1channel surround sound audio ● Works with all operating systems and HDMI video sources ● Plug and play—no software or drivers to install ● Built-in equalization control lets you adjust monitor image System Requirements Package Includes ● B126-2A0 HDMI over Cat5/Cat6 Active Remote Receiver ● Screwdriver for adjusting equalization ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60 Hz, 0.5A; Output: 5V, 2A, 4.5-ft. (1.37 m) ● Mounting hardware ● Owner's Manual Works with Tripp Lite’s B126-Series transmitters to receive an HDMI signal via one Cat5e/6 cable and split it to 2 projectors, monitors or televisions. Ideal for digital signs, schools and trade show presentations. Description The B126-2A0 HDMI over Cat5/Cat6 Active Remote Receiver works with Tripp Lite's B126-002 or B126004 transmitter to extend an HDMI signal and split it to two projectors, monitors or televisions. It's ideal for digital signs, trade shows, presentations, classrooms, churches, retail settings and other applications where the video source is located farther than conventional cables allow or that require multiple displays connected to one source. The receiver uses HDMI cable (see Tripp Lite's P568-Series) to connect to the monitors and Cat5e/6 cable to receive the signal from the transmitter or a remote repeater in the chain (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series). The B126-2A0 can extend a 1080i (60 Hz) signal up to 200-ft. (60.96 m), a 1080p (60 Hz) signal up to 150-ft. (45.72 m) and a 3D signal up to 125-ft. (38.1 m). You can connect up to three B126-110 remote repeaters in the chain for a maximum of six HDMI displays and full signal extension of 700-ft. (213.36 m) (1080i), 500-ft. (152.4 m) (1080p) or 400-ft. (121.92 m) (3D). In addition to crystal-clear video, the B126-2A0 delivers full, rich stereo and 7.1-channel surround sound (multi-channel or PCM) audio when paired with a B126-002 or B126-004 transmitter. Built-in equalization control lets you fine-tune the image quality at each remote display. Supports 24-bit True Color (8 bits per channel) and HDCP compatibility. Easy to set up with no software or drivers to install. Mounts to a wall, rack or pole using the included hardware. Features Extends High-Definition Signals ● Works in tandem with Tripp Lite's B126-002 or B126-004 transmitter unit ● Extends a 1080i (60 Hz) signal up to 200-ft. (60.96 m), a 1080p (60 Hz) signal up to 150-ft. (45.72 m) and a 3D signal up to 125-ft. (38.1 m) ● Connect up to 3 B126-110 remote repeaters to the chain for maximum signal range of 700-ft. (213.36 m) (1080i), 500-ft. (152.4 m) (1080p) and 400-ft. (121.92 m) (3D) ● Connects to previous link in the chain with one Cat5e/6 cable (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series) Supports the Latest Video and Audio Resolutions 1/5 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Works with all operating systems and HDMI video sources ● Supports HD resolutions up to 1080p (60 Hz) ● Supports stereo and 7.1-channel surround sound (multi-channel or PCM) audio when paired with a B126-002 or B126-004 transmitter ● Supports 24-bit True Color (8 bits per channel) and HDCP ● Built-in equalization control lets you adjust the image on the local monitor Easy to Set Up and Use ● Plug-and-play engineering—no software or drivers to download and install ● Connects quickly to monitors with HDMI cable, such as Tripp Lite's P568-Series ● LEDs indicate at a glance when the unit is receiving power and a signal from the previous link in the chain ● Included mounting hardware lets you install the unit on a wall, rack or pole TAA-Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332180728 Product Type Receiver Technology HDMI; Cat5/5e; Cat6 Host Connector RJ45 (FEMALE) VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 720P Range (ft) 200 Max 1080P Range (ft) 150 Max 1280 x 720 (720p) Range (ft) 150 Max 1920 x 1080 (1080p) Range (ft) 150 Receiver/Transceiver Video Output HDMI Receiver - Number of Video Outputs 2 Range Extension using other Tripp Lite product 175ft @ 1080i 125ft @ 1080p Recommended Cabling N202-Series Cat6 Patch Cable Other Tripp Lite product used to extend range B126-110 Max Supported Color Depth 24-bit True Color HDR Support No 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States 3D Video Supported Yes Chroma Sub Sampling 4:4:4 Maximum Signal Range (ft) 150 Maximum Signal Range (m) 46 AUDIO Audio Input HDMI Audio Output HDMI Audio Specification Stereo Audio INPUT Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.37 AC Plug Type NEMA 1-15P Power Source Unit (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 4.5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators Green (Power), Orange (Activity) PHYSICAL Color Black Included Mounting Accessories Wallmount Number of Displays 2 Optional Mounting Accessory Notes Can DIN Mount using Tripp Lite Bracket  B110-DIN-02  Form Factor/Mounting Options Box; Wall-mount 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 2.20 x 6.30 x 7.20 Shipping Dimensions (hwd / cm) 5.59 x 16.00 x 18.29 Shipping Weight (lbs.) 1.20 Shipping Weight (kg) 0.54 Unit Dimensions (hwd / in.) 1.000 x 2.500 x 3.600 Unit Dimensions (hwd / cm) 2.54 x 6.35 x 9.14 Unit Packaging Type Box Unit Weight (lbs.) 0.2 Unit Weight (kg) 0.09 Housing Metal ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 200 Max 480P Range (ft) 200 Max 1440 x 900 Range (ft) 200 Max 1080i Range (ft) 200 Max 480i Range (ft) 200 Max 640 x 480 Range (ft) 200 Max 800 x 600 Range (ft) 200 Max 1600 x 1200 Range (ft) 200 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Number of Ports 2 Side A - Connector 1 RJ45 (FEMALE) Side B - Connector 1 (2) HDMI (FEMALE) 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States FEATURES & SPECIFICATIONS HDCP Specification 1.4 Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer Yes STANDARDS & COMPLIANCE External Power Supply Certifications FCC; PSE; TUV; RoHS; UL; cUL Product Compliance RoHS; REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B126-2A0 价格&库存
很抱歉,暂时无法提供与“B126-2A0”相匹配的价格&库存,您可以联系我们找货
