1000 Eaton Boulevard
Cleveland, OH 44122
United States
2x2 HDMI Matrix Switch with Remote Control 1080p @ 60 Hz (HDMI 2xF/2xF), TAA
MODEL NUMBER: B119-2X2
Highlights
Share multiple HDMI sources
between multiple monitors
Supports computer video
resolutions up to 1920 x 1200,
and HD resolutions up to 1080p
@ 60Hz
Plug-and-play; No software or
drivers required
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
Package Includes
Connect 2 HDMI source devices to 2 HDMI displays and either share video on both or switch between
them.
Description
Tripp Lite's B119-2X2 is a 2x2 HDMI Matrix Switch that routes high definition video from any two HDMI
sources to any two HDMI displays. It supports computer video resolutions up to 1920 x 1200, and HD
resolutions up to 1080p @ 60Hz. The 2x2 Matrix eliminates the need to disconnect and reconnect HDMI
sources. It works with any HDMI source that connects to an HDMI display, and each source is accessible
at all times by any display by selecting it with an IR remote, or using the RS232 port to switch the unit.
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases.
Features
Share multiple HDMI sources between multiple monitors ( 2 Input, 2 Output )
Allows any input to be routed to any output; or the same input to be routed to multiple outputs
Switch between inputs via pushbuttons, remote control, or RS-232 serial
Monitors can be located up to 25 ft. from the switch
Supports computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p @ 60Hz
HDCP and EDID compatible
Mounting hardware included
Plug-and-play; No software or drivers required
Compatible with all operating systems
Specifications
OVERVIEW
UPC Code
037332180186
1/3
B119-2X2 Local Transmitter
Unit
External Power Supply with
NEMA 1-15P Plug(Input: 100240V, 50/60Hz, 0.5A; Output:
5V, 2A)
3.5 mm to DB9 Adapter Cable
Mounting Hardware
Remote Control
Owner’s Manual
Cleveland, OH 44122
United States
Technology
HDMI; IR
VIDEO
Supported Resolutions
1920x1080 (1080p)
POWER
Power Source Type
AC Adapter
External Power Supply Plug(s)
NEMA 1-15P North America
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 0.5A
External Power Supply Output
Specs (V / A)
5V / 2A
External Power Supply Cord Length
(ft.)
4.0
(m.)
1.2
AC Adapter
Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A
PHYSICAL
Color
Black
Included Mounting Accessories
Yes
Rackmountable
Yes
Shipping Dimensions (hwd / in.)
10.24 x 2.17 x 6.46
Shipping Dimensions (hwd / cm)
26.01 x 5.51 x 16.41
Shipping Weight (lbs.)
1.50
Shipping Weight (kg)
0.68
Unit Dimensions (hwd / in.)
1.200 x 9.200 x 3.900
Unit Dimensions (hwd / cm)
3.05 x 23.37 x 9.91
Unit Weight (lbs.)
1.45
Unit Weight (kg)
0.66
COMMUNICATIONS
Port Control
Push Buttons
Signal Range (ft.)
60
Signal Range (m)
18
IP Remote Access
Yes
EDID Compatible
Yes
RS-232 Serial Extension Support
Yes
2/3
Cleveland, OH 44122
United States
CONNECTIONS
Number of Ports
2
Side A - Connector 1
(2) HDMI (FEMALE)
Side B - Connector 1
(2) HDMI (FEMALE)
STANDARDS & COMPLIANCE
Product Compliance
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“B119-2X2”相匹配的价格&库存,您可以联系我们找货
