Mini Thermal Receipt Printer
Created by Phillip Burgess
https://learn.adafruit.com/mini-thermal-receipt-printer
Last updated on 2022-03-21 02:14:03 PM EDT
©Adafruit Industries
Page 1 of 43
Table of Contents
Overview
3
Power
4
First Test
5
• Print Test Page
6
Arduino Code
8
9
9
10
10
11
11
For Product #597
For Product #2751
For Product #2752
For Product #2753
Connect to Arduino
Install Library
Printing Text
14
Bitmap Printing
15
• Windows
• Mac and Linux
15
18
Barcode Printing
19
CircuitPython
CircuitPython Microcontroller Wiring
Python Computer Wiring
CircuitPython Installation of Thermal Printer Library
Firmware Version and Baud Rate
Usage
Create ThermalPrinter Class
Initialize ThermalPrinter
Test Page Print
Printer Fonts
Print Barcodes
Check Paper
23
24
24
25
26
26
27
27
29
30
Python Docs
33
Downloads
33
• Firmware Changer
33
Troubleshooting!
33
Hacking!
37
Parts and Tools Needed
Procedure
Code Changes
Printing Huge Images
Other Things to Know
38
38
41
42
42
Page 2 of 43
Overview
Add a mini printer to any microcontroller project with this very cute thermal printer.
Also known as receipt printers, they’re what you see at the ATM or grocery
store. Now you can embed a little printer of your own into an enclosure. This printer is
ideal for interfacing with a microcontroller, you simply need a 3.3V to 5V TTL serial
output from your microcontroller to print text, barcodes, bitmap graphics, even a QR
code!
This printer uses very common 2.25" wide thermal paper, available in the Adafruit
shop (http://adafru.it/599) or any office or stationery supply store. Up to 50 feet of
paper can fit in the bay. You will also need a 5 Volt to 9 Volt regulated DC power
supply that can provide 1.5 Amps or more during high-current printing — our 5V 2A
power supply will work very nicely (http://adafru.it/276).
You can pick up a thermal printer pack including printer, paper, power supply and
terminal-block adapter in the Adafruit shop! (http://adafru.it/600)
Of course, we wouldn't leave you with a datasheet and a “good luck!” — this tutorial
and matching Arduino library demonstrate the following:
• Printing with small, medium and large text
• Bold, underline and inverted text
• Variable line spacing
• Left, center and right justification
Page 3 of 43
• Barcodes in the following standard formats: UPC A, UPC E, EAN13, EAN8,
CODE39, I25, CODEBAR, CODE93, CODE128, CODE11 and MSI - with adjustable
barcode height
• Custom monochrome bitmap graphics
• How to print a QR code
Power
These printers use a thermal head to heat the special receipt paper and draw images
and text. That makes the printer very small — there's no moving ink head — but it
means they require a lot of power. This printer in particular requires 5 to 9 Volts, 1.5
Amps current! That means you will need a fairly beefy supply and you cannot run it off
of USB power. An external adapter is required!
We suggest using the 5V 2A power supply in our shop (http://adafru.it/276). It’s got
plenty of power to keep the printer happy and you can also use it to run some
microcontrollers or sensors off of the remaining 500 mA current that is not required
by the printer.
A quick way to power the printer is by just using a 2.1mm jack adapter (http://adafru.it/
368), which you can attach to the printer’s red/black wires:
Page 4 of 43
First Test
The first test you should do is to just make sure that the printer is running and you
have the power wired up right.
First up, pull the little plastic tab up top to open up the paper holder. Then insert a roll
of 57.5mm (2 1/4 inches) thermal paper into the bay as shown below.
• For Product ID #597 "Mini Thermal Printer" (http://adafru.it/597)The optimal
length of the paper will be 50 feet (about 15 meters) so try to pick up that size.
Sometimes if you buy paper from an office supply shop, its a little longer, around
80 or 85 feet in which case you'll need to remove paper from the roll until its
1.5"/40mm in diameter and fits easily.
• For Product #2751 "Tiny Thermal Printer" (http://adafru.it/2751) The optimal
length of the paper will be 33 feet (about 10 meters) so try to pick up that size.
• For Proudct #2752 "Nano Thermal Printer" (http://adafru.it/2752) The optimal
length of the paper will be 16 feet (about 5 meters) so try to pick up that size.
• For our Thermal Printer guts kit (http://adafru.it/2753), there's no paper bay so
you can use any size.
Make sure that the paper doesn't bind or stick in the bay, it should rotate freely.
None of these small thermal printers have a cut feature; pull the finished print against
the perforated edge.
Page 5 of 43
As previously described, power the printer using a 5V to 9V 1.5A or higher power
supply, such as wiring up a 2.1mm DC power jack:
Print Test Page
Most of these thermal printers have a test feature providing basic diagnostics. You’ll
then know that power is good, paper is correctly loaded, and have some
configuration details of the particular unit.
On most Mini and Tiny printers: hold down the button on the top of the printer while
connecting power to print a test page. In normal use, tapping this button feeds the
paper by one line.
Page 6 of 43
On most Nano printers and printer guts: connect power first, then tap the button on
the control board to print a test page.
Not all “printer guts” units have a button installed. If needed, you can make a
temporary connection across the “J1” pads using a jumper wire or metal tweezers.
Occasional factory production changes occur…if you don’t get a test page using the
method above for you model, try the opposite method. A few may even lack a test
page feature, but the status LED provides an indication of good power.
The status LED may blink when the printer is powered. It will not necessarily be
on steady! This varies from model to model.
If you don't get a printout, check that the paper is inserted correctly and not binding,
that the power is correctly wired, power supply is plugged in, etc. Then try again.
Note the baud rate on the test page. This may be 19200 or 9600. We'll need this
number later:
Page 7 of 43
If no baud rate is shown, or your printer has no self-test page feature, try using
9600 as the default.
Arduino Code
To send data to the printer, we will use a 5V TTL serial connection. This is not the
same as the 10V RS232 serial from a computer’s 9-pin serial port — don’t connect the
printer directly to a standard PC port or you may damage it. It’s possible to use
something like an FTDI cable to talk to the printer, but we’re going to assume that
nearly everyone will want to use it with a microcontroller. This tutorial shows how to
wire it up to an Arduino, and our example code is Arduino-compatible. Any
microcontroller that can output TTL serial will work, with suitable adaptation to the
code.
To start, we’ll connect to the data cable of the printer. An easy way to connect is to
simply press 22AWG or so wires of matching colors into the plug, then use those to
extend the connection to an Arduino.
Page 8 of 43
For Product #597
The "Mini Thermal Printer"s data cable has three wires
• black = GROUND
• yellow = data IN to the printer
• green = data OUT of the printer
On the power cable, connect red to 5-9VDC power and black to power ground
For Product #2751
The "Tiny Thermal Printer"s (http://adafru.it/2751) data cable has five wires
• black = GROUND
• green = data IN to the printer - Opposite of the Mini Thermal printer!
• yellow = data OUT of the printer - Opposite of the Mini Thermal printer!
leave red and blue not connected to anything
Page 9 of 43
For Product #2752
The "Nano Thermal Printer"s (http://adafru.it/2752) data cable has five wires and no
power cable
• black = GROUND
• blue = data IN to the printer (labeled RX on the PCB)
• green = data OUT of the printer (labeled TX on the PCB)
• red = 5-9VDC power (connect the ground of the power plug to the same ground
as data above)
• yellow = DTR, not used at this time, skip!
For Product #2753
The "Thermal Printer Guts"s (http://adafru.it/2753) data cable has five wires and no
power cable
This cable may not have colors in which case look for the text on the connector. Its,
sadly, covered when you plug in the cable
• VH = 5-9VDC power (connect the ground of the power plug to the same ground
as data above)
• GND = GROUND
• labeled RX on the PCB = data IN to the printer
• labeled TX on the PCB = data OUT of the printer
Page 10 of 43
• labeled DTR on the PCB = connect to GND.
Connect to Arduino
At the Arduino end, the Data OUT wire connects to digital pin 5, Data In goes to digita
l pin 6 and Ground to any of the GND pins. You can change the digital pins later, but
to match the example code, stick to this for now!
Note the colors of the wires below don't necessarily match the colors of the data
cable, so double check the in and out designation for your product, they're all
different!
Install Library
Now its time to download the Arduino library code (https://adafru.it/aHt).
Go to the Arduino Library manager under Sketch -> Include Library -> Manage
Libraries...
Page 11 of 43
From within the manager install Adafruit Thermal Printer library
We also have a great tutorial on Arduino library installation at:
http://learn.adafruit.com/adafruit-all-about-arduino-libraries-install-use (https://
adafru.it/aYM)
After installing the library, restart the Arduino IDE.
You should now be able to access the sample code by navigating through menus in
this order: File→Sketchbook→Libraries→Adafruit_Thermal→A_printertest
Page 12 of 43
If your printer test page shows 'BAUDRATE: 9600', you'll need to make a small
change to the library source code. Using a text editor (Notepad, etc.) open the file
Adafruit_Thermal.cpp and change this line:
#define BAUDRATE
19200
to this:
#define BAUDRATE
9600
Some printers arrive from the factory set for 19200 baud, but a few may be set to
9600. This will not negatively impact the performance of your unit! The speed of the
paper through the printer is already much less than this and you will not see any
difference…it's strictly a data protocol issue of getting the microcontroller and printer
communicating.
OK upload the sketch (with baudrate change if necessary) to the Arduino. You should
see the printer print out the example receipt which includes all the capabilities of the
library.
If this does not work, first check that the printer and Arduino are both powered, and
that the data in, out and ground wires are properly connected to the Arduino.
Page 13 of 43
Printing Text
The thermal printer has a few handy things it can do, most of which are in the A_print
ertest sketch. These are shown in the image above. In order, starting from the top:
• Inverted text: this is invoked by calling inverseOn() — you will get text that’s
white-on-black instead of black-on-white. inverseOff() turns this off.
• Double height: this makes text thats extra tall, call doubleHeightOn() — likewise,
turn off with doubleHeightOff()
• Left/Center/Right justified: this aligns text to the left or right edge of the page, or
centered. You can set the alignment by calling justify('R') (for right-justified), justif
y('C') (for centered) or justify('L') (for left-justified). Left-justified is the default
state.
• Bold text: makes it stand out a bit more, enable with boldOn() and turn off with b
oldOff()
• Underlined text: makes it stand out a bit more, enable with underlineOn() and
turn off with underlineOff()
• Large/Medium/Small text: by default we use small, medium is twice as tall, large
is twice as wide/tall. Set the size with setSize('L'), setSize('M') or setSize('S')
• Line spacing: you can change the space between lines of text by calling setLine
Height() where numpix is the number of pixels. The minimum is 24 (no extra
space between lines), the default spacing is 32, and double-spaced text would
be 64.
Look through the source of the A_printertest sketch to see these used in context.
Page 14 of 43
Bitmap Printing
This printer can print out bitmaps, which can add a touch of class to a receipt with
your logo or similar.
The first step is to get the logo prepared. The printer can only do monochrome (1-bit)
images, and the maximum width is 384 pixels. We suggest starting with a small bitmap
(100 pixels or less on each side) and then experimenting to get the size and look you
want.
A few steps are required to prepare an image for printing. For Windows users, there’s
a nice graphical user interface for this. For Mac and Linux, different tools are used…
not as visually slick, but they do the job well.
These barcode printers shouldn't be confused with a LaserJet - they're not good
at printing heavy/dense images with lots of black or they might stick and stall!
Windows
Use an image editing program to save your image as a 1-bit BMP — in Windows, the
built-in Paint program will suffice.
Download, install and run LCD Assistant (https://adafru.it/aPs). This program is for
Windows only but does a really fantastic job! Load the BMP file you previously
generated (in Paint, etc.). The file must be in BMP format — the software won’t read
PNG, GIF, etc. Then a couple of settings need to be adjusted…
Page 15 of 43
First, in the “Byte orientation” section of the settings, select “Horizontal” (item A in the
image above).
Second (item B above), you may need to change the Width setting. Because this
software (and the thermal printer) handle images in horizontal groups of eight pixels,
if the image width is not a multiple of 8, it will be truncated (cropped) to the nearest
smaller 8-pixel boundary. For example, with the 75 pixel wide image above, the output
will be cropped to only 72 pixels wide, losing some data from the right edge. To avoid
this, increase this number to the next multiple of 8 (that would be 80 for the example
above), and the output will be padded with blank pixels to cover the gap. Remember
the number you use here, you’ll need it later.
The image height does not need to be adjusted this way, only width.
Set the table name to something short but descriptive (e.g. “adalogo” above), then
select Save Output from the File menu. Give the file a similarly brief but descriptive
name, ending in “.h” (e.g. “adalogo.h”).
To get this file into your Arduino sketch, select “Add File…” from the Sketch menu. This
will add a new tab to your code. Your original code is still there under the leftmost tab.
A couple of small changes are now needed in both tabs. First, at the top of the file
containing the new table data, change “const unsigned char” to “static const uint8_t
PROGMEM” as shown below:
Page 16 of 43
Next, in the tab containing the main body of your code, add an “include” statement to
reference the new file:
#include "adalogo.h"
Check the A_printertest example sketch if you’re not sure how to include the code
properly.
You can now output the image by calling printBitmap(width, height, tablename), where
width and height are the dimensions of the image in pixels (if you changed the image
width to a multiple of 8 as previously described, use that number, not the original
image size), and tablename is the name of the array in the new tab (e.g. “adalogo”
above).
Having a graphical user interface is nice, but some of these extra steps can be
confusing and error-prone. If you prefer, the technique below for Mac and Linux works
in Windows as well.
Page 17 of 43
Mac and Linux
The conversion tool for Mac and Linux doesn’t include a fancy GUI, but it works well
and avoids several steps (and potential mis-steps). The source image doesn’t need to
be in BMP format — most image formats can be read natively — and the output can be
added to a sketch with no further editing. It works for Windows as well, if you’d rather
use this method.
First, if you don’t already have the Processing language installed, download it from
processing.org (https://adafru.it/aPt). Processing looks almost exactly like the Arduino
IDE, but it’s for writing code for your normal computer, not a microcontroller. This can
be a little confusing to first-timers, so if something doesn’t seem to compile, make
sure you’re running code in the right environment: Arduino for for the Arduino board,
Processing for your computer.
This code runs in Processing 2.x, the latest version of Processing available from
their website. Don't use the older Processing 1.5.x version!
The Adafruit_Thermal library folder that you previously downloaded contains a subfolder called processing. Inside that is a sketch called bitmapImageConvert.pde. Load
this into Processing and press RUN (the triangle button).
You’ll be prompted to select an image using the system’s standard file selection
dialog. The program runs for just a brief instant, and will create a new file alongside
the original image file. For example, if you selected an image called “adalogo.png”,
there will be a new file called “adalogo.h” in the same location. This file contains code
to add to your Arduino sketch. You shouldn’t need to edit this file unless you want to
change the variable names within.
properly.
Page 18 of 43
If the source image was called adalogo.png, then the resulting .h file (adalogo.h) will
contain three values called adalogo_width, adalogo_height and adalogo_data, which
can be passed directly and in-order to the printBitmap() function, like this:
printBitmap(adalogo_width, adalogo_height, adalogo_data);
Barcode Printing
Thermal printers are really good at printing barcodes! This printer supports 11 different
codes - UPC A, UPC E, EAN13, EAN8, CODE39, I25, CODEBAR, CODE93, CODE128,
CODE11 and MSI. It only supports linear (1-D) barcodes, and can’t generate 2-D
barcodes like QR codes (although there is a hack you can do, see below!) Barcodes
are generated “on the fly,” which is nice — you can customize the height and data
included quite easily.
You can make a barcode by calling printBarcode("barcodedata", BARCODETYPE), whe
re the first string is the data to encode (e.g. a UPC code) and BARCODETYPE can
be UPC_A, UPC_E, EAN13, EAN8, CODE39, I25, CODEBAR, CODE93, CODE128,
CODE11 or MSI.
Some barcodes are very restricted — you can only put in 12 numbers, no characters.
Others are very flexible and take nearly any character input. Please check out the
wikipedia list detailing kinds of barcodes (https://adafru.it/aPq)to pick the right one
for your application.
The available range of barcodes varies with the printer firmware revision. Check
Adafruit_Thermal.h for a list of codes.
It’s also possible to print QR codes, if you’re willing to pre-generate them. This might
be handy if you want to, let’s say, include a URL on the receipt and the URL doesn’t
change. You can generate QR codes at many sites including this one. (https://adafru.it/
aPr) Use the smallest QR code size. The image will be in PNG format, so if you’re
using the Windows LCD Assistant tool you’ll need to convert it to BMP first (Windows
Paint works for this). Then you can convert and embed this in your Arduino sketch as
previously described.
Page 19 of 43
CircuitPython
It's easy to use the thermal printer with CircuitPython (or Python) and the Adafruit
CircuitPython Thermal Printer (https://adafru.it/C5K) module. This module allows you
to easily write Python code that controls the printer, like printing text and barcodes
(note right now bitmap printing is not supported by CircuitPython code).
First wire up a thermal printer to your board with a serial connection exactly as shown
on the previous pages for Arduino. Be sure to supply a power supply to the printer
which can provide 5-9V at about 1.5 to 2 amps of current.
Remember too there are two ways to wire the printer, the simplest is just to connect
the TX of your board to the RX of the printer--this allows you to print anything but not
check the paper status:
Printer power positive (red wire) to 5-9V
power supply positive.
Printer power ground (black wire next to
red) to power supply negative / ground.
Printer RX (yellow) to board serial TX.
Printer ground (black wire next to yellow)
to board ground / GND.
Page 20 of 43
A more advanced option is to connect the printer's TX pin to your board's serial RX
pin. However be very careful to ensure your board supports a 5 volt serial input!
Many boards, like the Feather M0, do not support a 5V serial input and will be
damaged! You can however create a simple voltage divider with a resistor divider
circuit to knock the printer's 5V output down to a safer 3.3V level:
DC power supply positive.
Printer TX to one side of a 2.2KΩ resistor.
One side of a 3.3KΩ resistor to the
opposite side of the 2.2KΩ resistor. Other
side of the 3.3KΩ resistor to board ground
/ GND.
Board RX to the junction of the 3.3KΩ and
2.2KΩ resistor (i.e. output of the voltage
divider).
Again be very careful connecting the printer TX (green wire) to your board! As
mentioned above you can damage your board if it does not support 5 volt
inputs. When in doubt, leave the green wire disconnected! You can still print
without the green wire, you only lose the ability to read if paper is present.
Since there's dozens of Linux computers/boards you can use we will show wiring for
Raspberry Pi. For other platforms, please visit the guide for CircuitPython on Linux to
see whether your platform is supported (https://adafru.it/BSN).
Here you have two options: An external USB-to-serial converter, or the built-in UART
on the Pi's TX/RX pins. Here's an example of wiring up the USB-to-serial converter (htt
ps://adafru.it/dDd):
Page 21 of 43
USB TX to printer RX
USB Ground to printer Ground
Here's an example using the Pi's built-in UART:
Pi GND to printer Ground (black wire)
Pi TXD to printer RX (yellow wire)
If you want to use the built-in UART, you'll need to disable the serial console and
enable the serial port hardware in raspi-config. See the UART/Serial section of the
CircuitPython on Raspberry Pi guide (https://adafru.it/CEk) for detailed instructions on
how to do this.
If you want to be able to check the printer paper status, you can create a simple
voltage divider with a 2.2KΩ and 3.3KΩ resistor circuit to knock the printer's 5V
Page 22 of 43
Printer RX (yellow) to Pi serial TXD.
to Pi GND.
One side of a 3.3 KΩ resistor to the
side of the 3.3KΩ resistor to Pi GND.
Pi RXD to the junction of the 3.3KΩ and
divider).
You can use the same technique with the USB-to-serial cable:
USB ground to breadboard ground rail.
Printer RX (yellow) to USB TX (green).
to ground rail.
side of the 3.3KΩ resistor to ground rail.
USB RX to the junction of the 3.3KΩ and
divider).
Library
If you're using a CircuitPython microcontroller, you'll need to install the Adafruit
CircuitPython Thermal Printer (https://adafru.it/C5K) library on your CircuitPython
board.
First make sure you are running the latest version of Adafruit CircuitPython (https://
adafru.it/Amd) for your board.
Next you'll need to install the necessary libraries to use the hardware--carefully follow
the steps to find and install these libraries from Adafruit's CircuitPython library bundle
(https://adafru.it/zdx). Our introduction guide has a great page on how to install the
library bundle (https://adafru.it/ABU) for both express and non-express boards.
Page 23 of 43
Remember for non-express boards like the Trinket M0, Gemma M0, and Feather/
Metro M0 basic, you'll need to manually install the necessary libraries from the
bundle:
• adafruit_thermal_printer
You can also download the adafruit_thermal_printer folder from its releases page on
Github (https://adafru.it/C5L).
Before continuing make sure your board's lib folder or root filesystem has the adafruit
_thermal_printer folder copied over.
Library
If you're using a Raspberry Pi or other computer with Python, you'll need to install the
Adafruit_Blinka library that provides the CircuitPython support in Python. This may
require verifying you are running Python 3. Since each platform is a little different, and
Linux changes often, please visit the CircuitPython on Linux guide to get your
computer ready (https://adafru.it/BSN)!
Once that's done, from your command line run the following command:
sudo pip3 install adafruit-circuitpython-thermal-printer
Before you can use the printer module you must determine the firmware version and
baud rate of the printer. This is easy to find out by printing a test page from the
printer as described on the first test page (https://adafru.it/C5M), hold the printer
button as power is applied. Print out the test page and take note of these values
printed at the bottom:
• Baudrate - Remember this value, typically 19200 or 9600.
• Version - Take note of this value too, it's a value like 2.2, 2.64, 2.68, etc. You will
use the version to pick the appropriate module for interacting with the printer.
Page 24 of 43
Usage
If you're using a CircuitPython microcontroller, connect to the board's serial REPL (htt
ps://adafru.it/Awz)so you are at the CircuitPython >>> prompt. If you're using a
computer like the Raspberry Pi, bring up a REPL at the command prompt by typing py
thon3 . (On some systems, python may run Python 3 - just make sure you're not
using Python 2, as it isn't supported.)
To demonstrate the usage of the sensor we'll initialize it and print some text from the
REPL.
First you must import the necessary modules to initialize the hardware serial
connection to the printer. These commands will vary depending on your hardware choose the appropriate set:
# On a
import
import
uart =
CircuitPython microcontroller:
board
busio
busio.UART(board.TX, board.RX, baudrate=19200)
# On the Raspberry Pi with the USB-to-serial converter:
import serial
uart = serial.Serial("/dev/ttyUSB0", baudrate=19200, timeout=3000)
# On the Raspberry Pi with built-in UART:
import serial
uart = serial.Serial("/dev/serial0", baudrate=19200, timeout=3000)
Page 25 of 43
Notice the baud rate of the serial connection is specified with the baudrate keyword.
For most printers they'll use a rate of 19200 baud, however other printers might be
configured to use a different rate like 9600 baud. Use the baud rate you saw printed
on the test page of your printer!
Also be aware CircuitPython currently requires bi-direction UART connections so even
if you don't have the board RX pin hooked up (as recommended) you must keep the
RX pin disconnected and ignore using it in your project.
Next you'll need to import the thermal printer module and call a function to get the
right class depending on the version of your printer firmware. Be sure you've found
the exact version number for your printer by following the steps mentioned above and
on the previous test page!
import adafruit_thermal_printer
ThermalPrinter = adafruit_thermal_printer.get_printer_class(2.69)
Notice you call the get_printer_class function from within the
adafruit_thermal_printer module. You must pass this function the version of the
thermal printer that you're using and it will internally find the right class to import and
use in your code. In this example we're specifying a printer with version 2.69
firmware, but be sure to specify your printer's version!
The result is a class which you can immediately initialize:
Now construct an instance of the ThermalPrinter class:
printer = ThermalPrinter(uart)
Notice you must pass in the serial UART connection that was previously constructed.
Be aware it will take from a half to even 5 seconds for the printer to be created and
initialize itself and warm up. You can optionally specify auto_warm_up=False as a
keyword and manually call the warm_up function to control when this warm-up time
occurs if needed in your application (or you are confused why your code takes so
long to start up).
Page 26 of 43
Test Page Print
Now you're ready to print!
Try printing a full test page with the test_page function:
printer.test_page()
You should see the printer test page print out.
You can advance the paper forward a number of lines with the feed function, try
feeding 2 lines to make some space:
printer.feed(2)
Now print a small line of text with the print function and feed a few lines to move it
out of the printer to read:
printer.print('Hello from CircuitPython!')
printer.feed(2)
Printer Fonts
There are a few properties you can use to adjust how text is printed. Each of these
can be set to a True value to enable, or a False value to disable:
• bold - Print bold text.
Page 27 of 43
• inverse - Print inverted (white on black) text.
• upside_down - Print upside down text (might not work on all versions of
printers).
• double_height - Double height size text.
• double_width - Double width size text.
• strike - Strike-through text (again might not work on all versions of printers).
Try turning on bold text and printing a line:
printer.bold = True
# Turn on bold
printer.print('This is bold text!')
printer.bold = False # Turn off bold
# Feed lines to make visible:
printer.feed(2)
There are a few properties you can set to special values to further control text
printing:
• underline - This controls underline printing and can be None (off), adafruit_
thermal_printer.UNDERLINE_THIN , or adafruit_thermal_printer.UNDERL
INE_THICK .
• size - This controls the size of text and can be
adafruit_thermal_printer.SIZE_SMALL , adafruit_thermal_printer.SIZ
E_MEDIUM , or adafruit_thermal_printer.SIZE_LARGE . The default is
small.
• justify - This controls the justification or location of printed text and can be a
dafruit_thermal_printer.JUSTIFY_LEFT , adafruit_thermal_printer.JU
STIFY_CENTER , or adafruit_thermal_printer.JUSTIFY_RIGHT . The default
is justify left.
For example to print thick underlined, medium text, with center justification:
Page 28 of 43
printer.underline = adafruit_thermal_printer.UNDERLINE_THICK
printer.size = adafruit_thermal_printer.SIZE_MEDIUM
printer.justify = adafruit_thermal_printer.JUSTIFY_CENTER
printer.print('Medium center!')
# Reset back to normal printing:
printer.underline = None
printer.size = adafruit_thermal_printer.SIZE_SMALL
printer.justify = adafruit_thermal_printer.JUSTIFY_LEFT
printer.feed(2)
Print Barcodes
Finally you can print a barcode with the print_barcode function. Each printer
supports a different type and format of barcode so consult the product sheet in the
downloads section for each type. However here's an example of printing a UPC A
barcode with value '123456789012':
printer.print_barcode('123456789012', printer.UPC_A)
printer.feed(2)
Page 29 of 43
The first parameter to print_barcode is a string that defines the barcode value (this
varies depending on the type of barcode, a UPC A code is 13 digits). The second
parameter is the type of the barcode, which again is dependent on the printer
firmware. Typical values you might use include:
printer.UPC_A
printer.UPC_E
printer.EAN13
printer.EAN8
printer.CODE39
printer.ITF
printer.CODABAR
printer.CODE93
printer.CODE128
Check Paper
If you've connected the RX pin of your board to the printer TX (again be very careful
to make sure your board supports a 5V serial RX--many don't!) you can query paper
status with the has_paper function that returns True or False if there is paper
present:
printer.has_paper()
That's all there is to using the thermal printer with CircuitPython!
A complete demo of the usage is in the thermal_printer_simpletest.py demo in the
library (https://adafru.it/C5N).
If you're running thermal_printer_simpletest.py on the Raspberry Pi (or any
computer), you'll have to make some changes.
On the Raspberry Pi, comment out the uart = busio(...) line, and uncomment
the import serial and uart = serial.Serial(...) lines, changing /dev/
ttyUSB0 to the appropriate serial port.
Page 30 of 43
Unless you used a voltage divider to hook up the printer TX line, make sure you
comment out the paper check code:
# Check if the printer has paper. This only works if the RX line is connected
# on your board (but BE CAREFUL as mentioned above this RX line is 5V!)
#if printer.has_paper():
print('Printer has paper!')
#else:
print('Printer might be out of paper, or RX is disconnected!')
Now you can run the program with the following command:
python3 thermal_printer_simpletest.py
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
# SPDX-License-Identifier: MIT
# Simple demo of printer functionality.
# Author: Tony DiCola
import board
import busio
# Pick which version thermal printer class to use depending on the version of
# your printer. Hold the button on the printer as it's powered on and it will
# print a test page that displays the firmware version, like 2.64, 2.68, etc.
# Use this version in the get_printer_class function below.
# Define RX and TX pins for the board's serial port connected to the printer.
# Only the TX pin needs to be configued, and note to take care NOT to connect
# the RX pin if your board doesn't support 5V inputs. If RX is left unconnected
# the only loss in functionality is checking if the printer has paper--all other
# functions of the printer will work.
RX = board.RX
TX = board.TX
# Create a serial connection for the printer. You must use the same baud rate
# as your printer is configured (print a test page by holding the button
# during power-up and it will show the baud rate). Most printers use 19200.
uart = busio.UART(TX, RX, baudrate=19200)
# For a computer, use the pyserial library for uart access.
# import serial
# uart = serial.Serial("/dev/serial0", baudrate=19200, timeout=3000)
# Create the printer instance.
printer = ThermalPrinter(uart, auto_warm_up=False)
# Initialize the printer. Note this will take a few seconds for the printer
# to warm up and be ready to accept commands (hence calling it explicitly vs.
# automatically in the initializer with the default auto_warm_up=True).
printer.warm_up()
print("Printer has paper!")
else:
print("Printer might be out of paper, or RX is disconnected!")
Page 31 of 43
# Print a test page:
printer.test_page()
# Move the paper forward two lines:
printer.feed(2)
# Print a line of text:
printer.print("Hello world!")
# Print a bold line of text:
printer.bold = True
printer.print("Bold hello world!")
# Print a normal/thin underline line of text:
printer.underline = adafruit_thermal_printer.UNDERLINE_THIN
printer.print("Thin underline!")
# Print a thick underline line of text:
printer.print("Thick underline!")
# Disable underlines.
# Print an inverted line.
printer.inverse = True
printer.print("Inverse hello world!")
printer.inverse = False
# Print an upside down line.
printer.upside_down = True
printer.print("Upside down hello!")
printer.upside_down = False
# Print a double height line.
printer.double_height = True
printer.print("Double height!")
printer.double_height = False
# Print a double width line.
printer.double_width = True
printer.print("Double width!")
printer.double_width = False
# Print a strike-through line.
printer.strike = True
printer.print("Strike-through hello!")
printer.strike = False
# Print medium size text.
printer.print("Medium size text!")
# Print large size text.
printer.size = adafruit_thermal_printer.SIZE_LARGE
printer.print("Large size text!")
# Back to normal / small size text.
# Print center justified text.
printer.print("Center justified!")
# Print right justified text.
printer.justify = adafruit_thermal_printer.JUSTIFY_RIGHT
printer.print("Right justified!")
Page 32 of 43
# Back to left justified / normal text.
# Print a UPC barcode.
printer.print("UPCA barcode:")
printer.print_barcode("123456789012", printer.UPC_A)
# Feed a few lines to see everything.
printer.feed(2)
Python Docs
Python Docs (https://adafru.it/C5O)
Downloads
• Adafruit_Thermal library for Arduino (https://adafru.it/aHt).
• LCD Assistant (https://adafru.it/aPs) — optional bitmap conversion utility for
Windows.
• Processing (https://adafru.it/aMI) language — needed for bitmap conversion for
Mac or Linux (and optionally Windows). DOWNLOAD VERSION 1.5.1, not the 2.0
beta.
• Thermal Printer User Manual (https://adafru.it/C5P).
• An older version of the Thermal Printer User Manual (https://adafru.it/C5Q).
• Thermal Printer Product Sheet (https://adafru.it/C5R).
Firmware Changer
If you'd like to risk it, you can revert/change the firmware using this tool that is from
the manufacturer. We haven't tried it. It's completely utterly unsupported and you may
break your printer. We won't replace it if it stops working due to a firmware change!
update_firmware.zip
https://adafru.it/oAA
Troubleshooting!
I'm not getting it to work!
First thing to try is the power up test. You do not need an arduino for this
Make sure the paper is in the bay correctly, it should feed under and up so that the
Page 33 of 43
paper comes through the slot without bending
Hold down the button on the top, then plug in the printer to power. It should print
out a test page
The green LED will not be on solid, it will blink once in a while, that's normal.
I'm trying the self test and it's still not working.
Make sure you have a good power supply that can deliver the required current. If
you are trying to operate at 5V, your power supply must be able to maintain a
constant 5V even when the current demand spikes during printing. If your printer is
making an attempt to print, but then struggling, then it is likely your power supply is
dipping below 5V.
If possible, try a higher voltage power source. At 9V you should be able to get
away with 1A.
I'm having difficulty getting a printout
Make sure the paper roll is not 'stuck' feeling in the bay, it should rotate easily!
My Arduino sketch used to work, but doesn't compile
now!
Some changes have been made to support a broader range of Arduino-like boards.
Older code will require updating. Fortunately it's just a few lines around the global
declarations and the setup() function.
Old syntax:
Adafruit_Thermal printer(RX_PIN, TX_PIN);
New syntax: declare a SoftwareSerial object and pass its address to the
Adafruit_Thermal constructor, like so:
SoftwareSerial mySerial(RX_PIN, TX_PIN);
Adafruit_Thermal printer(&mySerial);
Page 34 of 43
Then, in the setup() function:
mySerial.begin(19200);
printer.begin();
My sketch compiles, but the output is different than
before.
The printer's features and behavior have changed over various firmware releases.
First, check the PRINTER_FIRMWARE value in Adafruit_Thermal.h, make sure it
matches the value at the bottom of the printer test page (hold down the paper feed
button when connecting power to print out a test page).
Some features just behave a little differently among releases…barcodes, line feeds,
etc.…if you were previously using an older library or an older printer, you may need
to tweak the code to produce the desired formatting with a current setup.
The USB printer is not showing up as expected.
The printer might be in a different mode. To check and change the current USB
mode, do the following:
• Similar to self test - hold in the FEED button while applying BUT KEEP
HOLDING IT (see below).
• You should get an extra bit of output that will tell you the Current USB mode.
It should say COM.
• If it doesn't say COM, then change the USB mode by holding the FEED button
again for 2 seconds.
• It should print the new USB mode and then exit.
• Done.
Page 35 of 43
Page 36 of 43
Hacking!
Look at those huge, razor-sharp image prints! You want some?
The following…
• Is an undocumented printer feature and is NOT guaranteed to work.
• May require modifying your printer — a warranty-voiding operation! Continue at
your own risk.
You should only attempt this if all of the following apply:
• Have first confirmed that the printer works as expected when operated through
conventional procedures.
• Have a genuine performance bottleneck that cannot be adequately resolved
by adjusting the printer timing and thermal settings first.
• Are comfortable opening things and soldering.
A modified printer is not eligible for a refund or exchange.
These printers have a limited serial receive buffer. Push bits to the printer faster than
it can physically heat dots and feed paper, and you experience an “overflow” —
bitmap images become garbled, text and formatting commands may be skipped.
The thermal printer library tries to throttle data to the printer at just the right rate. Too
fast and an overflow occurs. Too slow and it wastes your time; the printer isn’t
Page 37 of 43
operating at peak throughput. This is an imperfect process…though we use very
conservative timing estimates, the actual speed through the printer is impossible to
predict…sometimes overflows still occur.
Hardware handshaking is a means by which a printer or other device can report to the
microcontroller that it’s ready to receive more data, virtually eliminating buffer
overflows while operating at peak throughput…the paper feed stops only when it
physically absolutely must. Optimal performance.
It appears that some varieties of these thermal printers support hardware
handshaking (e.g. firmware v2.64, 2.68). This is barely mentioned in the datasheet,
and in fact there isn’t even a physical connection for this on the outside of the printer.
A little surgery is in order…
The “Tiny” and “Nano” printers (plus the “Printer Guts”) have an exposed DTR pin
— no modification is necessary! Scroll down to the “Code Changes” section to
continue.
• Small Phillips head screwdriver
• Pliers
• Soldering iron and related paraphernalia
• A bit of wire…but ideally a female jumper wire
Procedure
Unplug all cables, turn the printer over and
remove the two small Phillips screws.
Page 38 of 43
Take the back plate off, then remove the
two (or sometimes four) Phillips screws
holding the circuit board in place.
These screws are a little smaller than the
back-holding ones…don’t get them mixed
up!
Carefully, so as not to unseat or unplug the
connectors, turn the circuit board over and
look for the unpopulated via labeled
“DTR.”
There are some other interesting solder
points in here, if you’re so inclined. “HV” is
the raw 5–9 Volts from the power supply.
On the right is a 3.3V pin, though I don’t
know the available current. Conceivably
one could bring these out to reduce
overall cabling in a project…or even install
a tiny microcontroller right inside!
Cut an end off a female jumper wire and
strip & tin the end.
This will be hanging out of the printer…so a
female jumper prevents accidental contact
with things if you’re not using the
connection. If you only have regular wire,
that’s fine, just be careful not to leave a
bare end dangling.
Page 39 of 43
Solder the wire to the DTR pad. Top,
bottom, doesn’t matter…it’s right up
against the serial connection plug, so use
whatever path works best for you, there’s
ample room for routing the wire around
either way.
Pedants may note that this isn’t technically a DTR pin, but rather CTS. It’s longstanding thing among printer manufacturers…apparently the misnomer was made
decades ago but has stuck for consistency.
On the back plate, there’s a small metal
“finger” between the serial and power
sockets. Using pliers, this can be bent
back to provide an exit route for the DTR
wire.
Page 40 of 43
Screw the controller board back in place
(check that neither of the cables has come
unseated), routing the DTR wire around
between the two sockets, then screw the
back on.
Finished with the hardware!
You can then reconnect the power and serial sockets, and wire those up as before.
Use a jumper wire to connect DTR to any available Arduino pin. In our examples, we’ll
use digital pin 4.
The printer electronics operate at 3.3V, so no level shifting is needed with 3.3V
boards (Arduino Due, etc.)…this can safely be connected directly.
Code Changes
Just one line…the Adafruit_Thermal constructor…needs changing. It can accept an
optional parameter, a pin number to use for DTR:
Adafruit_Thermal printer(&mySerial, 4);
This works just as well with a hardware serial port (e.g. Arduino Mega or Due):
Adafruit_Thermal printer(&Serial1, 4);
No other changes are necessary. Try this with one of the example sketches…you’ll find
the printer is suddenly lots faster! That’s because the software throttle is no longer
used…the printer continually reports its actual “ready” state to the microcontroller.
Page 41 of 43
The printBitmap() function can output images from an open stream or stored in
PROGMEM (flash memory)…as explained on the “Printing Bitmaps” page.
Although the Arduino Mega has a whopping 256K flash space, a limitation of the AVR
microcontroller is that a single array can’t exceed 32K…that’s about a 384x680 pixel
bitmap image. If you try to embed a larger image in your code, the compiler will report
an error.
One workaround might be to break really long images into multiple smaller images,
and print these out consecutively without a feed() in between.
Another is to use a non-AVR Arduino-compatible board, such as the 32-bit Arduino
Due. This has no problem with massive arrays. The Chrysler Building image above is
384x1132 pixels!
This type of printer fares best with light line art and sometimes dithered photographic
images as long as the overall dot density is fairly low, like under 50%. Large solidfilled areas exhibit strange streaky artifacts…this isn’t a bug of the library or printer
firmware, but just a side-effect of how receipt printers operate, that they can only heat
so many dots at a time and have to pull shenanigans to go beyond that, else they jam.
Page 42 of 43
Here are a couple examples from fancy
commercial receipt printers.
Notice in the first one that the “solid black”
area isn’t really solid black…examining it
closely, you can see it’s densely dithered,
but not 100% filled.
The second does have solid fills, but limits
the total area. On any given row, only so
many pixels are set.
If you try to print a “dense” image and the paper jams (image gets squashed
vertically), pass a lower density value to printer.begin(). Default value is 120. So for
example:
printer.begin(80);
DTR support is not a panacaea. Glitches occasionally do still happen…sometimes
overflows, sometimes “framing errors” with serial data. But overall it seems fairly
reliable and buttery smooth!
Page 43 of 43
